N54Boost N54Boost is offline
Car: 07 335i N54
Arrow Stand Alone Halo switch help - 06-13-2013, 06:33 AM
I have a 2007 335i the halos come on with headlights or turn signal modes only, im trying to figure out how i can set my halos to a seperate switch that way i can run them as a stand alone system and able to turn them on or off whenever i want. Does anyone have any direction on how to do this, or maybe a DIY out there. Thanks Gentlemen
ajm8127 ajm8127 is offline
Car: '07 335i
Default 06-13-2013, 09:54 AM
Check out http://www.distantxtremes.com/daeos-...y-harness.html
Usually I think this stuff is overpriced but for $40 I might buy it myself and use it with the LED bulbs Terry offers for the pre-LCI angel eyes.
Car: '07 335i
Default 06-13-2013, 09:59 AM
Oh, if you do install this, make sure you use electrical tape over the tap connections, especially the ones outside of the DME enclosure. This will keep splashing water/salt off of the electrical connections.
If you really want a switch, install one in the red wire that connects the harness to power inside of the DME enclosure. Personally I would just leave them on all of the time.
Default 06-13-2013, 04:05 PM
Code out your marker lights....still work as turn signals.
Car is torn apart and battery is disconnected right now...I'll take a pic later.
edit...pic added
Chris749 Chris749 is offline
Default 09-20-2013, 09:42 AM
edit...pic added
What do you mean by "code out" marker lights? and how do you do it?
dsjr2006 dsjr2006 is offline
Car: E90 N54 Xi
Default 10-08-2013, 07:14 PM
Go to e90post and check-out the coding forum.
Default 10-08-2013, 10:09 PM
Sorry, I missed your post...
Can't comment on E90post although I'm sure its there. It would also be on www.bmwcoding.com with all the instructions you'll need to get started.
But to answer your question.."coding them out" is connecting to the cars ECU and changing the line of "code" for that particular item from "activ" to "nicht activ" if memory serves me right.
I can get the exact terms and proper ECU, but you're going to have to set things up properly in order to be able to "talk" to the ECU to begin with and that website will help you do that.
big_c big_c is offline
Car: NA
Default 01-06-2014, 06:41 PM
If you dont want to deal with coding, I have a daeos vista harness that allows angel eyes as DRL for sale. $45 shipped. PM me
