kaltrin maliqi kaltrin maliqi is offline
Car: Bmw 335i xdrive
Default Code 133E10 valvtronic system: disabled, to frequent verstellfehler? - 03-17-2018, 03:10 PM
Can anyone give help me why this code is showing on my f30 2013 335i Xdrive.
What happened: merging onto a busy street stepped on it, it downshifted and the car didnít like it, engine light turned on with drivetrain malfunction continue driving. I stopped and checked the codes thru the jb4 app. There will be a picture with what I saw. I deleted the codes, it turned off the cel but the drivetrain malfunction was still up. I shut the car off completely, turned it back on and no check engine light and no malfunction however when I check for codes this 133E10 code still stays there. There is no power loss or any indication that thereís something wrong.
Any help on how I can fix it would be appreciated
Default 03-17-2018, 05:05 PM
Sheered off the VANOS bolts maybe? Probably something mechanical.
Default 03-17-2018, 06:17 PM
Thanks Terry! You think itís save to drive on it?
DBMatt DBMatt is offline
Car: BMW M135i PWG
Default 08-18-2018, 12:25 PM
I have the exact same issue right now.
M135i is mine, 133E10 code. Sometimes goes away for a day or two and then back again.
No loss of power, no noticeable issues other than the CEL and error code itself.
Did you get to the bottom of the issue?
Default 08-18-2018, 12:36 PM
I actually have not fixed it and have been driving with it as is. I havenít noticed anything other than maybe a couple mpg lower. But the I only get the 133e10 code. Iíve probably done 10k miles on it and no issues whatís so ever. Iíve read maybe if we reset the valvtronic it can fix it, I think if not wrong it can be reset at the dealer or if you have one those tuning apps, Iíve been meaning to download the app but it doesnít work Apple products so been to lazy to look for an android phone or tablet to download the tunes and stuff etc. if you do find a solutions please let me know
Car: BMW M135i PWG
Default 08-18-2018, 01:11 PM
I actually have not fixed it and have been driving with it as is. I haven’t noticed anything other than maybe a couple mpg lower. But the I only get the 133e10 code. I’ve probably done 10k miles on it and no issues what’s so ever. I’ve read maybe if we reset the valvtronic it can fix it, I think if not wrong it can be reset at the dealer or if you have one those tuning apps, I’ve been meaning to download the app but it doesn’t work Apple products so been to lazy to look for an android phone or tablet to download the tunes and stuff etc. if you do find a solutions please let me know
Wow well thats a positive! I was worrying I was going to damage the engine or something.
I have also read the same that it can be fixed with a re calibration by a dealer for a small amount. I may well try this. I have also read that some people (on E90 forum) have actually disabled the valvetronic system on purpose in order to improve throttle response (apparently). So this is all very bizarre, I'm not sure whether the car actually needs the valvetronic system or not!
I have come to the conclusion it works basically to improve fuel economy so the cam is not always on high lift under normal driving conditions thus saving fuel. However with the system disabled, the car goes into a fail safe mode, increases the cam lift to max and runs on high cam all the time, hence the extra fuel consumption.
I compare it a little to the Honda VTEC system (I have experience with Honda). Low cam below 6k rpm, high cam above 6k rpm - all in order to improve fuel economy. I guess its like having a Honda in VTEC all the time.
I'll let you know what happens.
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default 11-29-2018, 12:11 PM
I have this error too cant clear code ill try reset adaptation from mhd apps
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
dror135's Avatar
Default 12-02-2018, 08:21 AM
i fix it !
Default 03-22-2019, 08:50 AM
Originally Posted by dror135
i fix it !
Great to hear that. did the adaptation fix it or was it something else?
