5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default N55 common issues? - 04-06-2017, 04:51 PM
Hey guys, just got a 2011 535i with the N55..
Was wondering what are the common issues to look out for on this engine..
Ialready did the water pump and t-stat and Coils/plugs.
How robust is the HPFP and the injectors on this engine?
Anything else to look for?
2014 F10 535i N55 PWG
Stoolz Stoolz is offline
Car: 11 135i
Default 04-08-2017, 04:54 PM
Chargepipe.
They are plastic and break.
Mine broke and sucked a piece into the throttle body.
Lucky for me it got stuck there.
primamateria's Avatar
primamateria primamateria is offline
Car: 11' 335i xDrive e90
Default 04-09-2017, 07:10 AM
As Stoolz said - chargepipe.
Only other thing that I replaced due to being faulty was the oil filter housing gasket; started leaking pretty good. Cheap fix though - new gasket - $20 or so.
I replaced the coils and did new plugs and a new trans pan/gasket with new ZF trans oil; changed out the rear diff fluid also. These things were done just as preventative maintenance.
Surprisingly I'm still on the stock HPFP @ 100k+.
11' 335i xDrive e90,
JB4 ISO Map 7 @ 20psi, ISO_14 Firmware, BMS/MHD e85 BEF, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF **, VRSF 7in. FMIC,
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 04-10-2017, 12:34 AM
100k+ miles or kms !? Im at 85k miles still on stock hpfp too but getting hpfp shadow codes sometimes nowadays
Btw have you ever 1/4 mile ?
Oh and OP its more about regular maintenance !
Plugs every 20k if tuned 50k if not
Diff oil
Tc oil if x drive
Oil gasket
Belt tensionner/idler pulley
Coolant leaks
Coils
At oil
And yeah change that chargepipe asap
Default 04-10-2017, 01:44 AM
Diff oil
Tc oil if x drive
Oil gasket
Coolant leaks
Coils
At oil
Oh sorry should've specified, 100k miles. I'm just waiting for the day it craps out on me. ;p
And nah, haven't yet. Plan to this summer for sure.
Default 04-10-2017, 05:00 AM
aight keep me posted ! having long cranks or any signs that its going out ?
335i x-drive 2011 e90 n55
ER chargepipe | performance line d.p | 90/10 bms meth kit | K&N drop in | JB4 + MHD pump flash | xhp stage 3 flash | PURE STAGE 2 turbo
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 04-11-2017, 07:21 AM
Originally Posted by Stoolz
Chargepipe.
O wow ok, chargepipe first on the list then! Thanks
Thanks! Not bad.. I was a long time and numerous n54 owner and this n55 engine looks to be WAY more reliable.. great news
Diff oil
Tc oil if x drive
Oil gasket
Coolant leaks
Coils
At oil
Awesome sounds like basic stuff nothing out of the ordinary..
Seems the fuel injector and hpfp is mostly cured from the n54 days..
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 04-16-2017, 12:45 PM
how about the water pumps?
Ichiban Ichiban is offline
Car: 135i DCT
Default 04-17-2017, 08:38 AM
waterpump needs replacing too, regardless of your year N55.
Design flaws from BMW. They last roughly 50k miles.
Default 04-18-2017, 01:41 AM
This.
I forgot to mention in the above post - I did replace the thermostat and coolant/water pump. My pump took a s^&* probably about 20k miles into having the car.
Torquejunkie Torquejunkie is offline
Car: 135i N55
Default 05-01-2017, 05:24 AM
Chargepipe.
Hi Bimmer junkies,
I'm new my name is Guido and I bourgth a 135i E82 coupe with the N55 engine.
I've read that you changed the chargepipe. Do you guys have a Part-No. that I'm able to buy replacement.
Don't what to blow the engine because of BMW did a mistake in engineering dept.
Sorry for my poor english.
Greets from Germany
orteeze orteeze is offline
Car: 08' 335i
Default 05-01-2017, 06:33 AM
Originally Posted by Torquejunkie
Hi Bimmer junkies,
Greets from Germany
Buy an aftermarket metal charge pipe and you will never have to worry about it again.
Cobb
VRSF
Make sure you select N55 motor and specify your year make and model.
E90 LCI M Sport
Car: 135i N55
Default 05-01-2017, 12:22 PM
Cobb
VRSF
Thanks Orteeze,
I'll check Tuning shops here in Germany.
Br
Guido
Oil couldn't cause the issue... It's no Oil in the engine...
Kurler Kurler is offline
Car: 2011 BMW E93 335i LCI
Default 05-02-2017, 03:01 PM
I had crank seal, dct sump gasket and oil filter housing gasket leak at 46k kms
Car: 135i N55
Default 05-03-2017, 12:01 PM
Hi Orteeze,
Thanks, I've found a dealer who sell Burger parts...
I'll check the existing charge pipe. If it's made from plastic I'll replace it.
Br
Guido
