Anytyme's Avatar
Anytyme Anytyme is offline
Car: 2011 335I
Default 04-04-2016, 01:08 PM
You misunderstood me. I have a 2011 N55 E series 6AT. I'm swapping it to manual. So far I have a 2009 transmission, pedal assembly, BMS SSK, and Spec stage 3 clutch.
N55 World Record 650whp 571tq
2011 N55 335I, VM Top Mount Kit, PTE 6266 Gen 2, JB4 AMS Fmic, ER CP with BOV, FuelIt Stg3 LPFP, , PI Platinum Kit.
nick380 nick380 is offline
Car: 2007 335i Sedan
Default 04-04-2016, 03:20 PM
Gotcha! yea my bad i thought you were saying autos were hard to find in your area. For your year check out the diff and make sure you don't need a new pumpkin (changes were made after 08 for manuals(smaller pumpkin)) may require new driveshaft length. Also 2011 is N55, so make sure your transmission has the pilot bearing shaft not the flywheel! aka check for a pilot bearing inside the input shaft of transmission. it won't have it Check this thread for details:
http://www.1addicts.com/forums/showthread.php?t=1138684
2007 335i Sedan 6AT W/ Sports Package @ 107K miles Current mods: BMS DCI, Mishimoto OCC, Vishnu CP, VRSF DP, Beluga Racing Exhaust, JB4 G5 ISO, Bilstein B12 Pro-kit suspension, Full M3 front upper and lower control arms conversion.
Future mods: FMIC, Meth kit, LED tail lights, m3 front and rear bumpers,
Manual Swap Project http://www.n54tech.com/forums/showth...d=1#post436711
Anytyme's Avatar
Car: 2011 335I
Default 04-04-2016, 03:57 PM
I'm pretty much stuck with my pumpkin, since I just bought the helical LSD prior to deciding to want to do a swap. How would now if I need a shorter or longer driveshaft? Only after install?
Default 04-04-2016, 04:02 PM
I would reference: http://www.realoem.com
and look up both 2009 and 2011 and see if the lengths are listed as the same or different. A lot of the time it will tell you if that part number is used in another vehicle and what years as well!
Anytyme's Avatar
Car: 2011 335I
Default 04-04-2016, 04:54 PM
Thanks a lot
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Default 04-07-2016, 11:00 AM
I tend disagree the car is a blast with the Auto, alpina flash and a single turbo, the only reason I'd like to go Mt is to increase the boost, 22psi gets old after a while! lol
iambinko iambinko is offline
Car: 1995 325is
Default 06-11-2016, 02:15 PM
Hello I am doing this swap from auto 335xi to stick rwd I am planning on putting this setup in my e36 chassis I wasn't so lucky to have a dual mass flywheel to get the pilot stub and carrier is there anyway to source these parts from somewhere used or new
keyap keyap is offline
Car: N55 135i
Default 06-12-2016, 04:42 AM
Don't want to derail the thread but as there's talk of N55s with DCTs, thought it was worth throwing in. I've run at 26psi max without an issue. Car is currently set up to DD map 7 (20psi) and run map 6 at 25 psi when needed.
It needed a BEF with slightly lifted limit and load values to stop DCT slip but so far all is good. Will be interesting to see how these units hold up long term as more N55 guys start to push the limits.
Anytime - don't take this the wrong way but I'm hoping I don't need to come to you for advice on a swap!
[B]
Default 08-09-2016, 04:57 PM
DIY done, my bad for the wait lmao!
08_335i 08_335i is offline
Car: 2008 335i
Default 09-12-2016, 04:13 PM
I just want to say thanks for taking the time to do this very extensive put together of parts and what to do. My AT just decided it was done holding power, so this is in me near future.
Default 09-12-2016, 04:16 PM
No worries man, yea the AT's are good for 500+HP and 400lb/tq. Glad to hear you are wanting to switch though a lot more fun on the manual side. Shoot me a message if you have any questions. I'll get to them as fast as I can.
Car: 2008 335i
Default 09-12-2016, 04:20 PM
You're awesome man thanks. I got a hellcat kill in right before it decided to tell me I've gone to far for it to handle haha. I've missed rowing my own gears though so I'm kind of excited to go back.
Julien France's Avatar
Julien France Julien France is offline
Car: Bmw 335i e92 AT
Default 02-27-2017, 03:36 PM
Hello, I have a 335i at, I would like to swap mt ... gearbox 135i and 335i are identical? Should the transmission shaft be changed? Thank you..
335i AT/ JB4+backend flash MHD/ Dci Bms/ intercooler Wagner/Dp/ Echappement Top speed/ chargepipe+mono dump Forge/ pompe a essence 320L/ Inlet Vtto/ Turbo TTE550/ Port injection Fuel It/ Ngk 5992/ Tmap/ Catch oil Bms/ Sport oil cooler valve Bms
Default 02-27-2017, 03:46 PM
I believe so, and yes you'll need a longer driveshaft for the manual trans. Some use a spacer, others have changed out the driveshaft for the manual version. Reference: realoem.com for the part numbers to make sure they match for both the 135i and the 335i. Good luck!
Default 02-28-2017, 06:03 AM
Merci.......
Joker135iN54's Avatar
Joker135iN54 Joker135iN54 is offline
Car: 2009 BMW 135i
Default 11-16-2017, 06:47 PM
When I get to step #53 I can't find "FRM" in the pop up window when I hit F1.
Can any one help me? Or had the same problem?
09 135i ST Manual Swap
everycar_bimmer everycar_bimmer is offline
Car: 08 BMW 335i
Default 11-24-2017, 09:43 PM
Awesome write up. Can you post a picture of your wiring harness (top passenger side)? Did you have to move around or cut connectors, other than rearranging the pins?
Turbohugh Turbohugh is offline
Car: E90-355I
Default 04-29-2019, 08:33 PM
I also want to thank the OP for this .
Car: E90-355I
Default 04-29-2019, 08:35 PM
Did you ever make the swap? Im getting E clutch rate faults .. Hoping to fix this weekend however if that doesnt work
ferocious's Avatar
ferocious ferocious is offline
Car: 335i N54 2008
Default 05-17-2020, 09:08 PM
Great writeup
I got few questions tho
I cant seem to figure out the clutch wiring
If i get Engine wiring harness for manual transmission module, does that mean
No extra electrical wiring needed to be done? Just plug in connectors?
And is the gas pedal swap mandatory
2008 335i N54 FFtech Top Mount single turbo Precision 5862
JB4 G5 , VRSF 7" FMIC , VRSF CP + HKS BOV, Tial Wastegates
BMS METH KIT IN CONJUNCTION WITH MMP PI WITH 1055CC INJECTORS, PURE M1 METH,TMAP 3.5,
FUEL-IT STAGE2 BUCKETLESS LPFP, RB PCV. CUSTOM TUNE, xHP Stage2 v1.5
more to come...
Zahak's Avatar
Zahak Zahak is offline
Car: BMW 335i
Unhappy 06-13-2020, 06:08 PM
I have similar problem, but in my case in step #53, I have FRM in pop up window, I can select that. But when I press F3 to execute the job, I got the error as attached picture! What should I do now?!
Now, I can start the engine by holding clutch, But I have Transmission Error and I don't know how to remove it?!
BMW E90 N54 2008 6AT, RB Turbo, JB4 G5 ISO 32, TFT Inlets, VVT Silicon N54 charge pipe outlet, Larger Inter cooler, BMS Port Injection, Methanol Injection, Evolution of Speed N54 intake manifold, Down Pipe, Charge Pipe, Blow Off, N20 TMAP, Remus Exhaust, BMS Oil catch can, K&N Filters, Alpina B3 TCU Flash, Fuel-It Stage3, Anti-Lag
