(#201)
Car: vw passat
Default 04-06-2015, 07:20 PM
yup stacked with jb4. i might try map 3 with a 70 or 75 adder and log. even though i am running terry's map it still made me buy the increased boost limit. martial said he'd credit me though once the version for jb4 users is released next week. truthfully i just want my 18 and 18.2 lbs of boost back i used to hit in the midrange. i have to check out my map 6 settings. its hard to tell because i am using firmware 28.8 but only log with jb4 mobile and change settings in jb4 mobile and that doesn't support 28.8. like i told terry the only reason i bought the mhd was to have an all in one device that can flash and run my jb4mobile to log. i really wanted to just do everything from my phone. i guess with this being so new we just have to wait and see.
Car: vw passat
Default 04-06-2015, 07:29 PM
Most of the people on this forum, in this thread, will be testing the MHD maps we've created for use with the JB4. You may have better luck on e90post or bimmerboost discussing details of flash only maps.
i sent you over some logs, didn't realize i emailed you 8 logs though, sorry. just a little confused why my targets are so low.
mike
Default 04-06-2015, 07:30 PM
lol no problem I'll look at one or two and get back to you.
Car: vw passat
Default 04-06-2015, 07:34 PM
and forgot to mention, no matter what i do i cant get the pedal to read 100%. in yesterdays 4 logs and todays 8 logs. 95,96,97% but never 100
also just noticed in tuner pro the difference between the bb flash from april 2 for ijeos and the mhd flash you sent me is 1963 bytes using the difference finder in tuner pro. thats a lot of changes.
i was hitting much higher boosts with the april 2 6mt ijeos bb flash and 28.5
romligno romligno is offline
Default 04-06-2015, 08:33 PM
Will i be able to flash stock bin files i made using bb software using mhd? Or any other flashes meant for the bb software? i dont have a bt cable is why i asked. Thanks
Spxxx's Avatar
Spxxx Spxxx is offline
Default 04-07-2015, 01:19 PM
Yes, any BIN that you create with TP or other application can be flashed via MHD... The biggest advantage of MHD is that is contains the new checksum logic allowing manipulation of an increased boost ceiling (equivalent of Cobb Race Logic) as well as some other torque limit tables.
Default 04-07-2015, 01:48 PM
Using 4/3 before you were seeing more peak boost because teh flash was forcing the boost target higher. I'm going to be revising map 7 soon for higher targets. But until then map 3 using meth safety mode = 3, lets you dial in a nice curve, even without meth. A 70 additive would give a nice 19psi peak.
BostonBeemah's Avatar
Car: AW 135i
Default 04-07-2015, 06:11 PM
Once we purchase the program, can we flash back and forth as many times as we want? From what I understand, as long as we pay for the program we don't have to pay anymore to use it to flash as many custom BINs I want to my VIN and only would have to pay if I want the OTS maps or a custom Wedge flash with the "race logic"
RIP 2008 AW/BL 135i
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 04-07-2015, 06:25 PM
Just got approved to Beta test and sadly my old Android phone was outdated so I ordered the suggested "Astro Queo A712" for $42 shipped. It's been confirmed that it works and it comes with an OTG cable. Should have the tablet tomorrow or Thursday and then my E85/Meth flash testing will begin!
The Leopard's Avatar
Car: E92
Default 04-07-2015, 06:26 PM
This is nice, but not worth making a post for. It doesn't provide any useful information.
TS N54
Need4Speed
Default 04-07-2015, 06:32 PM
Just like your post
If people don't know what Android device to buy for cheap, now they do.
Juan Testa's Avatar
Juan Testa Juan Testa is offline
Car: 335i Coupe
Default 04-07-2015, 06:46 PM
Hi Terry and guys,
Sorry for my question, I'm not sure if it is correct for this thread. I cannot use my e92 DKG transmission at high boost with this modifications; VTT 2, BMS race flash & meth... The DCT gear box slides! Does someone experience the same?
Thanks in advance,
Juan
Testa BMW Service Independente
BMS Dealer.
VTT Argentine Dealer and Instaler.
Active Autowerke Argentine Dealer.
Manhart Performance GmbH Argentine Dealer.
Spxxx's Avatar
Default 04-07-2015, 06:49 PM
Originally Posted by Juan Testa
Hi Terry and guys,
Thanks in advance,
Juan
Yeah, you're likely pretty far past the Torque limits of the stock gearbox...
I think Dodson makes an upgrade for the DKG/DCT e90 gearboxes? I'd check google for clutch upgrade options or modify the tune to request less torque.
Juan Testa's Avatar
Car: 335i Coupe
Default 04-07-2015, 06:55 PM
Thanks for your answer, Man!
BMS Dealer.
BuraQ's Avatar
BuraQ BuraQ is offline
Car: 335is DCT
Default 04-07-2015, 06:59 PM
I've tested the DCT all the way to 580 wtq, 80k+ miles, car was tracked almost every week, raced almost every day, and with absolutely no signs of slippage. Not to mention how many driveshafts I've destroyed. That's not his issue......
2011 E92 335is w/DCT
2007 E92 335i 6AT
DV135i's Avatar
DV135i DV135i is offline
Default 04-07-2015, 07:40 PM
So they're still accepting beta testers, but then telling others to wait for open beta this week???? looks like I'll be sticking to the bms backened flashing.
Terry can you please release your own version of this so we know it's trustworthy??? Lol
~JB4 G5 iso~BMS E85 Backend Flash~VTT Inlets~BMS DCI~BMS Low Temp Thermostat~BMS OCC~BMS Modified Clutch Valve~BMS Clutch Stop~335is Clutch~ER Competition FMIC Kit w/ HKS SSQV~3"AR **'s~3" Custom exhaust~RB PCV Valve~SteveAZ Stage 2 Bucket~Avant Garde M359 18x8.5 +35 18x9.5 +33~
AWil335i's Avatar
AWil335i AWil335i is offline
Car: 2007 335i
Default 04-07-2015, 07:58 PM
I'm in the beta program and the flash works great. Using it to flash backend JB4 maps... much better than the laptop app, which I occasionally had problems with on my K-Line
07 E92 335I | JB4 G5 ISO | BMS E85 Flash | DCI | BMS *** | Helix FMIC | Alpina TCU Flash | Walbro GLS392 | E70 | 429rwhp/474rwtq
Default 04-07-2015, 08:14 PM
I thought it might be cool to have custom (reliable!) DCAN cables with a micro-USB that goes right in the android device made eliminating the need for an adapter. But I haven't had time to look in to it yet.
For those using the MHD to load JB4 flashes the software charge is only $79 which I think isn't too bad considering.
Spxxx's Avatar
Default 04-07-2015, 08:26 PM
I wouldn't say Martial isn't trustworthy... He's trying to run a business and if you ask him enough times to take your money, he'll likely say yes... Lol
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 04-07-2015, 09:15 PM
He meant the cable, not the app.
Spxxx's Avatar
Default 04-07-2015, 09:17 PM
Hahahaha whoops, that makes more sense.
Car: vw passat
Default 04-07-2015, 09:19 PM
whats the difference between the bb maps posted in the sticky and the mhd maps you sent us terry? different logic? In tuner pro the difference between the bb flash from april 2 for ijeos and the mhd flash you sent me is 1963 bytes using the difference finder in tuner pro. just trying to understand a little better.
car runs great and logs look good with 28.81 firmware and the mhd map you provided.
thanks
Spxxx's Avatar
Default 04-07-2015, 09:27 PM
I think just Increased torque limits and boost limit to take advantage of the new checksums with MHD. I'll let Terry explain more
DV135i's Avatar
Default 04-07-2015, 11:41 PM
No... I meant the app, not the cable. They don't answer easy questions terry asks about posting logs or explaining aspects of how they're tuning, so I'm finding it hard to take them serious now. Especially if you have to "beg" someone to take your money. Oh well I'm over this new "trend" and will just stick with whatever bms is pushing from now on.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 04-08-2015, 02:14 AM
I'm always glad to hear something like this! I have a DCT car with under 40k on the clock. Hoping it's still solid. Only 8k miles with a JB4 and *** on it.
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
