(#801)
Default 09-05-2018, 08:37 AM
Not yet but we're also weighing some changes there also.
alo0oy215's Avatar
alo0oy215 alo0oy215 is offline
Car: 2012 f30 335i
Default 09-05-2018, 08:40 AM
Thatís great 😍 waiting for your updates
With every update the car becomes better and smoother and pulls harder
N55 powerd 335I sedan :
1- kettyless D P
2- CP
3- Custom exhaust
4- JB4 + FF wires
5- BMS F30 N55 Performance Intake
6- BMS WMI KIT
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 09-05-2018, 10:05 AM
I'm waiting for PWG upates as well...not patiently though, never patiently!
2013 BMW 335xi F30 N55 PWG
Summer '19 install: Speedtech BW 8374/PI & Tune by Trebila
Kingofqueenz788 Kingofqueenz788 is offline
Car: F80
Default 09-05-2018, 05:55 PM
Do u know what is included in the monitors license ?the setting that I care abt is the cel delete when I put my ********* in I donít want to have a problem with inspections
spammer's Avatar
spammer spammer is offline
Car: 435i
Default 09-05-2018, 06:23 PM
I can't speak for MHD but the JB4 module provides all that and more already. So i assume if you're already here you have the JB4.
Abear Abear is offline
Default 09-06-2018, 07:41 AM
Terry, I updated to the 16 test firmware yesterday and pulled a log, and running the EWG PI BEF.
135idct 135idct is offline
Default 09-07-2018, 07:21 PM
any plans for DPMI file? or use same the E85 file?
Default 09-07-2018, 07:47 PM
Looks solid to me. Any issues? Maybe raising auto shift reduction to say 30 would get boost down a touch more post shifts as EGT builds.
2sdays 2sdays is offline
Car: 2015 M235i
Default JB4_F_EWG_16_TEST5 & PUMP BEF - 09-08-2018, 11:56 PM
Hey Terry,
Updated to Firmware 16 and pulled a log for you on Map 2 (2018-09-09) - I'm also running the EWG PUMP BEF.
Prior to this I had ran JB4 only on Map 2 and Payam confirmed it was all good (2018-08-27).
Initially, I had flashed the EWG RACE BEF because I had thought it was for 93 and / OR 93 and e85 mixtures. No logs from this, I did some more reading and then flashed it down to PUMP to be safe.
Notced a couple of things:
- AVG IGN dropped from 5.9 to 3.3 (I'm guessing because I flashed RACE first), is this normal?
- As you noted, the BEF did change the targets from the additive to absolute. What should the targets be for Map 2?
- I reset my FF to 60, it's gone up to 95 - what does this mean?
- Got 102A22 MAF, air mass too high, again. I get this once in a while, easy enough to clean the maf and clear the code.
'15 M235i 6MT - Shell 93 oct
- K&N Drop-In
- VRSF Charge Pipe
- Fabspeed Sport c@t
- M2 OEM Spark Plugs stock gap- changed out from stock chasing down a misfire, none since.
Let me know if you need anything else on my end.
Thanks in advance! Appreciate the support!
Default 09-09-2018, 08:29 AM
Originally Posted by 2sdays
Hey Terry,
Set FUD bit6 on. You changed FUD to 6, which is entirely different.
Car: 2015 M235i
Default 09-09-2018, 11:02 AM
Is there something I'm missing here? When I change bit6 it changes Future Use D to 64. Is that different from FUD?
Default 09-09-2018, 01:19 PM
Good then save.
Car: 2015 M235i
Default 09-09-2018, 03:20 PM
Good then save.
Hm, did that and pulled a short log to only check the FUD value - itís still at 6. Iím going to test and go back to firmware 15 and see if it sticks at 64.
Does the log with FUD at 6 not look like itís supposed to then?
Car: 2015 M235i
Default 09-10-2018, 05:57 AM
Hey Terry,
I'm starting to think it could be an LG specific issue?
I double checked the FUD from the log using my iPhone 7 and it'll show up as 64 vs. the 6 I'm getting when I pull a log from my LG G3. The G3 is an old phone I pulled out just for JB4 gauges, logs, MHD, etc.
I updated EWG 16 TEST 5 from my iPhone just to make sure, and confirmed bit 6 was on in both apps.
Dturboman's Avatar
Dturboman Dturboman is offline
Car: BMW M4
Default 09-11-2018, 07:46 PM
Any details on the updated boost targets (since they are now absolute) for all maps after BEF?
Default 09-12-2018, 02:14 PM
Depends on the JB4 firmware. N55 EWG? S55?
Dturboman's Avatar
Car: BMW M4
Default 09-12-2018, 03:23 PM
S55, running the latest test 10 firmware.
Car: 2015 M235i
Default 09-13-2018, 06:21 AM
Also interested in the answer for this - N55 EWG.
and according to...
Note once installed and the JB4 is set to BEF mode (FutureUseD bit6 on) the boost targets on each map will change to higher boost absolute maps designed specifically for use with BEF maps. Actual boost targets will vary by JB4 firmware version.
...does the BEF change Map 2 from 'additive' to 'absolute'?
I can see in my Map 2 logs the targets have changed from the < 6 psi to > 10 psi - does this mean the EWG harness becomes more of a necessity as it is for those running say Map 5 + JB4 only?
Default 09-13-2018, 03:33 PM
S55 M3/M4 BEF Maps are posted in their own thread now: https://www.n54tech.com/forums/showthread.php?p=605637
siim138's Avatar
siim138 siim138 is offline
Car: F10 535i
Default 09-14-2018, 02:50 AM
Hello!
Please could somebody say, why I'm still getting the CEL?
I run with c.less d. pipe and the only code in DME ise about catalytic converter.
With the latest ISO FW update I disabled passive delete, should I enable it?
With the latest PWG1_RACE_3 no moore low boost error - that is good!
2011 F10 535i M-Sport PWG // Deep sea blue //
//JB4 PWG_INT_13 + BMS BEF PWG1_RACE_3 // M Performance mufflers// 3,5" cless dowpipe
Endeav Endeav is online now
Car: BMW M2
Default 09-14-2018, 07:19 AM
Posted some new N55 F EWG firmware for you BEF guys to test out. I think you'll like it.
JB4_F_EWG_16_TEST5:
1) Revised logic for absolute boost targeting maps resulting in smoother part throttle operation and the ability to set boost by gear values lower than the flash target.
2) Adjusted map4 to a low boost / VALET / safety map with a target of 8psi.
Curious, is Map 3 considered an absolute boost target map with the BEF and FUD 64?
Default 09-14-2018, 08:31 AM
Yes the WMI progressive map is absolute target and transitions between a low and high boost profile based on the meth additive setting and WMI flow.
Default 09-16-2018, 08:33 PM
How is the logs?
running big turbo n55 EWG EFR8374, pump 93 + 100% meth two nozzle
not tuned, EWG_RACE_BEF
20psi , OEM spark plugs, OEM fuel system, OEM intake box, OEM exhaust
Default 09-16-2018, 08:46 PM
Originally Posted by 135idct
How is the logs?
Tuning looks good.. But, fuel pressure is a bit of a concern. We may have to lean it out if you can't get more meth volume. What nozzles?
Default 09-16-2018, 08:53 PM
Aquamist HFS-4 ( 1.2mm + 1.0mm ) total flow rate ~1270 cc/min
it's not tuned, ur BEF RACE only, and disabled Auto FF learn set it to 100, so boost not go over target after many WOT pulls .
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
