(#2601)
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default 06-14-2016, 10:59 PM
You're at a gas station, right? Do they have a battery charger?
Blown95ImpalaSS Blown95ImpalaSS is offline
Car: 08 135i vert
Default 06-14-2016, 11:05 PM
made it home ok (and filled up with e mix on the way) but they were closed besides the pumps.
any ideas?
KrS24's Avatar
KrS24 KrS24 is offline
Car: e92 335i
Default 06-15-2016, 12:48 AM
I need a little guidance guys.
I flash the latest JB4_MHD_INA0S_PUMP to a Z4 35i.
After the write I keep getting a 2FA4 Wrong data set error and the cars engine light remains on.
Anybody had this issue before?
mkster08 mkster08 is offline
Car: 2008 335 AT
Default 06-16-2016, 03:37 PM
Anyone found their sweet spot for the exhaust burble yet?
Litebulb Litebulb is offline
Car: '09 SGM E88 135i
Default 06-16-2016, 05:47 PM
With my DP and PE, I get some burbs already so 2 sec and medium, works well for me. I tried high first, but with the top down it's too much.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
Default 06-16-2016, 06:06 PM
What are you talking about.
N54 | Build Thread
RSicks's Avatar
RSicks RSicks is offline
Car: 2010 535i M-Sport
Default 06-16-2016, 06:11 PM
God, I thought I was the only one that didn't understand.
'15 435i ///M Sport
CTS Intake VRSF CP/Race FMIC/DP/TIC MST Inlet xHP S3 3.5 TMAP Wedge Tune in process
Grip Grip's Avatar
Grip Grip Grip Grip is offline
Default 06-16-2016, 06:55 PM
Originally Posted by Blown95ImpalaSS
Hi guys, sharing from my thread to see if anyone has experience this before - hoping it's an update or setting within MHD that needs adjustment:
I'm sitting here at a gas station attempting to flash back to the MHD ijeos pump map since I will only have access to 91 octane on this road trip. The problem is that MHD is only giving me the option of what it calls a "long write" of 9-20 minutes and I'm afraid it will kill the battery.
Previously flashing between different backend maps only took 2 mins, but I no longer have that button on screen, just the 'long write 9-20 minutes' and 'options' buttons. Any thoughts? Luckily I have enough in the tank to make it home on the ethanol backend...
The same thing happened to me a few weeks ago while I was filling up with ethanol. I did the long write at the gas pump and the battery held up. Not a pleasant experience in the heat.
2009 335i XDrive (wife's)
Sold - '11 335is - N54 - DCT
Sold - '07 335i - 11.8 @ 120
Sold - '08 128i (wife's)
Default 06-16-2016, 10:45 PM
You are probably ije0s....
Car: 2008 335 AT
Default 06-16-2016, 10:50 PM
Yea I might knock medium down to soft and/or move it to one second, not sure I'll probably have to do more testing
Default 06-17-2016, 01:27 AM
With the new exhaust burble mode, aggressiveness set at high sounds too insane with my performance exhaust and *********. Especially with my top down.
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 06-17-2016, 04:17 AM
Video Pleeease...or sound are the burbles between shifts?
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF DP|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
JP.Williams JP.Williams is offline
Car: E93 335i
Default 06-17-2016, 08:35 AM
not mine, but one i found on Youtube
https://www.youtube.com/watch?v=t3Fn3H-WUTY
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 06-17-2016, 08:38 AM
Originally Posted by E30t387
All vaccum lines were replaced along with the he solenoids, did a vaccum test , found no leaks.
You around 15 psi below a normal curve, so there's definitely a leak.
Originally Posted by e91 335i
Hello. Today I finally got my TBI. I was wondering which MHD backend flash should I run if I try to hit 25psi with e50-e60 blend? Is it safe to run E85-flash or do I need a custom one?
As a daily fuel I was thinking 100% e85 and about 23 psi with MHD e85-flash. Possible? At the moment I am running about 22psi with e60 blend.
Mods: N54 6MT, JB4 G5, MHD e85, std RB's, FBO, RB inlets MMP outles, Walbro 455, healthy HPFP
Hybrid e85 map.
The BMS maps are organized this way
- IJE0S for non IS cars
- INA0S for IS cars.
So the INA0S (which is to be precise a INA0S IS map) will throw a 2FA4 is flashed on a non IS car. Use the IJE0S versions.
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Car: 2007 335i
Default 06-17-2016, 09:53 AM
Looks like there are 5 videos of Flarp mode already on youtube.
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
Car: 2008 335 AT
Default 06-17-2016, 09:55 AM
Lol flarp mode haha
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHD 1.36 and 1.37 updates - 06-17-2016, 02:37 PM
Here's the cumulative changelog for the last 2 versions:
- Exhaust burble with flash time settings (duration, aggressiveness).
- Prepended the last second of data when logging is started
- Monitor options (log channels) and the licenses store can now be used without a connection to the car (the last known VIN is used).
- Error codes: added several missing codes + German translation for all code descriptions.
- What's new menu (top right of the main screen).
No need to say the first point is far more discussed online, being a love - hate feature. I'd recommend to start with 2s and soft aggressiveness and evaluate from there, as the effects are very dependent on the exhaust mods.
And now for some results, respectively medium and hard setting on stock exhaust + ***:
k8R8k k8R8k is offline
Car: BMW
Default 06-18-2016, 07:41 AM
When I turn on the cold start noise reduction option the car hesitates/coughs/sputters a bit on cold start and I feel the car rocking a bit at idle.
I reflashed with the cold start noise reduction option off and it starts fine no cough and idles smoothly.
Any idea why this happens? Is it a symptom of a underlying issue with my car?
There were no codes thrown.
335i N54 6MT
Fuel: 98 RON
Flash: JB4 Single turbo TS
Car: 2008 335 AT
Default 06-18-2016, 08:29 AM
Same thing for me, sounded like a ghost cam tune. I mean it's kind of obvious that ALL cars go into cold start for a reason and forcing it to not go into cold start could and does act a little off.. Just live with the cold starts imo
Car: BMW
Default 06-18-2016, 09:42 AM
Thanks for the response, I don't mind the cold starts at all just thought I'd test out the MHD features.
Good to know I'm not the only one to have this issue though.
HairyWelshSteve HairyWelshSteve is offline
Car: '07 335i MSport Convertible
Default 06-18-2016, 12:11 PM
Within the TunerPro you can edit the cold start duration (stock is 65s iirc). MHD could add a slider like the min rpm?. Primarily cold start is to get the cats up to temp for emissions purposes but I'd read it also clean the plugs etc. Certainly a leaking injector fouling a plug could show up with cold start off I suppose.
| U.K. 2007 E93 335i| JB4 G5 I8A0S Pump Flash| Scoops | BMS DCI | CKS Performance 3" *** | MMP Silicone Inlets | Active Autowerke 5" FMIC | CDV delete |Fob Roof Controls | JB4 Connect rev. 3|
Car: BMW
Default 06-18-2016, 11:27 PM
If it is a leaky injector MHD may have created an easy way to diagnose leaky injectors.
But we won't know for sure until someone tests it.
Default 06-19-2016, 03:38 AM
There'll be lots of reasons for a rough idle on cold start, like VANOS & cam bearing ledge issues, plugs & coils.
Jeffman's Avatar
Car: 335xi
Default 06-19-2016, 05:36 AM
I tried 2 seconds / medium and can't hear a thing with my stock DP / stock exhaust
Default 06-19-2016, 05:58 AM
Is this option available for JB4 flashes too?
