(#1401)
Default 09-04-2018, 09:19 PM
FOL is global for all maps including additive maps, but there is a minimal benefit/impact if trying to adjust the AFR itself. Even if you reduce the trims AFR will stay where it's mapped out for the DME BT.
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 09-04-2018, 09:49 PM
Perfect thanks Terry!
BMW After BMW
Car: BMW M240i
Default 09-05-2018, 05:03 AM
I seriously doubt FOL adjustment requires the FF wire. FOL is likely active on all maps - ask in the support thread. EWG is for Map 6 if you’re messing with Duty Bias and other wastegate-related settings. Ask Terry if you want the gory details.
Default 09-05-2018, 03:12 PM
You need the FF wires to adjust FOL, without that then FOL numbers don't mean anything.
dRDiesel's Avatar
Car: BMW
Default 09-05-2018, 03:47 PM
The FF wires lowered my fuel trims on Map 3 with FOL set only on 65. Tested and logged earlier today.
Car: M140i
Default 09-05-2018, 10:06 PM
Installed my JB4 today on my Shadow edition 140i, using the dash menu the mph needle was jumping all over the place. Ie, when 1 was selected it was jumping between 0-2 and bouncing up and down.
Is this a known issue or is something up with my unit/install ?
JBoe JBoe is offline
Car: M240i
Default 09-05-2018, 10:52 PM
Ok, we know that FOL adjusts fuel if you have harness installed and is active on all maps. I noticed the immediate change when installed.
I want to install EWG, but have no issues with boost thus far. I don't want the install to cause changes and assume it will since FF install did. How do we zero it out so it won't have an effect once installed? I'm assuming I may need EWG for future WMI install. Maybe it's not... please advise.
BMW After BMW
Car: BMW M240i
Default 09-06-2018, 07:29 AM
I run WMI without the EWG harness connected and at lower additives (30-35) it’s perfectly fine. That’s not to say it won’t help - just you don’t generally “need it” for WMI. I do want to reconnect it at some point to see if it makes a difference in building or holding boost.
Not sure on the other question on “zeroing out”.
MW3Designs MW3Designs is offline
Car: 2008 335i Convertible
Default 09-06-2018, 04:40 PM
I’m dusting off the n54 335, and it’s been a while. Trying to figure out what firmware version I am running on the JB4, was looking for info on my current version, only thing I see is Rev 3.6 settings in the app settings.
BMW After BMW
Car: BMW M240i
Default 09-06-2018, 04:53 PM
This is sorta the B58 thread...
Default 09-06-2018, 07:03 PM
Thanks for pointing that out, will repost in the right place.
Car: M240i
Default 09-06-2018, 08:51 PM
Quoting myself... still needing an answer. lol!
Car: M140i
Default 09-07-2018, 04:20 AM
Uploaded the latest firmware and this is still an issue, also tacho does not move, instrument cluster is the 6WA I believe, anyone else got this issue ?
Car: M240i
Default 09-07-2018, 06:56 PM
I did on my M240, but that's known issue on our displays. Other than that, I've never seen such an issue. Can you connect the laptop or Bluetooth and make changes? Is it just the BC (dash integration) that's got issues?
Default 09-07-2018, 08:02 PM
Yes per the other threads we don't have the gauges active yet for those, we're working on it though!
dRDiesel's Avatar
Car: BMW
Default 09-11-2018, 07:50 AM
Hey Terry any sort of ETA if you had to guesstimate with the JB4 back-end flash?
Default 09-11-2018, 08:07 AM
MHD says 2-3 months on the flashing tools. So shortly after that.
dRDiesel's Avatar
Car: BMW
Default 09-12-2018, 08:12 AM
Question about the EWG pigtail. I have the pins installed into the JB4, but not plugged into the car. Besides throttle closures, does this pigtail some what help maintain better boost control rather then having it fluctuate under load (example: 15psi then drops to 14 psi then creeps up to 17 psi then drops to 16 psi during a log). I don't experience throttle closures at all, but the boost does fluctuate at times @ WOT.
Default 09-12-2018, 08:13 AM
If it's not attached to the wastegate to change dutycycle it doens't do anything.
dRDiesel's Avatar
Car: BMW
Default 09-12-2018, 08:15 AM
OK so i take it as this pigtail will some what help maintain a "better" boost curve on my logs. I was under the impression that it helped the *****l3ss folks with throttle closures and overboost conditions.
Default 09-12-2018, 08:23 AM
I don't know what effect it might have on your car or whether you need it at all. If boost is over or under target then one benefit is being able to bring it closer to target.
BMW After BMW
Car: BMW M240i
Default 09-12-2018, 10:53 AM
For me (B58 M240i with BMS intake, FF harness, 93 octane, and meth), it has helped correct overboost and create slightly smoother runs. I am sure of it because now I have it disconnected (the wire is faulty) and I am occasionally overboosting, esp with WMI/Map 7. I do currently get serious throttle closures when the car is on Map 7 when I first start driving at WOT, so I don't yet know if EWG control can help with throttle closures, but I am planning to fix the wire and then re-test, as a datapoint. The closures get better as I drive longer. I'll post logs when I get the thing reconnected.
HIRRS-ZN's Avatar
HIRRS-ZN HIRRS-ZN is offline
Car: F30 320i
Default 09-12-2018, 12:43 PM
Hi Guys,
I have a 320i B48 and just recevied my JB4 with the Fuel and EWG connectors. All connected with no issues car is still stock, am going to install a ******** and Exhaust later on.
I would like to find out which Firmware version i have? I am using the Bluetooth app and the Firmware ver it shows is 58/9//5
Is this the latest version or should i update to BMW_B48_B58_OBDII_9_T4.hex ?
Also, are there any settings i need to change in the user adjustments ? Default Wastegate Pos is Zero, is that normal?
Thanks,
Default 09-12-2018, 02:20 PM
The latest firmware is in the first post, and we have another test version we're kicking around we plan to post soon. If just using maps 1-3 no need to update it at the moment.
JDARCO JDARCO is offline
Car: 17’ BMW M240xi
Default 09-12-2018, 05:44 PM
Any chance this update will fix the issue some of have been having where the jb4 isn’t providing data? Been taking it easy on Map 1 until I can properly log and know the car is running properly, it’s killing me!
