335xiboost's Avatar
335xiboost 335xiboost is offline
Car: 2008 335xi jb+ VSRF ******* DP DCI cabin filter delete
Default Keeps going Map 4 log attached - 06-29-2016, 08:12 PM
So I thought my Map 4 problem was because of the 4x4 light. I now have no lights on my dash and no matter what it keeps kicking me to MAP 4. It worked perfectly before my car was crashed now I can't get it to do anything. I'm at my wits end with this thing. No misfires coils and plugs are pretty new have new ones waiting along with a 3.5 bar map sensor and planned on ordering a hot side charge pipe once I can make more than 10 lbs of boost. Any way to disable the fail safe so this stops happening?
2014 M5 1 of 577 6spd awaiting MORE BOOST
07 Cayman 5sp
08 Cayman S 6spd
02 996 TT 6spd more boossttt
04 Gallardo gated 6spd
Jayock's Avatar
Jayock Jayock is offline
Enginerd
Car: 2009 135i
Default 06-29-2016, 08:54 PM
You are going lean.
Update your interface and jb4 software so we can see more timing. 2014 software is soooo 2 years ago
--2009 BMW 135i--2016 Nissan Titan XD (Turbo Cummins ISV)--2016 VW Tiguan 2.0Tsi --1988 Beechcraft Bonanza--Suzuki GSX-R 1000--Honda CBR-600RR--
JB4 G5 ISO | MHD | E85 | Fuel-It S3 LPFP / PI | MFactory S3+ Clutch / SMFW / LSD / Mounts | Diff Lock | UUC Tranny Mounts | DwnPipes / Exhaust / FMIC | Chargepipe / Tial | KW V3s | HR Sways | HPA full M3 Suspension | BMS DCI / Oil Cooler Valve / Cowl Filters / 4bar / 2Step / OCC | RB PCV | Stri Gauges | Pole Position 225/265 | Installing: DR 6466ST
Jayock's Avatar
Enginerd
Car: 2009 135i
Default 06-29-2016, 08:55 PM
Also, don't disable your failsafe, even if you find a way. You are triggering it because you are almost 17:1 afr when you go failsafe.
335xiboost's Avatar
Default 06-29-2016, 09:15 PM
Damn what would cause it to lean out that bad failing HPFP? I guess it's good I'm not making boost it sat for 7 months and was loving map 7 now this
07 Cayman 5sp
08 Cayman S 6spd
Default 06-29-2016, 09:17 PM
Update the interface, yours is old and missing a lot of data. But also read the fault codes.
335xiboost's Avatar
Default 06-29-2016, 09:23 PM
How can I read the fault codes I was running it without the JB4 and had none except the O2 code from my dwn pips.
07 Cayman 5sp
08 Cayman S 6spd
335xiboost's Avatar
Default 06-29-2016, 09:25 PM
Also is it the old software that's causing it to run that lean?
07 Cayman 5sp
08 Cayman S 6spd
Default 06-29-2016, 09:29 PM
No just preventing the log showing all the data. So relog it after updating the interface.
You should never have o2 fault codes. That must be the problem. Fix them.
335xiboost's Avatar
Default 06-30-2016, 04:37 AM
I thought they were from the dwn *****
07 Cayman 5sp
08 Cayman S 6spd
Xshadows Xshadows is offline
Car: 2008 135i
Default 06-30-2016, 07:24 AM
You will get ******* ********* DETECTED codes, not O2 sensor codes.
335xiboost's Avatar
Default 07-03-2016, 07:50 PM
Just ordered the O2 sensors my understanding are the 5 wire pre *** are the only ones that matter pretty sure they are the original ones the car was assembled with 121,000 miles ago so it's probably time they were replaced
How do I update the software I wanted to do it before but couldn't figure out how...also could anyone point me in the right direction for a baseline adjustment to run 22psi safely with 50% E85 I'm going to install my 3.5 bar map when I do the O2 sensors and install the new plugs and coils that have been sitting for months while I got this thing pieced back together.
07 Cayman 5sp
08 Cayman S 6spd
