joeybutts joeybutts is offline
Car: '07 e90 335i
Default Clutch slip? Diff issues? - 02-22-2019, 09:20 AM
So the last month or two intermittently I have been having an issue where I get spirited on the street, shift and the revs surge but the car isn't going anywhere. I don't smell clutch and it grabs fine from a dig. Not throwing any codes.
Any ideas on what it may be? Oddest sensation, almost like I'm in neutral but not...... It's a 6 speed with upgraded clutch and single mass fly....
schmidty335i's Avatar
schmidty335i schmidty335i is offline
Car: 2012 335i 6mt
Default 02-27-2019, 11:13 PM
Bump, I have had the EXACT same thing happen at the track, it usually happens in 3rd gear.
2012 335i Msport E92 6mt M3 gauge cluster, FBO, Jb4 G5 iso w/ff, BMS meth kit, Stg2 LPFP, Fuel-it TBI, 3.5bar, Pure turbo w/ inlet pipe and GFB DV
Car: '07 e90 335i
Default 02-28-2019, 02:55 AM
Likewise...3rd gear is generally when it happens....
Car: 2012 335i 6mt
Default 02-28-2019, 06:53 PM
i havent heard anything more on it, but if i were to just guess... the only thing it seems to be is the clutch slipping. might not do it on launch our in 2nd cause the tourqe isnt getting high enough like it does in 3rd. the part that confuses me though is the zero smell of a clutch burning. hopefully someone with more knowledge on the subject will chime in.
NA55 NA55 is offline
Default 03-01-2019, 12:19 PM
Sounds like the clutch..
Do a 4th gear pull and see if it does the same..
Car: '07 e90 335i
Default 03-05-2019, 03:41 PM
Thanks! Will attempt and report back.
Is 4ish years a typical life span for our cars? Clutch was replaced about 3.5 yrs ago....
Car: '07 e90 335i
Default 04-03-2019, 05:46 AM
Well..... No slip, and the symptom has disappeared.
Weird. I have no idea and am speechless.
Car: 2012 335i 6mt
Default 04-05-2019, 06:13 AM
same with mine lol.... I have not the slightest...
eligard eligard is offline
Car: 2007 335i
Default 04-21-2019, 05:21 PM
Also happened to buddy's a couple of times before and then disappeared.
Car: '07 e90 335i
Default 04-22-2019, 07:40 AM
Just happened again.
Is there a way to maybe figure it out from a log?
Car: 2007 335i
Default 04-22-2019, 06:49 PM
Not sure if it will show up on the log. Hope some more experts would chime in
beetle6986 beetle6986 is offline
Car: e90 335xi
Default 07-17-2019, 04:52 PM
I feel the same thing occasionally on hard shifts to 3rd gear for a split second, But most of the time itís fine. Im wonder if I should do the CDV delete.
08 335xi - 6MT. JB4 ISO, map7, MHD E85 BEF, E50, DCI, VRSF p1p3s, VRSF FMIC.
04 Cobra - Intake, Borla/Bassani exhaust, FMIC, pulley, tune.
