(#6351)
goaljnky's Avatar
goaljnky goaljnky is offline
Car: M5, Z4 3.5 IS
Default 03-20-2013, 03:20 PM
Originally Posted by Cynical
Or just route it thru the fire wall or leave it outside the dme*box
Not ecu
I'm in a Z4. The DME box is on a left hand (driver's) side. I've yet to figure out how to get the wire into the cabin.
2011 S Drive 3.5 IS
2008 M5
2006 Mini Cooper S JCW
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 03-20-2013, 03:30 PM
Take a screwdriver and lift the steering wheel column boot away from the car's firewall.
The firewall will have a sharp edge to it..... so place a short length of tygon tubing
(split to go around the USB wire) where it goes through the firewall.... for protection.
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 03-20-2013, 03:31 PM
17B installed, will run some logs when I get fresh fuel.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
Default 03-20-2013, 03:48 PM
Did a dyno on the 17B with a 335is today on map 5. Was pretty strong @ ~412rw using a 40% E85 mix. Has ********* and DCI IIRC.
Cynical Cynical is offline
Default 03-20-2013, 03:54 PM
Lol ive been running map 7 with 50/50 e85/gas
Bad?
335is 7DCT/JB4
Default 03-20-2013, 04:43 PM
Trying to work up the E85 percentage a bit at a time at 3.25 gal into the full tank now. I will be getting fuel over the weekend to boost the percentage & will run a few logs.
No ** or DCI but I do have an FMIC.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
jamesatl335is jamesatl335is is offline
Car: 2012 335is Conv.
Default 03-21-2013, 09:55 AM
updating to 17b now. I'll have logs up by tonight on map 5 and map 7. running 6gal of
E85/93
12' 335IS Convertible (w\DCT)--BMS DCI--G5 ISO--E85\93 Mix
Default 03-21-2013, 09:59 AM
Bad?
You'd have to look at your logs to ensure it's safe. Map 7 won't check for timing drops, etc, so you're on your own for it.
inferno68 inferno68 is offline
Car: BMW 1M
Default 03-21-2013, 03:41 PM
Terry you did 412rwhp with the 335is but with what kind of boost pressure ?
kevin
Default 03-21-2013, 03:52 PM
That was on map 5@17psi peak IIRC. He did 425rw on map 7@18.5psi peak.
Car: BMW 1M
Default 03-21-2013, 04:05 PM
Wow pretty impressive, do you think you can get more with the bms flash ?
Default 03-21-2013, 06:46 PM
E85/93
Way too much E85. Threw fuel code on map7 and map 5 has a stutter at WOT...adding more 93 tomorrow.
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 03-21-2013, 07:41 PM
you need a BMS flash.
zeel zeel is offline
Car: AW e92 335i
Default 03-21-2013, 08:08 PM
And the walbro lpfp
Default 03-21-2013, 09:12 PM
Yes I've noticed the 335is in particular is pretty sensitive to fuel pressure down low on E85 due to its natively richer air/fuel targets. Of course one solution is the BMS flash, but I have a JB4 programming tweak in mind that might help a bit too.
Default 03-22-2013, 06:27 AM
Originally Posted by zeel
And the walbro lpfp
It's a lease, so reducing the E85 (or until Terry updates the 335IS for map5) is the only plausible option. When I was running 4 GAL of E85 it did 397WHP\422 TRQ...I'm happy with those figures with nothing but the DCI\G5.
335is 7DCT/JB4
Default 03-22-2013, 07:28 AM
If the station has any today will try 4.5 gal into a full tank of 93. That's 1.3 gal more than the last mix. Will try to get some logs Sat/Sun if no quick codes. I am running 17B
EDIT Misty out will have to put off the logs. That being said no codes during the 3 third gear runs to set the map.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
Nanehi Nanehi is offline
Car: 2009 335i Coupe
Default Will Cutting G5 Diodes Out Void My Warranty? - 03-22-2013, 10:08 AM
Just upgraded from JB4 G4 to G5. Before cutting the diodes out, I would like to know if this will void my warranty.
335is 7DCT/JB4
Default 03-22-2013, 10:30 AM
Will be happy to try it when you have it ready
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
mirsadvic mirsadvic is offline
Car: 2007 335i
Default 03-22-2013, 08:25 PM
I just got the G5 now for the noob question---i mostly bought due to trying to lower my wastegate rattle any info on how to directly do that i did get the usb cable aswell? also the g5 should come with the newest firmware correct? Last question do i have to cut the diodes to fix the rattle
OldBooster's Avatar
Car: 2008 135i AT
Default 03-23-2013, 06:51 AM
Until you learn more about the system and how it works, I wouldn't cut the diodes yet. Get familiar with connecting your laptop to the system, settings, etc. Then other members can advise you about how to address the wastegate rattle. And life itself will have fewer rattles if you put periods after the last word of a sentence. (kidding) Cheers!
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
Car: 2007 335i
Default 03-23-2013, 07:04 AM
Terry adviced me to go ISO, any input on how to do the wastegate i would appriciated it.
albertc albertc is offline
Car: 2007 335i
Default 03-23-2013, 07:05 AM
I removed the diodes and I'm running regular ISO, so if you feel like no running on beta you don't have to
JB4 G5, DCI, **, IC, Del Cats, Walbro LPFP, Meth
Default 03-23-2013, 11:05 AM
lmfao damn good to know. logs coming shortly. map 7 soooo strong like Jedi force is with me.
robc1976's Avatar
Car: 2007 335i
Default 03-23-2013, 12:06 PM
do you have RB's?
