(#851)
Joe2k10's Avatar
Joe2k10 Joe2k10 is offline
Car: 2014 BMW 535i
Default 10-06-2018, 09:28 AM
I tried flashing JB4_F_EWG_PUMP_10.bin
Joe2k10's Avatar
Car: 2014 BMW 535i
Default 10-06-2018, 02:03 PM
Estoril_AJ Estoril_AJ is offline
Car: F30 335i
Default 10-07-2018, 02:34 PM
Sure, you can throw them here or in the support forum.
Terry, any advice? See above post with .csv files and virtual dyno readings. I'm thinking NGK 95770 spark plugs and attempting to gap them to .020 or .022, due to rough idle at times and 50k miles on the oem ones. Thoughts?
_____________________________________________
2014 335i xDrive | aFe Intake | Dinan Exhaust | E85 Mix |
MHD + JB4 BEF {Map 2,6,7} [EWG_E85_10} (8/2/2018 MHD Map)
TwistedX TwistedX is offline
Car: 2015 BMW X6 35i
Default 10-07-2018, 11:28 PM
Terry, I have the MHD and JB4 BEF and I read something about leaving the OEM/Catted pipe box empty/unchecked should suppress the engine light but mine is still illuminated. Am I doing something wrong?
Also if I go meth with 50/50 can I flash the Race BEF file and run map 3?
Project Succubus - 2015 Estoril Blue M235i F23
Sponsors: SoloWerks, Extreme PowerHouse, and AEM Intake Systems
smartsteve smartsteve is offline
Car: BMW 335Xi F30 N55 2013
Default MHD - 10-13-2018, 05:09 PM
I finally pulled the trigger and installed MHD and installed BEF pwg3.
I did a short pull that I have attached. Could someone tell me if this is running the way it should or if I need to make any adjustments. Thanks.
Drag_n54's Avatar
Drag_n54 Drag_n54 is offline
Car: '09 BMW 335i
Default 10-14-2018, 04:18 AM
I still get the CEL for ********* but only if I'm cruising at a set speed for a period of time. I use the race flash and run meth but I also run e30/e40. Don't think you'll be running meth all the time so might want to stay on pump flash. Can always log and see if it's beneficial to do so
F30 335i PWG AT l MHD Stage 2+ E30 l WMI l VRSF D.P l VRSF FMIC l VRSF C.P l FTP Outlet l FTP Inlet l GFB DV+ l OCC l NGK 97506 .020 l Stage 2 LPFP l Resonator Delete w/ Stock Muffler
Default MHD Track Day - 10-14-2018, 06:46 PM
I did a short pull that I have attached. Could someone tell me if this running the way it should or if I need to make any adjustments. Thanks.
Just want to say, since yesterday that I installed it and today, full day at the track, I have thrown no drivetrain malfunction codes that I was constantly getting before.
My best run at the track was 12.663 at @ 109.63 this is the best since last year for me.
I am attaching 4 of my runs, perhaps Terry you can let me know if I am running correctly or if I need to adjust anything.
Appreciate your assistance
Default 10-18-2018, 08:55 PM
Logs look OK overall.
I'd shift around 5500rpm for maximum performance on the stock N55 turbo.
Also change open loop to 0 to get trims up.
Default 10-19-2018, 06:16 PM
Thank you for that, I found to change the open loop in the app but where do I set the shift point. I have auto 8 speed 335xi F30.
Drag_n54's Avatar
Car: '09 BMW 335i
Default 10-20-2018, 03:27 AM
You'll have to shift manually at 5500. I have my shift indicator in the app set to that. PWG problems
Marlinman's Avatar
Car: 335i coupe 2010
Default 10-20-2018, 06:24 AM
go get a PS2 and shift at redline!
Default 10-20-2018, 07:16 AM
Sorry, what is PS2
Drag_n54's Avatar
Car: '09 BMW 335i
Default 10-20-2018, 07:39 AM
Please believe that's in the works. This my daily so no rush. Saving for my project car
Sorry, what is PS2
Pure Stage 2. Upgraded turbos
alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Default 10-21-2018, 02:08 AM
Terry, any updates on the n55 pwg maps? Is there going to be a pump gas map?
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
Car: F30 335i
Default 10-21-2018, 09:35 AM
Any advice? I'm almost a page up with logs and virtual dyno. I tend to hit a CEL or a Drivetrain Malf. more often now, possibly due to LPFP? I run E30 consistently these days. Attached is a photo of the most recent CEL on E30, Map 7, BEF EWG_RACE_7e. It happens on Map5 at times as well
Jmwilson125 Jmwilson125 is offline
Car: M235i
Default 10-23-2018, 07:45 AM
Does this work now for the n55 ewg?
2016 M235i EWG N55 - Empty exhaust - Charge Pipe - Intake - FMIC - WMI kit dual cm5+cm7 - JB4 FF and EWG Wires.
Drag_n54's Avatar
Car: '09 BMW 335i
Default 10-23-2018, 08:05 AM
EWG holds boost or holds boost better to redline
Car: M235i
Default 10-23-2018, 08:14 AM
I meant do the shift lights in the app setting work now for the n55 ewg. I thought they didn't work, and that it was being worked on.... But I haven't checked in a while
crogs335 crogs335 is offline
Car: '13 F30 335i PWG
Default 10-23-2018, 08:20 AM
Terry, I am having trouble installing the BEF. Here's what I've done so far:
-Backup stock map
-Flash MHD Map 0
-Turn FutureUseD #6 "on"
-Downloaded 8/2/18 maps from this thread
The problem is that BEF maps PWG1, PWG2, and PWG3 do not appear. It seems this is because the files are in .xdf format, because all of the maps formatted in .bin show up. What do I need to do?
Of the attached photos, one shows the folder of maps saved on my android device, another shows the maps available to flash via MHD app.
Default 10-23-2018, 08:31 AM
You copy the BIN you want to look to the root directory of your device and then select in MHD app to flash. XDFs should not be copied over they are not flash maps.
Default 10-23-2018, 08:51 AM
So how can I flash PWG1 PWG2 or PWG3? Those are the maps that apply to me. I only have a **, CP, and JB4 on map 5 with ~ E30 on every other fill-up.
Please excuse my ignorance, Iím brand new to all this.
Drag_n54's Avatar
Car: '09 BMW 335i
Default 10-23-2018, 09:40 AM
While in MHD, you navigate to the folder where you extracted the files. Is that what you're asking?
Default 10-23-2018, 12:01 PM
Not really. I am asking how to flash PWG1/PWG2/PWG3 maps. Terry said that XDF files are not for flashing. BUT, PWG1/PWG2/PWG3 maps are only offered in XDF format...
This photo shows the folder (open in MHD app) with all the extracted files. PWG1/PWG2/PWG3 do not show up. Am I missing something? I thought those were the BEF maps us PWG guys are supposed to run without e40+/meth/turbo upgrades.
Can I download PWG1/PWG2/PWG3 maps in .bin format? If so, where?
Should i be running a different back end map? None of the others seem to apply to my setup.
smahel smahel is offline
Car: 335Ci
Default 10-23-2018, 12:07 PM
These are not maps but definitions for tuner program "TunerPro". PWG maps are JB4_F_PWGx_xxx_x.bin
Default 10-23-2018, 12:20 PM
So then which do I use? Terry said specifically:
"There are several F series models that each require a unique map. To differentiate them we've labeled each file:
EWG: 2014+ EWG models (except M2 and S55 models)
S55: 2015+ M3/M4 models
PWG1: For the PWG models I'm not sure yet which cars need which one, but MHD won't let you load the wrong one. Most cars seem to be PWG2.
PWG2:
PWG3:
M2: They have their own dedicated map set"
To me, that sounds like "run PWG1, PWG2, or PWG3". Without those options, I'm left with "JB4_F_PWGx_E85_x" and "JB4_F_PWGx_RACE_x"
I am not running race gas, and I only run 30% E85 or less mixed with pump gas. I do not see any pump gas options for PWG.
2013 F30 335i (PWG) | ER chargepipes | ER down pipe & custom exhaust | ER FMIC | ECS OCC | GFB DV+ | JB4 map 5 w/ MHD BEF
