RadarContact's Avatar
Car: 2010 E60/535i AT ó FBO+WMI
Default Battery registration?? JB4 nor MHD do it? - 01-04-2018, 08:19 PM
Neither the jb4 or mhd will register a new battery? Damn...
Do I need to buy Carly, etc type programmer for this?
// Radar //
2010 535i M-Sport w/Sport AT, Alpine White w/Natural Leather, type-135 wheels w/spacers & Coilovers --- JB4 G5 ISO Trebila (Map-6/BEF) Custom Tune, Custom Meth Setup, VRSF 3" free-flow D/Ps, MMPe DCIs, Wagner 1060 Stepped FMIC, VRSF Chargepipe/Tial BOV, BMS Oil Cooler Valve
NA55 NA55 is offline
Default 01-04-2018, 09:42 PM
I just changed my battery and used this to register it..
http://bimmersoftware.com/bmwlogger
Default 01-04-2018, 10:16 PM
We have the battery adaption reset in the JB4 menu system.
keyap keyap is offline
Car: N55 135i
Default 01-05-2018, 09:55 AM
Are you changing out on a like for like basis?
If 'yes' then you just need to register. If 'no' then you need to change the battery type to the new one and register. Not exactly sure what the registration does though as the charging is done via a learned PID system so it should simply adapt - I'd guess the adaption reset in the JB4 does the same but quicker.
Software within the package used for coding (NCSExpert etc, which can be downloaded for free) plus the right cable can do both.
[SIZE="2"]UK 2011 - E82- 135i - N55 - DCT
[B]
Default 01-05-2018, 11:20 AM
Really? I have the laptop version (Windows, but donít know which version of the software - prob about a year old) and also a version on my Android tab, for logging. I donít see it on either.
I hate always being the dumbass...
// Radar //
Default 01-05-2018, 11:24 AM
Well, I just had to buy a new battery for my e46, but we prob won’t be keeping that car for too much longer, so I was thinking about putting the new one in the e60 and putting the e60’s “old” battery in the e46 — assuming they are the same size which I think they are.
If that’s the case I’ll only have to register a new, same type battery in the e60.
Default 01-05-2018, 11:54 AM
// Radar //
It's an in dash option on menu 1.
fnne99 fnne99 is offline
Car: 2008 335xi
Default 01-05-2018, 12:42 PM
I can attest that if you replace a very worn out battery with the same size and ah, you will need to register the new battery. I didn't register my new battery and I kept having weird electrical issues (radio not turning on, clock still losing time, etc) even with the new battery. After I used the jb4 to register it, all those issues are now gone.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 01-05-2018, 01:14 PM
I think JB4 and MHD battery adaption reset methods work if the new battery is exactly the same as the old. Since it just tells it there's a new battery, and (assuming) doesn't reset the type, ah charging map, etc.
If going from flooded lead core to AGM, or vice versa, or if old battery is really worn out, you should use Carly, ISTA-D (Reingold), Ediabas Toolset32, or NCS Expert. I thought INPA could do it too but not sure.
See here for good info on this and options/steps:
https://bmw.***********.com/document...new-battery.6/
EDIT: url is masked ... not sure if there's an issue with posting links to the SS forum ... if so, Terry et al, my apologies.
2017 AMG C63 -JB4
2009 535i - 548whp - sold
Default 01-12-2018, 12:52 AM
Update:
Turns out my battery 2as good but severely discharged. Surprised it kept starting the motor after seeing how bad it was. Even in itís discharged state it was still putting out over 896 CCA, and alternator is good too.
Whew.
My JB4 software must be too old for the battery reset:
