e36luv e36luv is offline
Car: 1998 M3 GT3582R
Default Help With Limp Mode, Misfire and 30FF - 07-10-2016, 10:47 AM
I have been searching and I have made attempts to sort this on my own. My car starts up fine but under throttle it starts to stumble and wont hardly move.
I am getting the Engine Malfunction Reduced Power along with these codes through the JB4:
29D1 Misfirings, cylinder 5
29D2 Misfirings, cylinder 6
29CC Misfirings, several cylinders
29D0 Misfirings, cylinder 4
30FF Boost under target -- possible boost leak
I have also had 2AAF fuel pump, plausibility but that is not currently coming up.
My car is stock besides the JB4 on MAP 1. I have replaced all of the vacuum lines, replaced the ignition coils, spark plugs and checked the chargepipe for leaks. What is next? I dont want to just throw parts at it but I am thinking the injectors/HPFP next
08335ibmw 08335ibmw is offline
Default 07-10-2016, 03:15 PM
New plugs if they havnt been changed, check charge pipe they tend to get brittlw and break
Default 07-10-2016, 03:16 PM
Post logssssss
My phone wint pull up the link
Showdown045's Avatar
Showdown045 Showdown045 is offline
Car: 2010 335i Convertible
Default 07-11-2016, 12:12 AM
I had the exact same issue and also a strong smell of fuel. New plugs and Walnut Blast fixed the problem.
2010 335i 6AT E93,FBO, Inlets, BMS Meth Kit single cm10 (55add N20 TMAP)
Default 07-11-2016, 08:04 AM
Log added to the original post
Default 07-11-2016, 09:53 PM
I checked tonight and my car has the MSD81 DME, I haven't heard about any MOSFET issues with the 81. What else could be causing cylinder 4,5,6 misfire and the way this thing is running? I removed the jb4 and will test drive it in the morning to see if anything changes
anyone have any other ideas?
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 07-12-2016, 01:37 AM
My buddy's car did that because he didn't unhook the battery when he installed the jb4. Try unhooking batt wait 35min leave keys far away just incase don't open any doors etc try reinstall
08 E92 335i AT 20k Miles | ***** E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
Default 07-12-2016, 06:38 AM
I just drove the car with the jb4 removed and nothing changed. It ran fine for the first 5k or so mile with jb4 installed also
Default 07-12-2016, 08:52 AM
Man that sucks, only thing I can think of is what you stated injectors and hpfp get some BMW injector cleaner maybe that will solve any issues with injectors. Worked for me. I can't look at your log cause I'm on my phone but what is the hpfp number at
Default 07-12-2016, 04:52 PM
I got the 30bb code today and cylinder 4,5,6 misfire dead dme per bmw
Default 07-12-2016, 05:24 PM
Ouch! I wonder how that happens possibly jb4 install gone wrong?
Default 07-12-2016, 05:37 PM
Jb4 was out in 6 months ago , n54dme dan said that bmw mofets are barely keeping up with bmw stock tune , said once you change a tune no matter jb4 cobb or dinan it pops mofets . So im guessing its just a issue no matter if your upgrading or not bc i hear about stock bmws doing same thing
Default 07-12-2016, 05:52 PM
Mines a 2008 most happen with the 2007 dme idk if mine was a 2007 build date though
Default 07-12-2016, 06:19 PM
Mine is a 6/08 build date I would ask Terry about it, maybe it is crashed or maybe it's just a fluke. I dno if this will work. You can try the flash back to stock with mhd it will build you a stock flash bin. I dno if your ecu has a glitch in the software or if something actually burnt up. Deff ask Terry before you take that advice tho. You could find someone to do a bench flash with winkfp too
Default 07-12-2016, 06:51 PM
I didn't see your previous response. Let me.know how it goes on replacing them. Goodluck
Default 07-12-2016, 06:55 PM
Terry replied to a post about my situation and said i should bring it to a mechanic that could read the codes or somthing to that,affect . I think it was steve that pointed out it was most likely the mofets . I thank both of them for there time and replies
Jb4 g5 , bms dci, er fmic , active d.ps , bms charge pipe, tial bov -2008 335i
Default 07-13-2016, 08:37 AM
So I reinstalled the JB4 last night and took the car for a drive this morning. I waited for it to warm up and then beat the crap out of it in 3rd gear and it did not go into limp mode this time but still didn't run 100%. Only codes I got this time were mifire cylinder 4 and fuel pump plausibility. At some point the car switched to map 4.
Here are the logs i took, one is in map4. The fuel pressures look good to me in the map so can i rule out the fuel pump?
I am trying to get a INPA cable so i can swap injectors around and see if the problem follows.
What do you think?
Default 07-13-2016, 08:54 AM
Mabey coilpack
Default 07-13-2016, 08:56 AM
I won't be around my comp till later today I'll look at them and see if anything stands out. In the mean time hopefully someone else will chime in.
Default 07-13-2016, 09:16 AM
Also enable your 6cyl timing in your user setting on jb4 app it's probably a 4 but try 5 too
E92wala E92wala is offline
Car: 335i E92
Default 08-23-2016, 02:25 AM
Any update? Did you fix the problem and how?
