Boba8523 Boba8523 is offline
Car: C
Default BMW X2 Fresh Install Log Review - 12-08-2018, 03:05 PM
Hi Everyone,
Just installed the JB4 for my BMW X2 B46 engine.
Would love to get a review of my logs to ensure everything is running smooth.
On stock cats, 91 pump fuel.
MAP 0 WOT
.csv Log
Map 1 WOT
.csv Log
MAP 1 WOT #2
.csv log
Map 1 driving around (various WOT, aggressive driving)
.csv log
Default 12-08-2018, 03:34 PM
For logs we need the CSV files, not the photos.
Car: C
Default 12-08-2018, 07:44 PM
Hey Terry, I included the csv logs right beneath each photo.
Default 12-08-2018, 08:05 PM
Doesn't download. Sorry seems sort of a lot of work went in to it, was a total waste of your time. Just attach the CSV files to the post directly.
Car: C
Default 12-08-2018, 10:59 PM
Ok, uploaded directly:
  • Map 1 aggressive drive around
  • Map 1 WOT
  • Map 0 WOT
Btw Terry, let me know if you'd like me to do a proper log--3rd/4th gear WOT 2K to redline.
Thanks.
Car: C
Default 12-09-2018, 02:03 PM
Here is the log for map 1 4th gear WOT pull from 2,000 rpm
Default 12-09-2018, 02:09 PM
Set TMAP = 0 as boost is not logging accurately as you have it set on the MINI firmware.
Alternatively If you want to test the updated X2 firmware, load the attached, TMAP can stay at 1 (it will lock on that anyway), and then you have to select bit3 on the WMI page which is mislabeled "DTML WMI Input", turn that bit on and save, and log.
Car: C
Default 12-09-2018, 04:13 PM
Here you go Terry, same firmware, TMAP=0, Boost failsafe changed to 21psi.
Same 4th gear 2K rpm WOT pull
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 12-09-2018, 04:40 PM
Terry is this a firmware update for cas equipped with the b38 mini engine?
Default 12-10-2018, 09:55 PM
Good, looks as expected to me!
Car: C
Default 12-12-2018, 03:02 AM
Hi Terry,
Can you please check this log?
down pipe, Map 2, 91 octane.
4th gear WOT pull from 2,000 rpm.
Default 12-19-2018, 09:49 AM
Some timing drops but overall looks solid to me.
Car: C
Default 12-19-2018, 11:58 AM
Thank you Terry.
What can I do to fix the timing drop?
Still new to tuning and learning the ropes.
Default 12-19-2018, 03:02 PM
Not much. Add more octane, lower the boost. On pump grade fuels drops are to be expected. Excessive drops indicate too much boost for the fuel quality.
Car: C
Default 12-19-2018, 11:16 PM
Should i be looking at avg_ign for that or ign_1 / ign_4?
Also do you know of any resources to learn more about what each of the acronyms in the spreadsheet mean?
Default 12-20-2018, 11:50 AM
You'd look at actual ignition values. This specific is limited in what you can adjust so other than checking logs for obvious issues, there is limited benefit to doing any sort of in depth analysis. There just isn't much you can change.
Car: C
Default 12-20-2018, 01:07 PM
From the values you see, is this timing drop something you see often for those running down pipe+map 2 on 91 pump? Trying to gauge how significant the issue is as I understand timing drop could be detrimental to the engine...
Car: C
Default 12-27-2018, 03:33 PM
Hi Burger Tuning,
I did another pull in map 0, map 1, and map 2 from 4th gear.
Could you check if any adjustments need to be changed?
