335xiRT1 335xiRT1 is offline
Default 12-11-2017, 03:01 PM
Originally Posted by Bullitt1841
Have you been able to reliably tune with TBI and no ethanol? That would be a good starting point.
This B58 engine and DME are completely different and are presenting a lot of problems that were not present in the N54 and N55. Unfortunately, we can't carry over all of our tuning knowledge directly from those platforms. So don't be surprised if we can't figure **** out.
Still working on it....it snowed here over the weekend so gonna do some more testing tommorow.
Iíll try running it with straight 93 see how it goes on my next fill up.
2017 340i JB4/ BB TBi/ intake
Juan_BIGBOOST_TURBO's Avatar
Juan_BIGBOOST_TURBO Juan_BIGBOOST_TURBO is offline
Default 12-11-2017, 03:23 PM
Originally Posted by JB4OFF
Nitrous fogger my mistake. It has poor atomization property. It shoots fuel out like a squirt gun. Because Ryanís car was a disaster and undrivable with nearly 7lbs of overboosting and two turbo revisionís. He couldnít WOT the car without an issue. Hence why the product hasnt been tested throughly. Even Terry said the turbo is too aggressive for the car. Iím not gonna argue with facts. Thatís why Ryan returned the turbo after 8weeks of a headaches. Not saying you have a bad product but itís rushed imho.
When he installed the 64mm turbo the car stopped overboosting, however with a DA of -1100 FT it is imposible to correctly tune a car. I am working now on another solution for it. I did refunded him his money. The issue started due to the cold weather. Even stock cars are having the same issue with this weather. Ryan is keeping the kit we will get him the new manifold and wastegate that will for sure solve the issue with the boost control.
webpage: bigboostusa.com
BigBoost's car: BMW M240i
Stage 3.4 turbo
Current B58 record holder: Currently: 822 WHP
4.8 100-200
10.85 @ 135 1/4 mile
Daily Driver: BMW M235i
BBT stage 3.3 turbo
Default 12-11-2017, 05:17 PM
I also thought about buying dual meth nozzles and hooking the TBI kit to that because they do atomize better than the nitrous fogger.
Default 12-11-2017, 05:19 PM
If customers want we can develop this and replace the current foggers in the already sold TBIs.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 12-11-2017, 05:24 PM
Did you test what I told you? Or is it snowing still?
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
JB4OFF JB4OFF is offline
Car: 340i
Default 12-11-2017, 05:47 PM
I would highly recommend cm nozzles instead using a nos fogger. The only nitrous company that makes good fuel foggers is nitrous outlet and wizards of nos.
Default 12-11-2017, 06:42 PM
After watching some videos i would deff like to swap out the NOS fogger to meth nozzle. Atomization is a lot better with meth nozzle.
Iím gonna try those settings tommorow and post some new logs.
jalkster jalkster is offline
Car: 340i M-Sport
Default 12-12-2017, 05:07 AM
Count me in on that. Just seems like a better approach.
340i 8AT DME Stage 2 | JB4 | AP Intake | ER ** | Meisterschaft GTC | Ohlins R&T | Ground Control Camber Plates | MP LSD | 437M | RE-71R
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 12-12-2017, 10:07 AM
Iíve had this car for 2 years. I know what works and what doesnít. My friend Ryan also had the tbi kit from BB. And he took it off. Aside from that if you wanna keep playing with nitrous solenoids for fuel. Be my guest. Iím not gonna **** talk Bigboost but they rush things with not much thought.
Ah, didn't realize you were a 2-year expert.
I wasn't talking specifically about the bigboost kit for B58, have no knowledge/interest in them. I have the Fuel-It TBI for N54 so very familiar with how/when TBI's operate.
Just your comment that TBI wouldn't work because of IPW. Saying that shows you have a misunderstanding of the fuel system. Trims (reflection of how much fuel DME commands to injectors) will normally go down with TBI active. If not you likely have it installed wrong or adjusted poorly.
2017 AMG C63 -JB4
2009 535i - 548whp - sold
Car: 340i
Default 12-12-2017, 10:46 AM
Itís more complicated on the b58. Iíve spoken to Steve from fuel it and weíre gonna need to change a few things with a backend flash or trick a few sensors on the b58 to use its fuel system for additional fuel. The car wants to maintain a certain afr and when more fuel gets dumped into it it seems as if the dmebt gets wonky from what he explained to me.
Default 12-12-2017, 12:44 PM
Iím deff noticing that.
LessIsMore's Avatar
Inner Circle Member
Default 12-12-2017, 01:19 PM
That sucks.
2017 AMG C63 -JB4
Bullitt1841's Avatar
Default 12-22-2017, 04:57 PM
Updates?
Default 12-22-2017, 07:16 PM
I stopped putting in e85
Now
I switched the nos fogger to dual meth nozzles.
It seems to be to much fuel. So I’m going down to 1 meth nozzle.
Also took off the d@wnpipe
The car is fighting the extra fuel.
Timing is zero out.
The trims are goin down to 9
Almost like the dme sees the extra fuel and is spraying less fuel through the injectors.
Default 12-24-2017, 12:17 PM
Now
It seems to be to much fuel. So Iím going down to 1 meth nozzle.
Timing is zero out.
Got any logs to post?
Default 12-24-2017, 09:22 PM
No they were bad.
I didnít even bother saving them.
Itís fustrating.
I will do some more testing after the holiday and report with hopefully some good news.
Default 12-25-2017, 12:24 AM
No they were bad.
Itís fustrating.
Yeah, the reason I added meth was because I didn't think TBI would be the answer on this platform. We might be able to figure out some tuning with the JB4, but it might not be as good as with meth.
Default 01-13-2018, 09:38 PM
This thread sure went quiet fast. Nobody is having success with the kit?
Default 01-13-2018, 10:33 PM
Iím using the newest update Iíll post some logs of my progress.
Weather has been bad here in NY lately.
Default 01-13-2018, 10:34 PM
Were you able to get timing up?
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 02-01-2018, 09:08 PM
update......
its been a while, ive been making a bunch of changes and doing tons of datalogs to sort out this tbi kit. so far logs look decent I think, considering its been 30 degrees here in NY. Don't think bigboost put much thought into this kit for stock turbo, he wasn't much help tuning it.
here is some things ive learned along the way, along with some notes about the kit:
You have to cut the vacuum line on top of the intake manifold to get boost pressure for hobbs switch.
the tee I got with the kit was the wrong size, told BB, was never sent a new one, but was easy fix from local home depot
I adjusted the hobbs switch to go off at 13psi
I replaced the single nos fogger to a DO7 meth nozzle for better atomization
the stock d@wnpipe had to go back on the DME couldn't handle the extra boost surge with the aftermarket d@wnpipe, I was getting throttle closures
the car hates e85, I'm running straight 93
FF wires are not needed, makes it harder to tune
t12 firmware helped out a lot with the extra boost
here are datalogs, Map 0,1,2 are without TBi,
map 6 is with TBi
I'm able to run more boost while keeping afr down, timing seems low but its been real cold here and dme bt are high, so low timing is suspected
Default 02-01-2018, 10:22 PM
map 6 is with TBi
Your Map 6 log looks pretty bad. It's not necessarily unsafe (since your AFR is rich and stable after 5k RPM), but it just looks bad regarding Boost, DME BT, and AFR. You're getting a huge throttle closure at 3.5k RPM. I usually see this when I haven't adapted enough runs, or if I'm not running enough boost.
I would try adapting with more runs first, then if they seem safe, try running 1-2 PSI more.
You're running EWG wires, correct?
Default 02-02-2018, 02:09 AM
Like I said they look decent. I’m constantly making smal adjustments. I’ll post up more logs.
Yes running EWG
Default 02-02-2018, 06:00 AM
update......
map 6 is with TBi
You didn't get you the new Tee because I'm shipping you the new vacuum line and the billet aluminum map sensor spacer to get boost reading from there.
Stage 3.4 turbo
4.8 100-200
BBT stage 3.3 turbo
Default 02-02-2018, 06:07 AM
Also just as an update we are now shipping all TBI kits with a single 7 GPH methanol injection nozzle instead of the NOS fogger. Also there is no need to cut the vacuum line now because we provide the map sensor spacer the get boost pressure from there.
