(#526)
Default 02-23-2016, 10:03 AM
When our E92 gets back I'll work on incorporating the 2STEP and anti-lag systems together.
mike_nazz mike_nazz is offline
Default 02-23-2016, 01:01 PM
awesome, 2 step and antilag all in one can't wait.
BostonBeemah's Avatar
Car: AW 135i
Default 02-23-2016, 01:18 PM
Now thats exciting!
RIP 2008 AW/BL 135i
echoknight echoknight is offline
Car: 2007 BMW 335i 6-SPD
Default 02-23-2016, 01:56 PM
Originally Posted by BostonBeemah
Now thats exciting!
This is great.... now we will have more theater.
500hp500tq 500hp500tq is offline
Default 03-01-2016, 11:46 AM
Question, if I'm doing a 40roll or something will pressing the volume button keep me at that speed?
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
Default 03-01-2016, 12:16 PM
Close. You'll accelerate a bit.
To engage anti-lag you need to let off the gas, press the button, then press the gas. Otherwise the DME may lock it out until you let off the gas.
Default 03-01-2016, 12:22 PM
cool i was guessing that.
I can't hook at 13psi in 2nd anymore on r888's using antilaggg now. ;(
"stock"
Default 03-02-2016, 09:04 AM
Map6-1500 is a antilag specific boost cap. Comes in handy sometimes.
konvikt21 konvikt21 is offline
Car: 2008 335i 6mt
Default 03-03-2016, 01:26 PM
For hardware would this utilize the anti lag chip, 2step relay, or both? Might hold off on purchasing until these are combined
Default 03-03-2016, 01:27 PM
Strictly software stuff. Hardware is unchanged.
Default 03-04-2016, 12:04 AM
Can we permanently remove brake signal interferience with the antilag? I use to be able to brake boost with great 60ft times. Now there seems to be a 1 sec lag
Default 03-04-2016, 09:30 AM
It has a speed trigger so should not enable until ~30mph. Have a log of a launch? Does IAT drop?
Indo Rider's Avatar
Indo Rider Indo Rider is offline
Car: 135
Default 03-04-2016, 11:23 AM
Holy ****, I just read all 20+ pages to get the whole history and evolution of this feature. Makes sense. Question is how much better than traditional brake boosting is this for hybrid twins?
Next up, 30+ pages on the port and injection sticky
2009 135i 6MT Jet Black, FBO+
Vogt.ryan's Avatar
Car: 2008 BMW 335i sport
Default 03-21-2016, 08:58 AM
So this cannot be used with stock turbos and 93 octane?
***** less ***** and Intake only right now btw
Default 03-21-2016, 04:10 PM
It could be. But we suggest E85. With stock turbos I don't think there is much real world benefit as they spool very quickly on their own anyway.
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 03-22-2016, 04:50 PM
damn I was planning on getting this just to have as a fun toy but i'm fbo on stock turbos. can anyone comment if this is still "fun" with stock turbos? does the torque hit you in the back all at once when taking off from a roll?
2009 335i e92 n54 | FBO | JB4 | e85 flash |
Car: 2010 535i
Default 03-22-2016, 05:42 PM
You definitely get a burst of speed from it. There is an advantage if you are doing roll races or need a quick burst of speed to do a power move.
bmwheath's Avatar
bmwheath bmwheath is offline
Car: 07'' 335i coupe
Default 03-23-2016, 03:57 PM
Terry is this compatable with Automatics?
JB4 ISO - ***** less Dump ***** - BMS DCI - VRSF 7" intercooler - BMW PE exhaust - Charge pipe & Raceport BOV - Stage 2 fuel pump - BMS E85 Flash/E55 mix, running map7 - BMS Catchcan - Quaife LSD - 19'' Beyern wheels - Msport suspension - Aero front lip - Lux V5's - Mid kick rear spoiler - Dark tint - Msport steering wheel with M3 paddles & trim
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 03-23-2016, 05:11 PM
Yes, im running it with the steptronic transmission.
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF **|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
KrS24's Avatar
KrS24 KrS24 is offline
Car: e92 335i
Default 04-10-2016, 11:49 PM
Will this work on a Z4 35i DCT?
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 04-10-2016, 11:59 PM
Interested to know this also.
bmwheath's Avatar
Default 04-11-2016, 02:42 AM
I have it fitted but doesnt seem to work?? Foot off pedal, hold down volume button, floor pedal then release?
Default 04-11-2016, 07:40 AM
Log it if you need help.
furkanyahsi furkanyahsi is offline
Car: Z4 35i
Default 04-15-2016, 07:56 AM
I bought for z4 35i it will be work right?
Z4 35i sdrive
Default 04-15-2016, 09:23 AM
Yes, anti-lag works for all N54 models.
