schmidty335i's Avatar
schmidty335i schmidty335i is offline
Car: 2012 335i 6mt
Default e92 cluster power out of car - 03-23-2019, 01:07 AM
does anyone know how to get the cluster powered up outside of the car? i tried to use a 12v 5 amp supply on pin 9 (positive) and pin 18 (negative). the needles move for a sec but the digital display never comes on.
2012 335i Msport E92 6mt M3 gauge cluster, FBO, Jb4 G5 iso w/ff, BMS meth kit, Stg2 LPFP, Fuel-it TBI, 3.5bar, Pure turbo w/ inlet pipe and GFB DV
Car: 2012 335i 6mt
Default 03-23-2019, 03:40 PM
i found out how. i am supplying it with 12v at 5amps i put positive on pin 9 and negative on pin 18. then you just push the mileage reset button and it turns on and will display your mileage on the cluster.
eligard eligard is offline
Car: 2007 335i
Default 04-23-2019, 07:28 PM
Good to hear you figured it out. Should be good future reference.
