mfromani mfromani is offline
Car: E93
Default 3166 Code - 10-06-2018, 12:03 AM
Installed the JB4 a few weeks ago on my 2013 E93. Car seems to run fine but about every 150 to 200 miles it throws a 3166 code. Didn't give these codes in the past. I've searched this forum and other forums on 3166 codes but I don't see anything on a real solution. I'm running MAP 5
Also what exactly is a "tuner code?" I see people referring to tuner codes but I can't find a definition of what that means.
Finally - using the iOS app I can't seem to get the H2O or tranny gauge temp to work. Just says 0
Default 10-08-2018, 09:17 AM
Does a CEL come up with the 3166 code or is that just the tuner code?
Are you on the most update Jb4 firmware?
WeekendWarriorz WeekendWarriorz is offline
Car: 2012 135i N55 DCT
Default 10-08-2018, 11:45 PM
Update latest firmware and plug the stock MAP connector harness in. Cel should go away and never come back
Car: E93
Default 10-09-2018, 02:56 PM
CEL would come up. I just updated firmware earlier today using JB4 mobile.
Car: E93
Default 10-09-2018, 02:57 PM
So do you mean don't hook the MAP connector to the JB4?
CTM95's Avatar
CTM95 CTM95 is offline
Car: 2013 135i
Default 10-12-2018, 04:15 PM
I am having the same issue, I installed the JB4 with the connect kit and updated to the 17_T5 firmware about a month ago and with in the first 30 miles got the 3166 code. I cleared it and it keeps coming back within 50 miles, if I don’t clear it within a day it’ll throw a SES light. It happens on maps 1,2,4, and 5 but not 0. I’m also getting an intermittent 2C90 that I’m not sure is related but it happens on all maps but 0 even with default settings on menu 10,11, and 12.
2013 135i DCT, 16k miles, BMS Intake/OCC, JB4, ETS 7" IC/CP, AR Down Pipe, GFB DV+, Berk Street Catback, 92/93 oct. - Totaled
2013 135is DCT, 46k miles, BMS Intake, JB4 w/ connect kit, ER CP, VRSF Down pipe, 92/93 oct.
Default 10-21-2018, 01:10 PM
Originally Posted by CTM95
I am having the same issue, I installed the JB4 with the connect kit and updated to the 17_T5 firmware about a month ago and with in the first 30 miles got the 3166 code. I cleared it and it keeps coming back within 50 miles, if I donít clear it within a day itíll throw a SES light. It happens on maps 1,2,4, and 5 but not 0. Iím also getting an intermittent 2C90 that Iím not sure is related but it happens on all maps but 0 even with default settings on menu 10,11, and 12.
Disconnect the Jb4 harness from the MAP connector harness and plug the stock one in. Leave the jb4 one unplugged. You're all set to go now.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 10-22-2018, 01:08 PM
I actually just installed the JB4 on my 2014 X1 and had the same code come up. So you're saying I should only have the TMAP, Fuel pressure wires (FF), and the Boost solenoid wires hooked up?
I am running 5.14.T8
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Default 10-22-2018, 01:23 PM
When I spoke to Ando @ BMS he said I needed to be on the latest firmware, which should be 5.17. And correct, leave the MAP sensor unplugged and dangling around. I zip tied mine to the big harness.
Car: 2011 e92 335i
Default 10-22-2018, 01:27 PM
It was a typo on my part. I am running 5.17.T8. I will give it a shot tomorrow. Thanks for the heads up.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
MrHaloHalo's Avatar
MrHaloHalo MrHaloHalo is offline
Car: 2014 X1 35i
Default 10-22-2018, 05:08 PM
On my X1 (stock turbo, stock BEF, JB4 firmware version 5.17_T5), running the JB4 disconnected from the MAP sensor (i.e. stock connected) did fix the 3166 code. I ran it this way for several thousand miles with no real problems, but it did cause a constant 28A0 code (throttle-valve angle - intake manifold pressure correlation: limit value exceeded). This would show up as a 'tuner code', but for unknown reasons it would sometimes trip the CEL. I would clear it, drive for a couple of days, and the CEL would come on again, and the only code showing was 28A0.
Eventually, it seemed to trip a nuisance CEL about as much as the 3166 code did. So, figuring more data to the JB4 is better than less (all things being equal), I've reconnected the MAP sensor to the JB4. Hopefully, the 3166 bug gets fixed in the next JB4 firmware.
Default 10-22-2018, 05:19 PM
Hmm, my car hasn’t had any codes, I’ve seen in another thread that this has fixed the issue for other cars too. Hopefully terry can make a once and for all fix in a new firmware update
MrHaloHalo's Avatar
Car: 2014 X1 35i
Default 10-22-2018, 05:29 PM
Maybe its because I'm still on the stock BEF, or maybe its an X1 thing? I'll be curious to hear if others (particularly X1 owners) running the JB4 disconnected from the MAP sensor report getting the 28A0 code/CEL.
Car: 2011 e92 335i
Default 10-22-2018, 05:41 PM
I cannot imagine this being specific to the X1. It may have something to do with the stock flash however.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
mishmosh mishmosh is offline
Car: bmw x1
Default 10-26-2018, 02:26 PM
I'm getting this on my X1 as well. 3166 does not turn up at all on map 0. It will show up after some driving on map 5. If you don't clear it, it'll trip the check engine light after some more driving. I'd like to say it's been going on for at least 3 months now but I haven't tried anything. Will connect up the stock MAP connector to see if that really works. THANKS
Car: 2011 e92 335i
Default 10-26-2018, 10:21 PM
I haven't been able to test mine yet. Someone hit me in a parking lot so the car is going to the body shop first.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
CTM95's Avatar
Car: 2013 135i
Default 10-27-2018, 07:09 PM
I got around to switching back to the stock MAP, after putting quite a few miles on it my 3166 is gone but I'm now also having the 28A0 that throws the CEL after a while. I'm in a 135is so it's not an X1 specific thing.
Default 10-27-2018, 07:21 PM
Are you guys on the newest firmware? My late e has no codes and I’m on the newest firmware with the map unplugged. 2012 here
CTM95's Avatar
Car: 2013 135i
Default 10-27-2018, 07:50 PM
Just checked again to be sure, and I am on the most current firmware.
MrHaloHalo's Avatar
Car: 2014 X1 35i
Default 10-27-2018, 09:55 PM
CTM95: Are you still on the stock DME flash, or do you have a BEF?
CTM95's Avatar
Car: 2013 135i
Default 10-27-2018, 09:59 PM
Still on the stock DME flash.
MrHaloHalo's Avatar
Car: 2014 X1 35i
Default 10-27-2018, 10:21 PM
Interesting - hopefully this will be useful info for Terry
Default 10-30-2018, 08:45 AM
3166 is probably somehow tuning related to the DWP settings. Tried DWP = 0 to see if that helps?
CTM95's Avatar
Car: 2013 135i
Default 10-31-2018, 02:46 PM
I will be switching back to the JB4 MAP connection this weekend as the 28A0 seems to trip the SES light much quicker and more frequently than the 3166 did. I will do some driving with the DWP set to 0 and see what the results are.
MrHaloHalo's Avatar
Car: 2014 X1 35i
Default 10-31-2018, 04:22 PM
Had a chance to drive the X1 today, so I tried DWP=0, but I got the 3166 after about 5 miles. Cleared it, drove another 10 miles, checked codes and it was back again.
Any other settings to experiment with?
