LostMarine's Avatar
LostMarine LostMarine is offline
Car: E92 DCT ///M
Default I may be making a comeback- so help me out - 01-10-2017, 10:38 AM
Im about to buy another DD beater car, and i thought to myself, a 335xi nearly perfectly fits my criteria
-cheap
-AWD
-not too far out of style
So ill probably take my brothers E92 335xi 6MT off his hands
Whats the latest and greatest for best usable HP? I will NOT be running meth, just 93 octane
Im thinking:
JB4 (of course)
Air intakes
Turbo Inlets
**'s
whats a realistic HP for such a setup?
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 01-10-2017, 10:44 AM
350-375 probably..
MR F30 335i - MSport - Stock AF
Stucks Stucks is offline
Default 01-10-2017, 10:46 AM
-cheap
-AWD
Im thinking:
JB4 (of course)
Air intakes
Turbo Inlets
**'s
Add a fmic to that list and you could prob see around 400-410awhp with that setup on pump 93. add e85 mixtures and things could be pushed to 450-460awhp. then again, a lot depends on what type of dyno you use and other variables like temperature, ect ect.
Current: 2008 e92 335i coupe.
LostMarine's Avatar
Car: E92 DCT ///M
Default 01-10-2017, 10:50 AM
ok, with FMIC, charge pipe, and add stock frame snails, whats the best HP known for 93 octane only?
Default 01-10-2017, 10:59 AM
Stock frame....lol as in upgraded stock frame or "oem from the factory" turbos? If upgraded stock frame, there are a couple of cars that have dyno'd over 500whp on straight pump 93. One that comes to mind did so on regular 15t size rb turbos.
Default 01-10-2017, 11:00 AM
It's rough on 93 only. Maybe 475whp? You can make more but it gets a little sketchy long term.
No E85 access? With the new port injection kits out that is the go-to fueling. Then no issues up to 600whp on hybrids.
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 01-11-2017, 07:55 AM
Don't forget MHD
LostMarine's Avatar
Car: E92 DCT ///M
Default 01-11-2017, 04:11 PM
is that regardless of turbo's? Im really, REALLY trying to keep this "reliable" daily driver only duty
I do have access to E85, but not convenient for weekly fill ups
Default 01-11-2017, 05:23 PM
No, you guys are smoking crack. Stock turbos and 93 octane. You'll see about 400 whp at most, and that's because inlets will allow the turbos to peak at around 18-19 psi. They add more head room, about 2-3 psi more on stock snails.
Torque will be a little higher, low 400s. But that's plenty for an AWD DD. You will enjoy it.
If you decide to experiment w e40 you can get to 450 whp on that set-up.
Aaron Aaron is offline
Car: 335is
Default 01-11-2017, 07:06 PM
MHD > JB4
Car: 09 E92 335i
Default 01-11-2017, 07:15 PM
Exactly, stock snail, no matter how you tune it, the whp will drop off like a rock past 6k rpm. Sure, inlet will squeeze out a few more psi at the top end, but the most you can make reliably is around 400whp.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 01-11-2017, 07:32 PM
Buy a FMIC, ********* *** and do MHD stage 2 and be done
09 335 - 6266
07 335i - 6870, E85 - SOLD
Default 01-11-2017, 09:58 PM
That is figuring hybrid turbos. Subtract 20-40whp for stock ones on 93. Pretty much all the hybrids can swing 600whp on E85. Some up to 700whp when you start to break factory pistons. If you want to spend more money on a flex fuel sensor (not much more work to install if already doing PI) then the JB4 can can adjust its mapping based on your actual mix.
For just 93 I think you won't be thrilled with the platform but if you have something that can at least use E85 when you have access, it's the sort of power you're used to.
klipseracer klipseracer is offline
Default 01-11-2017, 11:09 PM
Welcome back LM. I made a comeback also in September. But I'm not being a pssy, I bought a ST kit.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 01-12-2017, 09:43 AM
370 whp with that setup.
Fmic for lower IATs for longer.
mountie mountie is offline
Car: AW 135i
Default 01-14-2017, 02:19 PM
This is my 135i dyno on stock turbos and meth injection. Also, FMIC, **'s, JB4.
