Default No Fly Zone 4/1/17 Results Thread - 04-01-2017, 06:49 PM
Just got back from another great day of 1/2 racing at NFZ. Compared to SS you can take as many runs as you want, which makes it great for testing and tuning, but the timing equipment is a bit flaky. And the track is a little longer than 1/2 mile if you start from a dig.
Payam raced our M5 and managed a best of ~160mph from a roll.
Jason raced our PureS2 M3 and hit a best of 163mph from a dig.
Adam raced the Z06 most of the day and ran a best of ~161mph from a dig.
I took around 10 runs in our Pure S2 E92 trying to sort out problems and managed a best of ~156mph from a roll. Adam managed to get a ~159mph trap from it although I suspect the timing equipment was off that run. More on this car in the next post. After I tired of it I took a few runs with the Z06 and ran ~158mph from a roll, ~160mph from a dig, including a narrow loss to Fuel-ITs M4.
Steve brought the Fuel-IT M4 out from AZ and managed an impressive 165mph from a roll with more in it. Turns out somehow his back end flash had the speed limiter left on it... He's run 170mph+ before at the same track so we expect better traps next time from it.
Vargas was also out and managed an impressive 172mph with their N54. Nice to see the N54 bar inching higher.
I'll add some more photos and videos as time permits.
Default 04-01-2017, 06:52 PM
With our E92 it's curse continues.
During the first run somehow wiring for the rear o2 sensor fell out under the car and ground apart a wire. We patched it back together.
After another run or two the under-tray partially ripped and was dragging along at 150mph... Had to remove it at the track and toss it, it's cracked apart.
Despite having really conservative timing (8 degrees peak), on straight E85, timing was completely flat-lining each shift unless I desensitized the knock sensors. Upon doing that timing and traps improved.
After getting timing sorted I noticed the fuel trim variance which was at around 20% grew to around 50%. No idea why. There are no o2 faults stored, tried resetting adaptions, etc. Acting like an oring is blown out again but I really doubt it. Maybe defective primary o2 sensors. The variance grew throughout the day. Shrug. (note I added a setting to disable the JB4 fuel trim variance safety)
And to top it off towards the end of the day it started throwing VANOS faults.
I'm so done with this POS! On the plus side the 335is clutch held well and at 26psi it was running almost on par with the Z06.
Car: F06 N55 640i Gran Coupe
Default 04-02-2017, 05:41 AM
Terry, Video pls 👍
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS ** n FULL Custom Exhaust
Custom BC forge 18/17 set up
Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
Default 04-02-2017, 07:38 AM
Man what a great time yesterday! Fun turn out from the BMS crew, most of the cars ran solid, and didn't seem like anything really broke. Timing equipment was a little flaky for sure, hopefully they can get that fixed next time around. As always tons of fun!
Vargas Turbocharger Technologies
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
chadillac2000's Avatar
Car: 2008 535i
Default 04-02-2017, 08:56 AM
Any videos of the 172MPH run? That's moving!
Here is a video of our Z06 getting smoked by Fuel-Its M4.
Default 04-02-2017, 09:15 AM
we ran 172 four times I believe. I have a video of one of the runs. We raced a drag prepped 240SX. Chris will be posting a full breakdown of the day, with all slips, photos, and videos.
www.Vargasturbo.com
Default 04-02-2017, 09:35 AM
It was a pretty painless and fun day! I still can't believe you changed and coded your fuel injectors in the pits
Default 04-02-2017, 11:27 AM
Hahaha. I've changed so many injectors its like swapping plugs at this point..
www.Vargasturbo.com
Ne1man35's Avatar
Ne1man35 Ne1man35 is offline
Car: 2008 135i fully loaded
Default 04-02-2017, 11:49 AM
wow that event looks like it must have been awesome. After seeing that 172 pass from VTT and seeing the new stuff they have been coming out with for the N54, The N54 seems to really be pushing boundaries. Id like to hear a vendors opinion of a few things:
-Do you guys think we will see 1000whp from an N54 anytime soon?
-If Not, Where do you all think the limit of the N54 is?
-Is there lots more potential for N54's to be had in the next couple years or is it close to its max?
-What N54 car in your opinion has the most traction or can be build to have the most traction for those high WHP levels? If money wasn't a factor at all, I can imagine how sick a 1m would be built up to this level because it was a wider body for wider tires.
My 135i probably won't ever be built up the level even of these cars and my long term goal is only FBO + GC Lites + LSD + other goodies topping off around 550-600whp Daily Driver. But Im very exciting to see whats happening with the N54 car from VTT pushing 800+ on twins What do you guys think is next?
2008 135i M-sport fully loaded | Mods in progress | Maintenance and detail freak | Subscribe to my YouTube Channel!
https://www.youtube.com/channel/UCNP...WOEG9BMruHqHyg
pits200 pits200 is offline
Default 04-02-2017, 12:20 PM
Nice runs Terry and Tony.
Tony, was the 172 run with di only or a little port too?
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
administartor
Car: M340i,X5,Raptor,C7 ZR1
Default 04-02-2017, 12:45 PM
I got 28 runs in. Minimal waiting in line. Not too hot out. It was a blast.
Default 04-02-2017, 05:29 PM
I would say about 90% DI only with 10% port on top. I might be able to get away with DI only, but I like the added safety. Plus the pops sound cool when you shift with your foot to the floor...
www.Vargasturbo.com
alnk1015 alnk1015 is offline
Car: 2007 335i e90
Default 04-02-2017, 06:51 PM
Pops?
Default 04-02-2017, 06:54 PM
Yes, the unburnt fuel igniting after a no lift shift. The thing uninformed people says hurts your motor.
www.Vargasturbo.com
Default 04-02-2017, 07:37 PM
FYI I no lift shifted every run on the E92 which is heavily dependent on port injection for fueling and got almost no popping out the exhaust...
Cortez08 Cortez08 is offline
Car: 2003 M5 2008 335xi
Default 04-03-2017, 01:15 AM
Is the m5 on stock turbos?
primamateria's Avatar
primamateria primamateria is offline
Car: 11' 335i xDrive e90
Default 04-03-2017, 01:33 AM
Good stuff dudes. Looks like a good time.
That Fuel-It M4 though..
11' 335i xDrive e90,
JB4 ISO Map 7 @ 20psi, ISO_14 Firmware, BMS/MHD e85 BEF, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF **, VRSF 7in. FMIC,
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 04-03-2017, 03:19 AM
If that's super lean isn't there a chance of overheating the turbines etc?
I disable the mhd popping feature on my flash just to be safe.
Default 04-03-2017, 06:12 AM
The big difference to me is, that dumb burbling thing is basically just dumping fuel to get pops, and ****, when you get the NLS pop, its a single pop. I would love to say its also helping keeping the turbine speed up, but I doubt its really having any effect.
www.Vargasturbo.com
Default 04-03-2017, 07:01 AM
Yup! Mods are: BMS intake and charge pipe, BMS dual cm 10 meth kit, JB4+Bcm, and upgraded dct clutch packs.
The car is so fast and drama-free, Im trying to find a manual one for myself lol.
suspenceful's Avatar
Car: 2008 BSM 135i
Default 04-03-2017, 08:08 AM
Nice! I've gone to two of their Midwest events.
Best was 156mph from a dig on stock turbos.
Default 04-03-2017, 08:16 AM
Nice!
On traps in general what I've found is you can't really compare runway to runway or even different events at the same runway, as for some reason they often vary wildly. For example last time at this event Ando ran 163mph in our Z06... We added ~60whp this time around, but it ran 160mph. A few others mentioned they were 4-5mph slower than last event same track too.
Maybe a VBOX file with a validated 1/2 mile from a dig would be a good way to compare different tracks/days.
hydra hydra is offline
Car: 2010 135i
Default 04-03-2017, 09:23 AM
I'm guessing this is down to wind speed/direction being more a factor at higher speeds? Assuming ambient conditions are similar of course...
Default 04-03-2017, 09:28 AM
I think the tracks are different lengths, different rules are enforced (e.g. allowed to start ~1/2 mile from as fast as you can, or from 0mph), and the timing equipment is not always accurately implemented. Net/net the best (and most fun!) way to compare is with side by side races.
