Galaxybrooks Galaxybrooks is offline
Car: 2008 BMW 335i Sedan w/ sport pckg
Default Major Fuel Leak From Injectors After Swap: pls help - 03-05-2019, 02:04 PM
Bought a set of 6 used index 12 injectors from someone off the forum who was about an hour drive away. Followed the normal DIY for swapping with no problems. Coded the injectors with INPA, they all had the same flow calibration numbers ??, and after two long cranks the engine flooded and gas came pouring out from under the car.
Spark plugs and coils soaked gas all over the top of the engine block by the injector holes. No spray from the gas lines to the injectors and all electronics ok
Question is has anybody heard about or seen fake injectors....or did I miss a step. Seems like a lot of gas for just two long cranks.
Any advice or input is appreciated and I'm hoping the engine is ok if I let it evaporate for a day or two.
DeepEddy's Avatar
DeepEddy DeepEddy is offline
Car: E92
Default 03-28-2019, 05:49 PM
Replace your seals.
DeepEddy's Avatar
Car: E92
Default 03-28-2019, 05:51 PM
Wait what same , same calibration numbers. That makes no sense, i think u were takin for a ride after u took a ride. I just bought new ones and the calibration numbers are closd but not the same
eligard eligard is offline
Car: 2007 335i
Default 04-24-2019, 11:32 PM
Have you ever resolved the issue?1
