(#176)
N54QC N54QC is offline
Car: 07 BMW 335i
Default 05-14-2016, 07:44 PM
Should wastegate adaptation being disabled while dialing in DB? Also after final adjustments are made to DB, should the FF RPM gain be deselected?
IBND335i's Avatar
IBND335i IBND335i is offline
Car: 2007 BMW 335i coupe
Default 05-23-2016, 02:20 AM
Heres a log for you Terry. These are hexon rr700s, fbo, inlets and a stage 2 lpfp .
2007 e92 auto
Jb4/dci/e85blend/e85flash/fuel-it stage2
12.53 @ 114
after ***: 11.92 @ 117.98
Bumbuclat93 Bumbuclat93 is offline
Car: E92 335i N54
Default 06-05-2016, 10:15 AM
Here's some logs on e85 hybrid flash. E60 mix. Fbo Vargas stage 2, inlets, stage 2 lpfp
Default 06-05-2016, 10:56 AM
Looks OK at first glance. Might not be a bad idea to test the KR flash time option at that lower boost level on E60.
Bullitt1841's Avatar
Default 06-15-2016, 05:03 PM
Originally Posted by antoniogaj
I need some assistance on how to set everything up. Tried taking it for a log in Map 2 with a Hybrid E85 Backend Flash and it felt very sluggish, then the half engine light came on. Is there an email that I can get in contact with one of you?
http://www.n54tech.com/forums/forumdisplay.php?f=35
TBM TBM is offline
Car: 2007 E90 335i
Default 06-19-2016, 11:22 PM
Terry, any updates on hybrid-specific maps?
I just got a set of Hexon RR600s installed along with MMP inlets/outlets and MFactory LSD.
I'm still on a race backend flash from when I was with the stock turbos (running 94 octane + dual CM7 meth nozzles at 80/20 mix).
I haven't pushed the car at all since installing the new turbos, as I want to make sure everything is fine first.
2007 E90 335i 6AT - 580whp/550wtq
Car: 07 BMW 335i
Default 06-22-2016, 08:40 AM
Bump
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Default 07-12-2016, 08:43 AM
Bump
Somewhere further back in this thread it was indicated to leave wastegate adaptations alone, but disable ff rpm gain, and leave it that way.
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, ** and full exhaust, Burger Meth, MHD BEF. Auto.
snelson3003's Avatar
snelson3003 snelson3003 is offline
Car: 135I
Talking 07-13-2016, 01:49 PM
Terry,
Can you review my logs for my E35 + FBO + Inlets + VTT Stage 1 n54?
I cant seem to build boost to target in lower RPM and over-boost higher.
Everything seems to work great and if you had some adjustments for me id be super grateful!
498WHP / 516TQ : 10/29/16
VTT Stage 1 + Billet Wheel | VTT Inlets | VTT PCV Valve | JB4 G5 ISO | BMS E85 Flash | Fuel It Stage 2 | ECS TwinTake| Stett Vacuum Canisters | Hartge Stepped FMIC | VRSF ** | 91Oct w/E50 | BMS Cowl Filters | Located in Denver, Colorado - High Altitude!
Maintenance: EKPM3-DE @ 74K | Water pump & T-stat @ 70K | Valve Cover @ 50K | VTT Turbo @ 70K | HPFP @ 65K | Walnut Blasting @ 65K | 6 Injectors @ 55K | Vacuum lines @ 55K | Spark Plugs @ 75K | Boost Solenoid @ 65K
Default 07-13-2016, 01:54 PM
Logs go to the support area.
Default 07-13-2016, 01:55 PM
I don't disable WG adaption when tuning unless I need to troubleshoot some specific issue then I'd turn it right back on.
Car: 135I
Default 07-13-2016, 02:06 PM
Woops, sorry i was under the impression this was for hybrid turbos...
scobbyanddale's Avatar
scobbyanddale scobbyanddale is offline
Default 07-14-2016, 07:03 AM
i have vargas stage 1 turbos about to get the 4bar map sensor set up so I don't have to buy anotherone later... do I have to run a backend flash? going to do inlets and outlets next month. I am running about 6 gallons of e85 and full bolt on no cats no muffler. I run map 5
Car: 135I
Default 07-14-2016, 08:54 AM
Scobby,
Yes a BEF is needed with the appropriate flash per the fuel you will be running. MHD is also the recommended app for the flash loading process.
Car: E92 335i N54
Default 07-16-2016, 07:40 AM
FBO, Vargas Stage 2, Inlets, Stage 2 Fuel It, Bosch 4 bar, Map6 E85 Hybrid Backend E40-E50
Car: 07 BMW 335i
Default 07-16-2016, 09:31 AM
Would repost in the support forum but it appears your hpfp is starting to fail. Once that gets addressed, then other minor adjustments can be made. Try to go WOT from 2500 to redline.
KrS24's Avatar
KrS24 KrS24 is offline
Car: e92 335i
Default 07-18-2016, 11:54 PM
Hi guys
Is there a Pump flash for Hybrids.
Ruru chen Ruru chen is offline
Car: 2012 BMW F10 535I
Default terry help - 08-04-2016, 03:12 AM
i have some problem now ,my LOG IGN is so low ,I hope he can rise,IAT about 130~160F,i feel He can be faster!!!
my car have :
TD04HL-19T hybrid turbo
JB4 G5
AEM Water/Methanol Injection
MHD JB4 backend FLASH
Fuel-IT N54 Secondary Fuel Line Adapter with Fuel Injectors
Fuel-IT FUEL PUMP
Patrick4588's Avatar
Patrick4588 Patrick4588 is offline
Car: 2010 335i and 2006 M3
Default 08-21-2016, 06:22 PM
probably not too many logs on the Vargas GC turbos. I'm running ms109 here, as the hpfp cant keep up and I don't have port injection yet. This is a 24lb target in map 6. I have the fuelit stage 3 lpfp
Car: 07 BMW 335i
Default 08-21-2016, 06:39 PM
Yeah, your hpfp is starved. Lower boost to 21 for now until you get the fueling addressed. You need either PI or meth to help compensate. Need to look into some DB tuning also.
Default 08-21-2016, 06:48 PM
Ive got it back down on 17 actually. But it doesnt look like its affecting my trims or afr so it should be ok there for occassional race
Default 08-22-2016, 06:04 AM
I want to get the platinum port injection kit. But have to save for a bit for that. Wonder if can get the basic kit then add on later?
GregGT GregGT is offline
Car: 2008 135i
Default 08-31-2016, 02:24 PM
I'm just starting out with a set of Pure Stage 2 turbo's and JB4 and want to make sure I am setting things up correctly.
Current Mods: Pure Stage 2, FBO, RB2" inlets, Stage 2 lpfp, Fuel = 93Pump
I am currently just running MHD flash map (Stage 2+).
I am going JB4 and have been reviewing setup guides in this thread and the main setup thread and have two questions:
1. Do I first need to flash my car back to stock via MHD to effectively remove the MHD map before installing JB4, doing BEF, etc etc?
2. I plan to just run pump for the time being. Does anyone have a starter map for Pure Stage 2 turbo's on pump as opposed to starting with a basic pump map?
Car: 135I
Default 09-01-2016, 10:20 AM
Greg,
MHD flash stage 2 gave me issues holding boost over stock levels in the upper RPM range.
There are specific BMS maps for the MHD app. They are free and downloadable.
You can reflash with the BMS flash OVER the MHD flash. So you can skip the stock flash part.
For Pump flash there are no specific maps for hybrid turbos. You will need to keep an eye on timing, boost, and use DB tuning to get things inline for these turbos.
Car: 135I
Default 09-01-2016, 10:21 AM
Patrick,
To me its odd that your Stage 3 pump dips into the 50's which also forces the HPFP to drop too. Stage 3 pump is capable of much better readings...
How old is your EKPM module?
