(#7851)
O2nice's Avatar
O2nice O2nice is offline
Car: 2007 e92 335i
Default 10-22-2013, 05:48 AM
Originally Posted by boostaholic
With the Alpina TCU flash driving around in D mode, the car shifts WAY to early even for normal day to day driving...Well atleast for my taste. Sport mode is what I usually use most of the time...Well really a mix of sport mode and using the paddles because I'm so use to using paddles on my previous M6 and E92 M3.
Since you just installed you G5 ISO and loaded the 27.5 firmware (newest firmware), make sure you restore defaults, just to be on the safe side so you can enjoy the tune to the full potential also make sure you go to settings tab and make sure look at the drop down menu to make sure your running the G5 ISO. I think its usually on G5 when you first get it because thats in the interface, not the actual board.
If I was you I would personally find someone in your area that does coding/flashing or do it yourself if your a tech type of guy and run the E85 flash. Just make sure you save your original BIN file. Put in about 4 gallons of E85 when your tank is on empty for the first tank and dont dog it around, let the car understand what is going on but after about a quarter tank is gone do a 3rd gear roll from 40mph thru 4th gear if you can letting the RPM's go to 7K redline on map 5 about 4 or 5 times for it to learn since its the autotune map. After the biggest smile you cant get off your face, at about a little less than a quarter of a tank, put in 8 gallons of E85 and the rest 93, which is usually around 5 gallons or less. Let it run for a few minutes before leaving the gas station and drive it normally for about 10 minutes or so to let it fully mix. Put it on map 7 and get ready to become literally ADDICTED Make sure you take traction control all the way off (hold DTC button for about 5 seconds) because the tires are going to for sure spin, even on stock turbos continue to fill your tank up with atleast a 50% E85/93 mix.. Then your mind will be BLOWN away
and just incase your wondering about if E85 hurts your car, it DOES NOT. I personally have been using it for almost two and a half years now, maybe more and I just got my first HPFP replaced about 3 weeks ago. Of course back in the day I would only put in 2 or 3 gallons but man that 2 or 3 gallons made huge gains and I got addicted just like you will
Sometimes certain cars cant even handle 50% e85 without a lpfp upgrade. He'll have to do some logs first to see whats going on.
kuch335's Avatar
kuch335 kuch335 is offline
Car: 07 335i Coupe
Default 10-22-2013, 10:04 AM
Terry, what are the actual usable values for dash setting 12? The Spreadsheet on first post says 25-30 but I see several posts in here where folks are running as low as 19 and as high as 35. Running 27.5 with latest flash but still trying to work out some rattle on light gas pedal. Thanks!
2007 335i E92 AT - JB4 G5 ISO + BMS E85 Flash, MR5 Intake, VRSF ***, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, LED Int, LUX V3, CF Hood, Mini Battery
Default 10-22-2013, 10:29 AM
I think we moved the range to 20-40 in one of the 27 versions.
trebila's Avatar
trebila trebila is offline
Default 10-22-2013, 11:13 AM
I'm running 60% e85 with the stock LPFP, no upgrade, with no issue.
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 10-22-2013, 12:13 PM
How many gallons do you put in? What mods do you have?
O2nice's Avatar
Car: 2007 e92 335i
Default 10-22-2013, 12:50 PM
Highly doubt that..lpfp is to weak to handle tht amount, u tryna tell me yours is superior than everyone elses?
orau22 orau22 is offline
Car: E92 335i Coupe 6MT
Default 10-22-2013, 03:40 PM
Originally Posted by dknl
Remove all mods and clear codes prior to going to dealer is the only way to be safe.
It takes them minutes to check if u modded ECU, why keep it in?
Yes, I would definitely remove it.
Jnat Jnat is offline
Car: 09 335xi
Default 10-22-2013, 03:43 PM
I don't know, my car cries foul at anything over E35ish. Car will run great at E40 but I get fuel mixture codes.
09 335XI /Cobb ATR TUNED 18.5 psi/DCI/2ND ***** '''''''/E20/Alpina/VRSF 7inch/VRSF Chargepipe with Tial BOV***
Cynical Cynical is offline
Default 10-22-2013, 03:44 PM
60% isnt an issue... above that yea. But No 60% isnt an issue at all if your lpfp is running fine. Your lpfp must be failing.
Car: 09 335xi
Default 10-22-2013, 03:45 PM
No fuel mixture codes?
O2nice's Avatar
Car: 2007 e92 335i
Default 10-22-2013, 04:15 PM
I have a walbro, its running excellent..i run 80% e85 sometimes
Default 10-22-2013, 04:34 PM
Same. I run 100% mostly, depending on how
My clutch is holding that day.
sointoyou sointoyou is offline
Default 10-22-2013, 06:15 PM
what's the max value on setting 10 and 12?
I updated to 27.5 and I have setting 10 at 50 and 12 at 38?
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 10-22-2013, 06:50 PM
I believe 10 = 50 and 12 = 40 so you are at the max.
trebila's Avatar
Default 10-23-2013, 01:35 AM
I live in France, so I put 30 liters of E85 and 20 litres of 93 pump gas.
My mods:
Jb4 g5 iso 27.5
BMS BB flash E85
BMS DCI
Helix FMIC
Alpina b3 flash
RB pcv valve
Midpipes uncatted
My LPFP is running above 50 psi all the time.
I have 50000 kms, so 35000 miles.
GtiGyver GtiGyver is offline
Default 10-23-2013, 07:43 AM
Hello all.
Can anyone explain how to best adjust the "Default Wastegate Position" and the "Base Duty Cycle".
What I'd like to know is when each of those values comes into play and how.
On idle?
On Deceleration?
On Partial acceleration?
I searched but found no conclusive explanations.
335si's Avatar
335si 335si is offline
Default 10-23-2013, 07:53 AM
I thought that the LP should be in the upper 60-70psi range under wide open throttle?
-2007 335i - All stock
12.3@118+mph
-2007 Suzuki SV650 - Evotech FE, M4 Carbon Slip-on, Solo Seat
trebila's Avatar
Default 10-23-2013, 08:58 AM
As long as the LPFP pressure is not below 50 psi, no issue.
335si's Avatar
Default 10-23-2013, 10:16 AM
Well I have been having LP fuel issues for a few weeks. Logs were showing 30-40psi at WOT!
First I replaced the LPFP and relogged. Logs only showed and increase of about 5-10psi across the board.
I then replaced the fuel pressure regulator and fuel filter assembly which BMW states is a "lifetime product." Just relogged and fuel pressure is very high 60s to low 70s under WOT in 4 gear! Problem solved!
I'm headed to the track tonight to see if I can beat my previous trap of 117.64mph.
12.3@118+mph
335si's Avatar
Default 10-23-2013, 10:33 AM
Terry - Logs of 27.5 and the latest race flash sent to you via email.
12.3@118+mph
Kish2604's Avatar
Kish2604 Kish2604 is offline
Default 10-23-2013, 12:12 PM
Can you highlight the part numbers you changed on realoem? Would be keen to do it at the same time as my lpfp upgrade...
Thanks..
|RB old gen|Jb4 G5|3" **'s|ER Competition Cooler|ER Charge pipe|Tial BOV|CM Meth Kit|Dual nozzle setup|BMS cowl filters|AFE intakes+scoops|
|BMS low temp oil thermo|MHD flash + coding|HnR Springs|M3 Control arm kit + H&R + Koni|LED Angel eyes+plate lights
335si's Avatar
Default 10-23-2013, 12:30 PM
Thanks..
http://www.ecstuning.com/BMW-E92-335.../Fuel/ES37459/
Part number: 16147163296
I definitely recommend doing both at the same time. I wish I would have done this! I'm just glad it's fixed now. I have 93k miles on my car, so I am sure the filter was due
for replacement. I don't understand how a filter can be a lifetime product....
12.3@118+mph
Alex!'s Avatar
Alex! Alex! is offline
Car: 135 I N54
Default 10-23-2013, 02:35 PM
Newbbye question, do you log with jb4 cable? wich parameter it is fuel pressure??
135I - 6 MT -JB4 G5 ISO Map 3 - BB Race Flash - Riss Rasing ******* ** - AFE CAIs - BMS SDL - 93 Octanes - Sistem X wather meth - SPEC 2+ - RB Twins!!
Car: 2009 335i AT
Cool 10-23-2013, 05:14 PM
Yes .... log with the JB4 USB cable.
LPFP pressure is FP L and HPFP pressure is FP H.
Default 10-23-2013, 05:32 PM
Wrong section!
Currently Active Users Viewing This Thread: 18 (1 members and 17 guests)
Milehighbmw
