(#276)
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 04-11-2015, 02:18 PM
Martial made a change that may should resolve it. But I'm not sure how to read the software version number within the app so he can chime in on when its been uploaded and ready for testing.
The app update to resolve this issue has been online for like 3 hours now. For the next update I will add a version number, for the moment you can read the app description in the google store which states the JB4 backend 30FE was tentatively resolved.
You can also delete the app and re download it, probably as quick as checking the revision notes.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 04-11-2015, 05:35 PM
I've been getting that question a lot. The short answer is maybe. If you're an automatic running high boost levels, feeding higher torque to the trans may help shifting. If you're an MT running higher boost levels, having a higher reported load may reduce the bog tendency. There is also some addl tuning flexibility within the software that I think will help with post shift automatic timing in our JB4 back end maps. But that said, compared to BB, it's basically a more convenient way of loading a flash map.
And how does that comparison stack up against the Cobb? Specifically for the torque load handling and shifting?
I suppose for DCT'ers this is the biggest point of concern as everything else is pretty much the same from a tuning perspective.
Default 04-11-2015, 08:33 PM
It's better than Cobb. Because the maps are unlocked, better supported, and it's 1/5th the price. The second MHD came out we dropped Cobb N54 support. Hopefully they add the 1M firmware soon so I can never open a Cobb N54 tuning interface again.
_ink's Avatar
Car: 335i DCT
Default 04-11-2015, 10:29 PM
Other than being unlocked and cheaper, and better supported.
Are there tangible benefits from a tuning perspective? Obviously, this is coming from someone who already has a Cobb.
Default 04-11-2015, 10:42 PM
No it's basically the same thing from a tuning perspective. Although being unlocked means we can access tables and disable fault codes not available within Cobb.
_ink's Avatar
Car: 335i DCT
Default 04-11-2015, 11:07 PM
Ok, this is what I wanted to hear.
It is a shame for the users that steady have Cobb's that you are doing this, but makes sense because Cobb lock out these tables, so is kinda their own doing.
darkrom darkrom is offline
Car: 135i N54
Default 04-12-2015, 11:07 AM
Got my battery charger. Figured I'd do it properly. Cable and otg ready to go. Dealt with visiting Walmart to buy one today, talk about deaspiration and commitment.
Default 04-12-2015, 11:25 AM
What did you get at Walmart??
N54 | Build Thread
Car: 135i N54
Default 04-12-2015, 11:27 AM
Just a 20 amp battery charger. Not many options around here on a Sunday. I'd gladly pay extra to avoid that place usually, but I've got flash fever.
DV135i's Avatar
DV135i DV135i is offline
Default 04-12-2015, 11:29 AM
Terry, will the bms maps already be on this app or will you be starting a new thread like the bimmerboost one that will contain the maps available?
~JB4 G5 iso~BMS E85 Backend Flash~VTT Inlets~BMS DCI~BMS Low Temp Thermostat~BMS OCC~BMS Modified Clutch Valve~BMS Clutch Stop~335is Clutch~ER Competition FMIC Kit w/ HKS SSQV~3"AR **'s~3" Custom exhaust~RB PCV Valve~SteveAZ Stage 2 Bucket~Avant Garde M359 18x8.5 +35 18x9.5 +33~
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 04-12-2015, 11:40 AM
They are on this thread, first post
DV135i's Avatar
Default 04-12-2015, 11:53 AM
lol I always go straight to the last page thanks!
Car: 135i N54
Default 04-12-2015, 12:47 PM
Its on the store boys. Go get it!
Car: 135i N54
Default 04-12-2015, 01:34 PM
I've got "contacting the ecu" hanging on my nexus 6 and my 2013 n7. Its on the charger. Any ideas? Jb on map 0.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 04-12-2015, 01:57 PM
After 5 weeks of closed testing, the MHD Flasher enters now the open beta stage. The app is available on the Google Store https://play.google.com/store/apps/d...hd.flasher.n54
Here is a list of the major changes that were done since the initial announcement:
- For the Stage 1 and Stage 2 91 maps, 93oct variants available at no cost
- Linear throttle option, for a more precise throttle control over the stock pedal mapping.
- The maximum number of monitors simultaneously loggable has been increased from 19 to to 30.
- 535i support
The next weeks will see the introduction of gauges, and the support of IKMA0S (for 1M cars) and INA0S (for z4 and 335is).
The 20% discount remains active during the open beta phase.
I would like to thank the closed beta users for the useful feedback and kind words.
Martial
BostonBeemah's Avatar
Car: AW 135i
Default 04-12-2015, 02:07 PM
- 535i support
Martial
Little confused. If i purchase the "flasher", are all the maps available after that to be flashed as many times as I want between them all and is the $79 the discounted price? Just a little confused as to why there are separate prices for everything if they can all be bought for the flasher price.
RIP 2008 AW/BL 135i
swaggasnatcha swaggasnatcha is offline
Car: 07 335I
Default 04-12-2015, 05:09 PM
Hey guys im new to this backend flash stuff and looking for some advice.
As of now I am stock with a jb4 and dci with 93 oct im planning on flashing a pump gas map tonight. Should I run jb4 pump back end or apps stage 1 93 oct?
Also from time to time I run 4 gallons of e85 so would I just run map 5 or would I have to re flash to a e85 back end?
Car: 135i N54
Default 04-12-2015, 05:21 PM
Got it working thanks to BostonBeemah being awesome and letting me use his cable and garage. Thanks man. The car is insane. Thanks terry and marshal this is amazing.
jack335i's Avatar
jack335i jack335i is offline
Default 04-12-2015, 09:51 PM
Hey Terry,
In the mhd back end flash files you only have st e85 back end flashes im running pump fuel with meth injection what flash would I use?
Default 04-12-2015, 10:17 PM
Start with the RACE file for pump + meth.
Car: 09 E92 335i
Default 04-12-2015, 10:44 PM
Anyway we can access the store or purchase license without having hook up to the car? Living in a condo with separate garage means I have no access to WIFI, and android device doesn't play very nice with iOS wifi hotspot.
ej0581 ej0581 is offline
Default 04-13-2015, 01:48 AM
Apologies if this is a stupid question but I can't seem to find info on the difference between the stage 1 and stage 2 maps in terms of car/ fuel requirements?
BuraQ's Avatar
BuraQ BuraQ is offline
Car: 335is DCT
Default 04-13-2015, 04:44 AM
If your talking about the Q-Logic or flash only maps then Stage 1 is for non FBO cars and Stage 2 is strickly for FBO .
FBO is classified minimum, upgraded intake, FMIC, and *********. If you are missing one of these upraded mods then your are not FBO
2011 E92 335is w/DCT
2007 E92 335i 6AT
Default 04-13-2015, 04:46 AM
Thanks for the info.
I'm FBO running 93 octane. Currently using only JB4, map 5.
What's going to give the best results for me - jb4 map 5, BMS pump flash or MHD stage 2 93?
BuraQ's Avatar
Car: 335is DCT
Default 04-13-2015, 04:50 AM
Im on the other side of the fence here, so that is something you will have to decide
2007 E92 335i 6AT
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
