(#101)
Audisom Audisom is offline
Car: 2013 S6
Default 09-06-2019, 01:33 PM
So,
1 = 3psi added over stock
2 = 2psi added over stock
3 = 1psi added over stock
4 = 0psi added over stock?
Default 09-06-2019, 01:55 PM
Originally Posted by Audisom
So,
correct.
Default 09-07-2019, 12:12 PM
So map 2 is 5psi over stock right.
0 = 5psi added per base map2 or essentially disabled
1 = 3psi added
2 = 2psi added
3 = 1psi added
4 = 0psi added
Is this look right?
So you can’t request 4?
I am confused
Sorry quoted the wrong post earlier.
0 will disable the feature.
1 cuts 1psi so total 4
2 cuts 2psi so total 3
3 cuts 3psi so total 2 etc.
So lets say if you using a map 6 with peak of 6 and want to extra boost in 1st you set it to 6.
Chio4 Chio4 is offline
Car: S6
Default 09-17-2019, 12:30 PM
I have noticed running map 2 93 oct that if I am going about 45-50 MPH and hit there is A delay and almost like it bogs down. anyone else notice this? I have not run logs on this yet
Default 09-17-2019, 02:36 PM
Can you test if it does this in map 1 as well.
Car: S6
Default 09-17-2019, 07:26 PM
I will log both map 1 and 2 for you
chrislakt chrislakt is offline
Car: 2016 Audi S6
Default 09-26-2019, 04:40 AM
Installed mine today with out a hitch, all i can say i wow.
The car feels so much stronger compared to stock. I owned the car since new and the JB4 has completely transformed it into a beast.
I'm in Australia, so we are right hand drive and had to install the JB4 between the positive terminal and the intake, it secured well and all the cable lengths reached fine.
I was previously using another piggy back type though the JB4 smashed it out of the ball park, i'm not sure what it was doing though JB4 map 1 is much much stronger.
I've emailed through some logs so i'd be interested to hear your feedback.
2016 Audi S6
Sydney Aus
Default 09-26-2019, 05:32 AM
Happy you satisfied. How did you route the OBD cable?
Car: 2016 Audi S6
Default 09-26-2019, 06:14 AM
The easy way via the door, when I have more time Iíll look for way to run the OBD cable through the firewall.
2016 Audi S6
Sydney Aus
Car: 2013 S6
Default 10-13-2019, 07:11 AM
Is there a update in the works?
Default 10-14-2019, 05:32 AM
We working on a few cars that run higher octane fuel fitting our boost control module. The barrier with this is going to be fitment as the radiator needs to be leaned forward and cars with distance control wont be able to do this unless they go through major effort for the install.
