(#551)
FeldiSan FeldiSan is offline
Car: VW Golf 7 R
Default 09-21-2019, 08:13 AM
The fault is per below. Something to do with the engine cooling system. Seems a dealer visit will be needed for this as it might relate to the failing water pumps.
15462 :
Engine Coolant Bypass Valve Control Circuit/Open
P2681
Thanks for this information. Is there a library for these Fould codes that I look for these codes when I have a problem again?
Greetings Micha
Default 09-21-2019, 09:51 AM
Greetings Micha
Best to email me for them. The app will have them added on one of the updates.
The list is very comprehensive and has taken years to compile so its not something we release to public as many competing diagnostic products don't have full translations.
Oput Oput is offline
Car: Audi S3 2016
Default 09-22-2019, 03:13 PM
Your link from top post returns error 404:
Directions on installing the interface and connecting to your JB can be found here http://www.n54tech.com/forums/showpo...21&postcount=1
And I can not start existing app on my hdd, it returns: You cannot start application JB4 from this location because it is alredy installed from a different location.
Can you help me to fix these issues?
Default 09-22-2019, 03:54 PM
Search the JB4 file and remove all that is found and install again.
Tiguan_2_Berlin Tiguan_2_Berlin is offline
Car: Tiguan 2 AD1 2.0 TSI
Default 09-23-2019, 01:26 AM
If its a 162kw/220ps version then try load the firmware again making sure you not connected to any other bluetooth device.
If its the lower power version it is the wrong firmware and you need to load firmware from Gen3B section.
Its working now. Thanks for your prompt support! Yes, bluetooth was also connected to navi, so i disconnected it.
Cougar95900 Cougar95900 is offline
Car: 19 Jetta GLI
Default 09-25-2019, 11:04 AM
Hey guys, I am new here.. I recently purchased a new GLI and took my old JB1 Rev1 off my old 16 GTI, and installed it onto my GLI.. It worked just fine and I only ever used Map 1 on the JB1. I just bought the JB4 upgrade board and installed it. I used the White wire from my O2 sensor since i have the black 6 pin connector sensor.
I see all of the different Octane ratings listed on the posts here, and I am from Arizona, So the premium fuel here is listed as 91 octane. ( (R+M)/2 )
My question is whether or not i can use any of the other maps with that fuel since that is all that i can get here. The car is stock other than a drop in K&N filter.
Thank you for any input can provide.
Default 09-25-2019, 12:13 PM
Rule of thumb is map 1 in summer especially since its hot there. In the colder month you can check if map 2 is ok via the logs.
If you got ethanol available you can mix in 3gal to a full tank and go up to map 3.
Car: VW Golf 7 R
Default 09-26-2019, 09:01 PM
Hi George,
Yes it was the waterpump with thermo control unit. After repair car without fouldcodes. Thanks
Greetings Micha
Default 09-27-2019, 08:38 AM
Hi George,
Greetings Micha
Happy its sorted.
Tloutas Tloutas is offline
Car: Golf MK7 R
Default 09-28-2019, 07:00 AM
Hey there sorry if this has been answered but I need to ask.
I have a stock mk7 golf r 6speed dsg and always using 98octane fuel.
Am I able to use map 3 and map 4?
I live in Australia and we are coming into our warmer months so just making sure that these will still be safe to use during summer.
Thanks in advance
Default 09-28-2019, 10:45 AM
Thanks in advance
For a 6 speed map 3 is good on 98ron. If it goes past 35C switch to map 4 for good measure.
TSI 1.8T Jasper's Avatar
TSI 1.8T Jasper TSI 1.8T Jasper is offline
Car: 2018 mk7.5 1.8T m/t
Default 09-28-2019, 05:24 PM
Hello
Question , just installed a CTS down pipe ( high flow *** ) on my 1.8T , currently running map2 93 and all good lots of extra mid-range added from down pipe but find maybe could use bit more in the top end .
Now George you have mention before that map3 on a 1.8t wont do well cos it lucks top end and will straggle ., will the down pipe help and would the map3 be now ok , if not that is fine just would like to see and ask before any changes done.
so mods are intake ,down pipe and throttle adjustment with obd11 and on map2 right now 93
thanks
Default 09-30-2019, 06:07 AM
Originally Posted by TSI 1.8T Jasper
Hello
thanks
The issue is flow related on the small Is12 turbo and adding 6 at the top is virtually pointless. With Is12 we taper the top to 4 maximum.
Default 09-30-2019, 09:38 AM
Thanks for a quick reply,,so basically leave it as is and if anything go to is20 .
Thanks again
SOLID FARRELL SOLID FARRELL is offline
Car: Mk7.5 GTI Rabbit Edition
Default 10-01-2019, 01:56 PM
George,
Any cases where JB4 causes code P050A to throw an engine light?
... or is this a unrelated warranty issue and if so would this one require (or recommended) removal of the JB4 prior to visit.
I cleared it once some weeks ago and filled up with fresh 93 then ran Map 0 without issue, or at least it would appear.
Today I left Map 2 loaded and got the fault after using/starting the vehicle a few times.
2019 GTI Rabbit Edition DSG with less than 6,000-miles.
K&N panel filter (mod)
300rms amp/sub (system draw)
Texas heat/humidity (weather conditions)
2 x MK7.5 Golf GTI Rabbit Edition (DSG) + JB4
Instagram
Default 10-01-2019, 04:12 PM
Originally Posted by SOLID FARRELL
George,
Common Problems That Trigger the P050A Code
Clogged air filter
Idle Air Control (IAC) valve failure
Mass Air Flow (MAF) sensor failure
Powertrain Control Module (PCM) failure
Throttle body assembly failure
Wiring issue
Default 10-02-2019, 12:16 PM
George,
Try get a read of the fault using the JB4 and let me know what it shows.
Default 10-02-2019, 01:00 PM
Hi George,
I had cleared one on September 10th when it first occured using the new Map 3 a short while after update.
Of course, second/current MIL was once I left Map 2 active.
Today I ran with the JB4 was set to 0 with the OBD unplugged and a fresh tank of 93.
The MIL was on earlier but off when I got in the car as of this afternoon and has remained off between restarts so far.
JB4
3AE8 - No Descrition Found
Schwaben VAG Scan Tool
stored
P050A/$07E8 - Cold Start Idle Air Control System Performance
pending
none
permanent
none
Any ideas?
Instagram
Russedwards_82 Russedwards_82 is offline
Car: 2014 Golf R
Default TCU tune advice - 10-02-2019, 07:46 PM
New to forum.
Have had my JB4 for over 12 months, currently running map 3 with BMS intake/inlet. Will be having CTS turbo catted ** and Res delete done next week.
Is the cost of a DSG tune ($900) worth the benefits for a better drive? Local installer reluctant to do for me as he is trying to bundle it up with a ECU & DSG tune. Fairly happy with my JB4 and also have early model turbo so can't push the ECU tune too hard anyway.
Any advice will be appreciated!
Default 10-03-2019, 07:32 AM
George,
It sounds like there is a vacuum leak of some kind affecting the idle. If you do take it in its always good practice to remove it.
Default 10-08-2019, 11:14 AM
Anyone dyno the latest Map 3 yet?
Been curious how the feedback and results are.
Instagram
Default 10-12-2019, 08:11 AM
A few mentions of Map3 for hot weather
- is it also a good option during the winter?
Cold fronts have been hitting Texas this month with peak temps dropping as low as 50-60F during the day and winter weather approaches so the question crossed my mind lately.
Instagram
Default 10-14-2019, 05:34 AM
No concerns in cold weather.
ZuMBLe ZuMBLe is offline
Car: VW Alltrack
Default 10-16-2019, 07:14 PM
What can the Fuel-IT with JB4 do on the VW platform? What are the possibilities?! It would be great if I could get the JB4 to add boost based of ethanol reading, or dial back boost etc.
s3s3s3 s3s3s3 is offline
Car: 2016 S3
Default 10-17-2019, 08:00 AM
I am experiencing what seems like a lot of misfiring/jerky acceleration on map 1, stock 2016 s3 with 98 octane. Can anyone help me out?
https://***********/u/s3s3s3/wtf?log...-9-11-14-18-19
