Odan.be Odan.be is offline
Car: BMW 335I 2007
Default OEM DMFW how much can it handle - 10-22-2017, 07:57 AM
How much power/torque at higher RPM's can the OEM DMFW handle before it starts giving misfires?
Got full bolt on with inlets and custom stock frame turbo's (local shop) stage 1ish...
so rougly how much Psi ?
thx
Andrew_Rs's Avatar
Andrew_Rs Andrew_Rs is offline
Car: Bmw Z4 E89 35i
Default 11-02-2017, 11:15 PM
thx
I don't think that you will have problem on any psi with stock turbos, because these turbos start to dying at high rpms..
treehouse treehouse is offline
Default 11-03-2017, 01:03 PM
For me misfires were not an issue, however, I did have a bit of slipping at around 80k miles with brand new stockers on E85 BEF with E50 and Map 7. Replaced with a new DMFW and 550i clutch and no slipping.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 11-07-2017, 06:50 AM
I think you'll only encounter flywheel issues with big singles and stage 2 hybrids.
The guys who had the timing flatline drop all seemed to be around that level of power.
I have some misfires in cylinder 5 and 6 at 26 psi on GC Turbos with port meth injection. Trapping qtr mile around 128mph with the misfire. If that power level makes sense
thegailway's Avatar
thegailway thegailway is offline
Car: 2007 335xi 6MT Sport
Default 11-07-2017, 03:32 PM
That makes 2 of us. FBO, inlets, meth, stock snails
2007 335xi E90 6MT, Sport Suspension, Cobb, AR *********, MMP Inlets, 335is clutch, DCI, CDV delete, ETS FMIC
thegailway's Avatar
Default 11-07-2017, 03:47 PM
The DMFW throws false misfire codes. It does not actually misfire. It's the way BMW decided to "sense" misfires that is the real problem.
Andrew_Rs's Avatar
Car: Bmw Z4 E89 35i
Default 11-07-2017, 03:54 PM
That's right it's a false missfire but it's a missfire for the knock sensor, somake sensor less sensitive isn't the right way, cause in cause of a real missfire the car will not cut
AWSAWS's Avatar
Default 11-07-2017, 04:56 PM
Under high torque the flywheel can vibrate (poor balance) or stretch(dual mass) from the rotational forces acting on it. That causes the crank position sensor to see a variance in where it is and what it should be. That confuses the car causing it to think there are misfires. The variance can interfere with how the cars ignition system reacts.
Default 11-07-2017, 05:07 PM
Normally problems start around 550whp.
E90Ryan E90Ryan is offline
Default 11-07-2017, 08:36 PM
It goes fairly soon just being fbo-stock turbo. I'd say to consider Stage 2+ with single mass fw if you want to be 400+
NA55 NA55 is offline
Default 11-07-2017, 08:46 PM
I think you're right. I've noticed that misfires are more prevalent on high wtq tunes with the DMFW.
