primamateria's Avatar
primamateria primamateria is offline
Car: 11' 335i xDrive e90
Default Question - Base Duty Cycle - 04-04-2017, 02:56 AM
I've read quite a few posts regarding menu 12/duty cycle, and notice the values on the iso firmware thread mention settings from 2-3.5.
Whole reason I'm asking this is because I was flipping through the menus on the wheel yesterday and noticed my menu 12 is set to 0? Is it supposed to be that low?
To quote T from another thread:
For the N55 it doesn't really matter much. The nature of the factory twin scroll turbo is to make around 3-4psi regardless of base dutycycle setting. So you'd only adjust it if you have some drivability issue.
So should I just leave it at 0 then? Thanks
11' 335i xDrive e90,
JB4 ISO Map 7 @ 20psi, ISO_14 Firmware, BMS/MHD e85 BEF, xHP Stage 3 TCU Flash, Flex Fuel Adapter, Rev3 Connect-Kit, 50% e85 mix/93 octane, K&N drop-in filter, ER Chargepipe, JB4 CAN-flap disabled, VRSF DP, VRSF 7in. FMIC,
Default 04-04-2017, 08:12 AM
Doesn't really matter for E series N55 ISO since the turbo builds 3-4psi with no duycycle at all.
