schmidty335i's Avatar
schmidty335i schmidty335i is offline
Car: 2012 335i 6mt
Default e92 cluster power out of car - 03-23-2019, 01:07 AM
does anyone know how to get the cluster powered up outside of the car? i tried to use a 12v 5 amp supply on pin 9 (positive) and pin 18 (negative). the needles move for a sec but the digital display never comes on.
2012 335i M3 Kombi, FBO, JB4, BMS meth kit with direct port injection, Spool Performance FX-150 HPFP, Stg2 LPFP, Mfactory SMFW, PS2 w/ inlet and GFB DV
Car: 2012 335i 6mt
Default 03-23-2019, 03:40 PM
i found out how. i am supplying it with 12v at 5amps i put positive on pin 9 and negative on pin 18. then you just push the mileage reset button and it turns on and will display your mileage on the cluster.
eligard eligard is offline
Default 04-23-2019, 07:28 PM
Good to hear you figured it out. Should be good future reference.
