(#6851)
wreckz's Avatar
wreckz wreckz is offline
Car: n54 TOOPL3SS
Default 06-15-2013, 11:25 AM
this works great for me
my car feels like its pissed off I fukn luv it
great feature ... still testing
Rob180bhp Rob180bhp is offline
Default 06-15-2013, 11:56 AM
So whats the best overall settings for a 135i manual trans
NihonX NihonX is offline
Car: 1M
Default 06-15-2013, 09:34 PM
Default.
alexim's Avatar
alexim alexim is offline
Car: 1M
Default 06-17-2013, 05:12 AM
So what if you don't want to limit torque on 1st and 2nd?? Where do you set the dash command???
mrbillytalent's Avatar
mrbillytalent mrbillytalent is offline
Probably being sarcastic
Car: e46 323i & e90 335i
Default 06-17-2013, 07:09 AM
Dash command set to 0 = no boost limiting
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar **'s SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
EvanL's Avatar
EvanL EvanL is offline
Car: 07 E92, 08 E61 (N54s)
Default 06-17-2013, 11:54 AM
Added 23B firmware & notes and updated wheel control sheet (& XLS file) to first post.
Terry,
Thank you for posting these. The Excel file is much more legible and the easy adjustability of the 1st and 2nd gear boost is a welcome addition.
Best,
Evan
'07 335i, '08 535xiT
blacksleeper blacksleeper is offline
Car: 2009 335i
Default 06-17-2013, 06:40 PM
How's this log look terry
Jb4 23b updated
2 gallons of e85 and 5 gallons of 93
Map 5
Dci
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 06-17-2013, 06:43 PM
Email him for faster response. But the logs look solid
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
Car: 2009 335i
Default 06-17-2013, 08:07 PM
Think I can get away with a higher mixer
Car: 07 e92 M/T
Default 06-17-2013, 08:14 PM
Yes, u should be good up to 40%
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default Dscoff - 06-18-2013, 12:38 AM
I started to max out 3 gallons E85 to 7 gallons 94 Pulp
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018 gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, 17.2 deg timing, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 431rwkw Mainline Dyno Aus
2016 M4 Competition Pack, 7-sp DCT, Jb4 Map 6
25.0 psi, s55 ign e85 Bef, E70, M4 plugs gapped 0.020, stock everything else, 374.9 rwkw Mainline Dyno Aus
alexim's Avatar
Car: 1M
Default 06-18-2013, 05:11 AM
Terry, any plans on getting the one push DTC at startup work for the 1M???
It's just about the only feature missing and I reallly miss it!!
Jnat Jnat is offline
Car: 09 335xi
Default 06-18-2013, 03:24 PM
Is it working for the 335 because the last time I tried it a couple months ago it did not work?
DSCOFF's Avatar
Car: 335i coupe N54
Default 06-18-2013, 05:29 PM
Yep it works for 335i. But I dun utilise it since I like to have dsc completely off which also saves my rear brake pads wear
Grease Monkey's Avatar
Grease Monkey Grease Monkey is offline
Car: 335i xdrive
Default 06-19-2013, 07:17 PM
Finally updated to 23B from ISO 18 (laptop battery had died and was waiting for a new one). My low throttle boost surge seems to have disappeared just by this update. I have not touched any of the added menu configurations, but map 5 has re-adapted which may also be part of the fix. Either way my car seems very happy with the newest update, thanks Terry!
My only complaint is that the automatic DTC setting still does not seem to work, any suggestions?
'09 335 xdrive: JB4 G5 ISO - BMS Pump Flash - E30 / BMS DCI / VRSF ** / VRSF FMIC / BMS CP / BMS CDV / BMS Clutch Stop / ZHP Shift Knob
'07 Mustang GT/CS vert: Intake / Tune / Straight ***** / Strut Brace
'67 Jacobsen Tractor: Yardwork Toy...
e91 335i e91 335i is offline
Car: BMW e91 335i
Default 06-19-2013, 11:12 PM
Is it possible to see the low fuel pressure from the meters or do I have to log it? I am changing my OEM lpfp to Walbro and it would be nice to see the pressure during cruise.
Default 06-20-2013, 09:11 AM
Fuel pressure is only in the laptop display.
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 06-20-2013, 10:07 AM
Terry, I'm still trying different settings to get my shifts smoothed out, including playing with the auto shift boost reduction. Is there any way you could add a menu 15 that included steering wheel adjustability for this so we don't have to only use a laptop to change this value? Just a thought...
2013 335is DCT -- Quaife | JRZ RS1 - 450/800# | M3 + Hardrace arms | e93 M3 + Hotchkis f/r sways | BMS CP + OCC | ETS 5" IC | AFE **'s + DCI | RB PCV + Thermo Delete | Setrab + Improved Racing oil cooling | Stoptech f+r BBK | Cobb BQ Tune
Default 06-21-2013, 06:13 PM
That setting generally should not be adjusted unless you have an over boost on high boost high RPM shifts. It's a PID / boost control setting and there would be no way to evaluate it without analyzing PWM and boost vs. target in a datalog.
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 06-22-2013, 01:10 PM
is there any gain in horsepower if i change my oem fuel pump to walbro 400lph internal?
bmw 335i e92 2007 AT
bms dci
fmic
as i just ordered it so im curious
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
Paulito Paulito is offline
Car: 07 AW 335I Coupe
Default 06-24-2013, 10:29 AM
bms dci
fmic
not unless you're running out of fuel on your stock pump
ashmostro's Avatar
Car: 2013 335is DCT
Default 06-24-2013, 10:47 AM
Got it. Back to 60 then.
FWIW, switching from map 5 to map 2 appears to have smoothed things out slightly..
Default 06-24-2013, 05:13 PM
Originally Posted by WickedB
I'm sure it's in this massive thread somewhere..., but can someone point me in the right direction as to where/ what you have to change to log the Low pressure fuel pump output? Also what the future use options all do would be helpful as well. I have JB4 G4 PNP if it matters..
Thanks.
You'll need a G5 to log low fuel pressure. It's not supported with the G4.
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 06-25-2013, 07:34 AM
Did you try map 6?
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
ashmostro's Avatar
Car: 2013 335is DCT
Default 06-25-2013, 08:23 AM
Not yet
Currently Active Users Viewing This Thread: 14 (0 members and 14 guests)
