(#1476)
Car: 2007 e90 335i
Default 09-19-2015, 05:19 PM
So the mhd loging and monitoring feature is not compattable with the jb4?
2007 e90 335i
climax_E92 climax_E92 is offline
Default 09-19-2015, 07:45 PM
Originally Posted by SchismX
Yes. I installed a JB4 backend flash and was able to increase my idle speed as well as doing the cold start noise reduction.
Oh thank you. Btw, do you just pay for that option separately?
SchismX's Avatar
SchismX SchismX is offline
Car: '2010 135i
Default 09-19-2015, 08:13 PM
The only thing I paid for was the flasher module, the $99 one.
JB4 + Trebila custom flash / ********* *** / ER Chargepipe + Tial Q / VRSF FMIC / BMS DCI / BMS OCC / Alpina B3 flash
Default 09-19-2015, 08:15 PM
You only need the $79 option if using one of our JB4 back end flash maps.
Blind35 Blind35 is offline
Car: 335Xi '08 N54
Default 09-19-2015, 11:23 PM
Tell me
I have down ***** and check engine
MHD Flaher help me? What map I need flash? I don't have JB4!
HairyWelshSteve HairyWelshSteve is offline
Car: '07 335i MSport Convertible
Default 09-20-2015, 01:27 AM
Originally Posted by Blind35
Tell me
It will allow you to read the codes for the CEL. However you *could* install INPA and use that to read out codes. You could find out more at www.bmwcoding.com
Van3 Van3 is offline
Car: Bimmer
Default 09-20-2015, 02:10 AM
I am currently single turbo but i do not have the JB4 yet, Can i load these maps through MHD and use my wastegate (10psi) to control my boost until i get my JB4 in?
Car: 335Xi '08 N54
Default 09-20-2015, 02:11 AM
I know what check engine
It's lambda after **
Sorry my English - bad
wardy335i's Avatar
wardy335i wardy335i is offline
Car: E93 335i
Default 09-20-2015, 03:14 AM
I had to changed my Lambda sensor BEFORE **, was pretty easy!
Sensor after ** looks easy too
2008 E93 335i M-Sport 6AT
MHD Stage 1 // Dual Foam Cones // Avant Garde M359 //
Powerflex Black Edition Polys // Ferodo DS2500s // VRSF 3" *** // TBC
London
Car: 335Xi '08 N54
Default 09-20-2015, 03:49 AM
I need to OFF my lambda - like EURO2
I need map like euro 2 in MHD Flasher
It's real?
Default 09-20-2015, 04:19 AM
It's real?
You can turn off the error codes using bimmerboost or MHD or even editing your stock bin using the up to date XDF in TunerPro
HeavyMetalRocker's Avatar
HeavyMetalRocker HeavyMetalRocker is offline
Car: BMW 335i e90
Default 09-20-2015, 08:15 AM
Not that I'm planning on flying down the highway at 190 or anything buuuuut in-case I find myself in the situation where I need to be flying at 189 does the MHD flash still remove the speed limiter like the BMS flash does??
CLTEURO CLTEURO is offline
Car: 08 335i 6MT Coupe
Default 09-20-2015, 09:08 AM
I may/may not have hit north of 150mph the other night in Mexico...stock limiter is 155mph, still in 5th and had plenty of RPM and gear to go!
2008 E92 335i Coupe 6MT | Apex Arc-8 18x9.5 | MHD: Stage 2 93oct | CP-e Charge Pipe | Active Autowerke BOV | DCI | VRSF C*****S D*******S | VRSF 5" FMIC | Cyba Air Scoops | BMW PE Mod
Car: 335Xi '08 N54
Default 09-20-2015, 11:35 AM
Please tell me
I don't have JB4
I buy and flash Staige 2 on MHD Flasher
And I don't have more power!
Why?
darkrom darkrom is offline
Car: 135i N54
Default 09-21-2015, 08:11 AM
It goes past the limit if you use the BMS backend via MHD. About the MHD tunes themselves, I'm not sure.
Car: Bimmer
Default 09-21-2015, 04:27 PM
Anyone? seems i can't get an answer even through emails.
Shafer Shafer is offline
Car: 2008 e90 335i 6MT
Default 09-21-2015, 04:30 PM
What are you currently using as a tune for your setup?
Car: Bimmer
Default 09-21-2015, 04:55 PM
Nothing haven't started the car yet.
Default 09-21-2015, 06:00 PM
You could reach out to anyone who makes tunes for MHD to get you setup with a low boost "base map" until your JB4 is installed. Then once it's in you can either use Terry's ST flashes, or continue with the tuner you choose and they'll get you a custom tune that's designed to work with the JB4 as well.
Car: Bimmer
Default 09-21-2015, 07:43 PM
Do you happen to know anyone i can pm or contact?
Thanks bro for the information you been the only person to help me so far.
Default 09-21-2015, 08:53 PM
PTF (ProTuning Freaks), Wedge Tuning, And now there's a handful of others as well.
FWIW, the support section would be ideal for this topic. You'd get more visibility there on the problem.
enrita's Avatar
enrita enrita is offline
Default 09-22-2015, 02:26 PM
with 0 cold start my car does not start after 5-6 times i crank it, than it starts badly and dies couple more times, i upped to 30 seconds and its a bit better. would raise idle speed help? ST with 100% E85
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
jmb85 jmb85 is offline
Car: 335i e92
Default 09-22-2015, 03:42 PM
no codes?
enrita's Avatar
Default 09-22-2015, 11:29 PM
Originally Posted by jmb85
no codes?
None as far as i know will check
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 09-23-2015, 01:25 AM
@Martial - does the cold start setting in MHD override the value even if it is left alone? I ask because I already edit my bin in TunerPro to shorten the cold start duration but on flashing today it appeared to be the full 65s. If the slider isn't moved couldn't the value flashed just be that in the .bin and not the default. Please correct me if I'm wrong.
There is no slider for cold start, just a text box. If you click it, all values are overwritten with 0s. Otherwise, values in your bin are not touched.
I was Monitoring my Engine last night, N54 with MHD Stage 1 98RON..
My idle Lambda reading was 14.4 and when i was foot to the floor, it went to 10.7...
I cant find much info on the net about what the perameters are but is this running too conservative/lean?
Running 99 RON
Idle is around 14.7. Wot should be a bit leaner, around 11.2 WOT / high rpm for the stage 1 map.
Originally Posted by brnmcn
Just wanted to chime in and say that the fail-safe built into the flasher app is top notch. Idiot-ass me pressed the back button mid-flash and it failed. Then, another option popped up to clear the failed flash and re-write.
Thanks, with MHD our top priorities is simplicity and safeness.
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
