(#4426)
stilov stilov is offline
Car: 07 335
Default 06-09-2012, 09:38 AM
With nitrous you'll need it just for the nitrous trigger, and depending on the shot the on demand CPS.
I have the nitrous trigger setup from the DIY on the G4 board...with the external relay.
Right now the jet is small but I'd like to try moving to a little larger .032 jet...I have a .026 right now.
I mean my wiring is done, I guess the G5 would make it cleaner looking...
Default 06-09-2012, 09:41 AM
Got it. Maybe not much benefit for you then. Would need to see logs to determine if anything in the G4 is holding it back.
mykal335xi mykal335xi is offline
boom
Car: BMW
Default 06-09-2012, 10:17 AM
.046 will be 80-100whp with a dual meth nozzle setup, so CPS is needed there, with the .032 or .036 it seemed to me that the power was a lot less, maybe 30-40whp. I know there are a handful of guys running smaller jets without reducing timing, and have been doing so for some time.
When I get my G5, I'm going to buy an hour at the dyno and play with the different jets, also going to have a dual meth nozzle setup with a valve to shut one nozzle off like hotrod had. So far running dual nozzles on my stock turbos without DP/FMIC seems to reduce power somewhat.
I won't be running nitrous in DD trim, purely a seats out/race gas type of setup for me. That being said I may still invest in a wideband, not sure it's needed at the lower power levels but at a .042 or .046 jet there is a lot more going on.
2011 335i m-sport
2008 335xi (Sold)
paf335i paf335i is offline
Car: 07 335i
Default 06-09-2012, 10:43 AM
how do i download the jb4 software to upload new firmware? Please help and how!
thanks
Car: 07 335i
Default 06-09-2012, 10:47 AM
Terry,
How do i install the software to update my jb4 to 5/23 as we were talking by email. I dont know how to get the program on my laptop or where to download the software, and when i download the hex file for the 5/23/ firmware it is a widows media center or something. what am i doing wrong? thanks !
aoschadlin's Avatar
Car: 535i
Default 06-09-2012, 10:53 AM
Originally Posted by paf335i
Terry,
1) Go to the first post in this thread.
2) Download the "interface" and install it. It's a software program.
3) Download the HEX file and save it somewhere you'll remember.
4) Connect your USB cable to the JB4
5) Follow these instructions http://www.n54tech.com/forums/showpo...21&postcount=1
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 06-09-2012, 11:31 AM
Also do not forget to run the usb_driver.exe program after running the setup.exe program. You will not be able to connect to the JB4 without running it first.
Car: 07 335
Default 06-09-2012, 01:36 PM
I have not pulled any timing on it...I have only used one 10lb bottle since Oct. I even have the n20 shut off at like 6600 rpm.
I have only used the .026 jet and you know, you can barely feel the difference. Thats why I wanted to step it up, but 1st priority is replace turbos right now and then last week it was moving my meth to the trunk.
Ramjet's Avatar
Ramjet Ramjet is offline
Car: Z4 s35i 7DCT
Default 06-09-2012, 05:42 PM
Originally Posted by Dirty Dog
Got me a local E85 gas station as well.
Hey Dog, you in Melbourne right, how'd you find the E85, I'd love to find some in Brisbane?
E89 N54 / Wedge / RB Turbos / AFE DCI / HPF FMIC / Stett CP / Forge DV's / AR Cattless DP's / BMS OCC / RB PCV2 / BMS Spacers
Dirty Dog's Avatar
Default 06-09-2012, 05:46 PM
PMed
rudypoochris rudypoochris is offline
Default 06-09-2012, 06:16 PM
Just confirming we can do the $150 upgrade even if we mod to 15ohm provided the solder job is good. Correct?
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 06-09-2012, 08:15 PM
OT but where can you get this valve for meth lines.
e92
boom
Car: BMW
Default 06-09-2012, 09:27 PM
Not sure, I was going to head to Lowes and try to find something that will fit with the CoolingMist meth lines I have.
I know others have said before that the meth lines are close to the size of refrigerator lines and such so there are fittings out there that will work, even if they are not the best for high meth content.
Worst case I'll just buy the push-fitting to AN connector from Howerton and I know I can make it work on AN-3 or AN-4 screw in lines.
2011 335i m-sport
2008 335xi (Sold)
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 06-10-2012, 12:27 PM
i bought a copper valve from lowes that was in the same section as the refrigerator fittings and such. looks like the inside diameter of the valve is smaller than the inside diameter of the hose so i guess ill have to go back and find another one. i dont recall there being alot of options though.
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
Car: 07 335
Default 06-10-2012, 01:09 PM
Well what's the thread size of the quick connect fittings? 1/8 npt?
Seems like you could find a double female ball valve that would work with those. I have some extra so I'm gonna try.
NihonX NihonX is offline
Car: 1M
Default 06-10-2012, 02:41 PM
I just purchased some polyurethane tubing from Home Depot.
It's worked for me and still no problems.
AcidLotus AcidLotus is offline
Car: 2009 LCI 335xi
Default 06-10-2012, 05:32 PM
This 5/23 firmware is pretty solid! I'm on a 60:40 91:E85 mix and am getting about 2 psi more. Also not getting any codes, which is good. Previously when I ran map 5, it felt about the same as map 1, but I'd get an exhaust vanos mechanical code, even after swapping and cleaning the solenoids. Could never get the code to throw on map 1 or stock. I also seemed to notice it more when the fuel gauge was less than 1/4 tank full.
mrbillytalent's Avatar
mrbillytalent mrbillytalent is offline
Probably being sarcastic
Car: e46 323i & e90 335i
Default 06-11-2012, 07:24 AM
Mine did the same thing, just wait a few mintues and it will work again. I believe it has something to do with the DTC or breaking traction, while using or about to be using the Cruise control. I've researched it and its a mystery.
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar dp's SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 06-11-2012, 07:15 PM
T, you said that the G5 firmware is different than G4, is the interface the same? Also how do I raise or lower the RPM on the 2 step? Am I able to turn the 2 step on/off from the speedo?
2011 335is DCT, FBO
Default 06-11-2012, 07:21 PM
Same interface, different firmware. 2step is on menu 8 IIRC.
OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default 06-11-2012, 08:04 PM
'Bout time I subscribed. More logs coming soon with car prepared. Cheers!
Terry's unmatched dedication to the N54
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
Mastermixlee Mastermixlee is offline
Car: 335
Default 06-12-2012, 12:48 AM
Terry would it be possible to add in a feature so you have to press 2 buttons to start the engine. For example u would have to press the brake AND press volume up on the steering wheel before the engine start button would work? May be asking too much but I would love this kind of feature as I hear so many BMW's being stolen, and lots of break ins and keys getting stolen. Would be a nice bit of added security.
David1 David1 is offline
Car: 335i Coupe
Default 06-12-2012, 08:35 AM
That wont help, they tow them away to get em.
Default 06-12-2012, 08:43 AM
Put a tracking device on your car. Then if it goes missing, round up a couple of NRA buddies and a juiced up Big Foot, follow the signal!
boom
Car: BMW
Default 06-12-2012, 11:58 AM
Have you run the car on the dragstrip with RBs?
2011 335i m-sport
2008 335xi (Sold)
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
ludo
