primamateria's Avatar
primamateria primamateria is offline
Car: 11' 335i xDrive e90
Default Timing/Knock Correction Setup for JB4 Logging - 04-03-2017, 01:55 AM
Picked this up from another thread and was wondering what's needed in the settings/set-up of the JB4 to be able to log knock corrections?
You can also setup the JB4 to show the knock correction independent of the timing values if you prefer.
11' 335i xDrive e90,
JB4 ISO Map 7 @ 20psi, ISO_14 Firmware, BMS/MHD e85 BEF, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF DP, VRSF 7in. FMIC,
Default 04-04-2017, 03:31 PM
On your N55, timing is already logged, corrections display as timing drops. Not sure if you can enter a value of 1 under 6-cycl timing or not...try it and see.
Default 04-04-2017, 04:01 PM
Cool Steve, thanks. I'll give the '1' value a shot.
Default 04-05-2017, 08:09 PM
