(#4376)
thesalg thesalg is offline
Car: 335xi
Default 05-30-2012, 05:20 AM
are all the boards gone?
Default 05-30-2012, 10:07 AM
Don't have any at the moment, but 20 are out there in testing now. Will expand that by another 10 or so next week.
Caruso0644's Avatar
Caruso0644 Caruso0644 is offline
Car: E92 335i
Default 05-30-2012, 12:32 PM
Should have mine tomorrow by Noon! Weather here is going to be 75 and Sunny, So ill be sending in logs
15' M4 : JB4 : BMS intake : Meisterhaft full exhaust : AR **'s : MSR Charge ***** : H&R Sport Springs / 08' E92 335i : Montego Blue : JB4-G5 : DCI : BMSMeth : BMSoilCC : VRSF **'s : VRSF Front Mount : 19" Vertini Magic : Bridgestone RE-11 : Carbon CSL Trunk Lip : MtechRearBumper : Mtech FrontBumper
Car: 335xi
Default 05-30-2012, 04:10 PM
Thanks Terry. Hope I can jump in on the next one!
vereak82's Avatar
vereak82 vereak82 is offline
Default 05-30-2012, 04:34 PM
Sent you my G4 Board today
JB4 pnp, Afe dci, Riss Racing ''**, Cyba intake scoops, ZS-Charpe pipe w bv, BMS ww Meth kit,
12.06@117 6-speed manual
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 05-30-2012, 07:08 PM
T will it be possible to run a 2 step and nitrous trigger off the board at the same time?
2011 335is DCT, FBO
Default 05-30-2012, 09:20 PM
No, it's setup for one or the other. But I can't say I'd suggest trying to NLS or 2step with nitrous involved.
Dirty Dog's Avatar
Default 06-01-2012, 06:19 PM
Terry 5/23 is absolutely amazing. I run map 3 99% of the time and put a mix of 50/50 98RON/E85 in the tank the other day and map 5 is now more aggressive than map 2.
Map 5 is my new rainy day map.
Default 06-02-2012, 09:57 AM
Upgraded this thread to sticky status. At some point in the future I'll start posting G5 specific firmware and notes in the first post. Those who are testing the G5 board, the interface will not yet block you from uploading G4 firmware. And if you do the car will throw lambda, crank position, and other various codes. So make sure to only upload G5 specific firmware.
illrider illrider is offline
Default 06-02-2012, 12:53 PM
Will the max cool mode help lower oil temperatures at all? Or just coolant temps? Got the dreaded limp mode today at the track. :-/
Default 06-02-2012, 01:25 PM
You'd have to check the specific code to see whether it was a water or oil temp limp. But it helps with both.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 06-02-2012, 01:26 PM
Autocross no....1/4 mile yes.
Default 06-02-2012, 01:55 PM
I never actually got a code. The oil temp gauge was reading around 270-280 though and the exterior temperature was around 103 today. Power kept going in and out. Part of the lap I would have full power, then all of my power would go away, then eventually the power would come back on, then shut off again.
Default 06-02-2012, 01:59 PM
Ah, yeah that is just the JB4 then cutting power on you to keep it from going in to an actual limp code.
aoschadlin's Avatar
Car: 535i
Default 06-02-2012, 02:02 PM
Is it possible for that the JB4 to "flutter" the power on and off or is that something else again?
I had that happen to me recently at a Laguna Seca track day.
No codes or CELs though.
Default 06-02-2012, 02:04 PM
We don't get people riding at 280 degrees often, but the logic right now might be too sharp of a transition. E.g. it goes from full boost to stock boost from 280->284 degrees. Maybe it could be smoothed out to 270->290, etc. But either way I think its time for you to consider some cooling mods.
aoschadlin's Avatar
Car: 535i
Default 06-02-2012, 02:06 PM
I was hoping Meth would do that.
I guess a larger IC is the next step.
GbreeE90 GbreeE90 is offline
Default 06-02-2012, 03:15 PM
What's the word on E85 tuning?
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 06-02-2012, 05:41 PM
E85 is amazing for the N54!!! Im a true believer after trying it!
skysurfer's Avatar
skysurfer skysurfer is offline
Car: 2008 535i
Default Read... - 06-02-2012, 05:44 PM
Search and Read !!
http://www.n54tech.com/forums/showthread.php?t=15846
Fly Birdie Fly !!
2008 BMW 535i
JB4 G5, BMS Pump Flash, ( Updated FW ), DCI,
Eisenmann Race Exhaust
ER CP
E60 **
450 HP / 480 TQ ( when running AEM 320, 50% E85 )
https://www.youtube.com/watch?v=51z_sELokzk
chuckd05 chuckd05 is offline
Car: 08 135i , 06 325xi e90
Default 06-02-2012, 06:30 PM
Has anyone just purchased a new core and installed a larger oil cooler. I'm not sure what size lines run to the oil cooler but I piece together a Setrab 25 row for my 370z that lowered temps 40 degrees. I was thinking about doing the same with my 135. I used a thermostatic sandwich plate for the Z tho I'm assuming I'd have to make do with the stock lines.
Max cool will only help so much. Most likely won't stop limp mode on a track ...
e92
robc1976's Avatar
robc1976 robc1976 is offline
Default 06-02-2012, 07:21 PM
Oil cooler
O, love mine!
robc1976's Avatar
Default 06-02-2012, 07:22 PM
I have, stage 2 Stett with a strab core.
bigdnno98's Avatar
Car: e92 335i
Default 06-03-2012, 07:21 AM
haha, for sure T. Wasn't trying to use them both at the same time. Just have them hooked up at the same time. use the NLS/2 step when I wasn't using NOS. I'm still on the fence with the NOS though so I'll be trying the 2 step/NLS for sure.
2011 335is DCT, FBO
09E90utah's Avatar
09E90utah 09E90utah is offline
Car: 2009 e90 xDrive 6MT
Default ? About DTC at start-up - 06-04-2012, 02:18 PM
Hey Terry,
When 5/5 is selected, should my one button push DTC dash light show? I've tried to toggle multiple times, and it never activates the dash light. I've always selected this when the vehicle is running so do I have to activate it when the engine isn't running?
NM - Just went through the old release notes and see that it isn't compatible with xDrive. Any chance that it will ever be compatible?
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
