Will be tackling my BMS Dual Nozzle CM5+BM7 Meth Kit install saturday, Install looks pretty easy. However, do I need to purge through the nozzles or should I take off the hose that goes to the T for the nozzles and purge from there. Also I will be running 100% methanol, what settings should I start off with. Considering I was 23psi on map 6 on stock DI
Mods: FBO Pure Stage 2 Relocated Inlets
Hey freddyamazin,
How did your install work out for you? Any caveats?
