michael4702 michael4702 is offline
Default F10 m5 jb4 drive train malfunction - 01-27-2019, 03:06 AM
Hi all,
New jb4 install on an f10 m5 2012 with 55k.
99 ron fuel (uk)
Map 1... 5-7 pulls... all ok
Move to map 2... bang... drive train malfunction.
Move back to map 1.... bang drive train malfunction.
Move to map 4... all ok (mainly)
Monitored boost on map 4 with fuel gauge. Boost to half way on fuel gauge. All ok.
Back to map 1... as soon as boost wants to go over half way... bang drive train malfunction. I guess it went over half way When I first tried but was not monitoring.
Back to stock... read codes... misfire cylinder 8.
The jb4 is a new box the metal recatnagle one... I have the usb console cable but where do I plug it in ???
Also is my research correct....
New plugs
Gap plugs (to what for map 2). What is the gap for map 2 please?
New coil packs (or swap around and see if misfire moves with it?)
Worse case... injector...
My Target is map 2 as I have good fuel in the uk if the clutches can handle it...
Also need to pull logs when I work out how to connect the usb cable...
Seems map 2 killed something... and I guess in cylinder 8...
Thanks all !!!!
Default 01-27-2019, 09:11 PM
Step1:
Read the code to see what it is.
Step2:
Post a JB4 log of a run so we can see if anything is wrong with the tuning side
