VinnyD VinnyD is offline
Car: 2008 Bmw 335xi
Default Need help reading this log please - 09-21-2019, 01:36 PM
I think I need to upgrade my fuel pump next. First and second gear never misfires. But at the end of 3rd gear at higher RPM’s it almost always misfires usually cylinder 6. Can someone please help guide me.
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 09-21-2019, 09:11 PM
Your lpfp is in the 40ís and your hpfp numbers arenít good either. I would upgrade ASAP. Your trims are maxed too. I would only run map 1. What fuel are you running?
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
BMS DCI - BMS OCC - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5Ē RACE FMIC
VRSF DPís - VRSF INLETS - VRSF OUTLETS
BMS PEDAL TUNER - RB PCV VALVE - 3.5 BAR TMAP
NGK 97506 @.022 - BMP STAGE 2 LPFP - H&R SPRINGS
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
19Ē 666m WHEELS - HANKOOK VENTUS V12 EVO 2ís
Car: 2008 Bmw 335xi
Default 09-22-2019, 08:09 AM
I was running 93 with about 4-5 gallons on E85. My map 1 works terrible with my upgraded turbos for some reason. I use JB4 with a MHD hybrid turbo backend flash
