after after is offline
Car: 2007 BMW e90 335i
Default Datalog - 09-21-2019, 04:21 AM
Upgraded turbos MMP 1K and 3.5 tmap
I used the JB4 hybrid turbo setup
Run is on 98 petrol
Fuel- it stage 3 LPFP
Single barrel shotgun HPFP
BMS DCI
BMS chargepipe
BMS PCV valve
JB4 and MHD BEF pump
2" silicone intakes
7.5" race intercooler
2" dwnpps
3.5" stainless steel street exhaust
Stage 3+ clutch
Aluminium flywheel
PR coils
NGK 97506 gapped
Catch can
INdex 12 injectors
Default 09-23-2019, 06:13 AM
Way overboosting
Lower FOL to 40 & relog
Default 09-23-2019, 07:03 AM
My Fuel Open Loop was already set to 40 when I did this log
I copied this
Default 09-29-2019, 12:34 PM
Way overboosting
My FOL is 40. should I change the FF?
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 09-29-2019, 02:49 PM
the first thing you should do is to set FF to 80 , then in FUD options set yes for "disable FF RPM gain" in the latest JB4 interface, and eventually select menu 4/2 (on the fly) and re-log , good luck
Do more with less !
