(#126)
joselarajan87's Avatar
joselarajan87 joselarajan87 is offline
Banned
Car: 2009 Bmw 335i
Default 03-03-2016, 10:46 PM
Originally Posted by Rushan
My identification shows 7591971 and date 14.4.2008, does that mean my TCU never been updated?
I'm planning to go for the Alpina flash but checked if I can go back to my old flash and seems the 7591971 not listed, how I can make sure I can go back to stock in case?
you can always flash your transmission to the latest software for it.. once conect4d with winkpf you just choose gk215 and hit program it will automatically choose the latest update for it. n by the way this works the same. for any module you are trying to update on your car.. not just the transmission
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 03-06-2016, 01:05 PM
After doing the Alpina flash, is there any log or file that get stored that shows what was the original ZB before the Alpina flash?
I mean a friend had flashed the Alpina from his laptop, and he don't know what was the stock ZB prior to the Alpina flash, is there anywhere as log or file will be stored by the WinKFP that can show what was the stock original ZB?
Brendan-m2's Avatar
Brendan-m2 Brendan-m2 is offline
Car: 2008 BMW 335i
Default 04-01-2016, 03:46 AM
Great write up, helped make this whole process much easy, very happy with the results.
If anyone in Australia near Newcastle wants this, I can help you out.
2008 BMW 335i with M-sports add-ons
Mishimoto Cooler, JB4 G5, VRSF DP, BMS CAI, BMS CP, BMS Oil CC, Alpina Trans Flash
Coming: Quaife LSD
Jgcdude1 Jgcdude1 is offline
Car: E93 335 N55
Default 04-01-2016, 08:55 AM
Originally Posted by Jgcdude1
I installed this update a while back. I installed the flash and it seems to work properly, but have never been to read anything on RPM shifter dropping to zero when shifting in manual mode.
Has anyone experienced this and fixed it?
I have a Nov 2010 build 335 N55.
No one experience this before? It's mostly annoying, not affecting performance.
ajsalida ajsalida is offline
Car: e92 335xi
Default 04-01-2016, 09:23 AM
From the very first post in this thread:
" (some N55 engines which are rare, exhibit the rpms jumping down to zero on each shift but acts normal in every other way..This can be addressed if you update your DME version if you have this erratic rpm issue after flash). "
Car: E93 335 N55
Default 04-01-2016, 11:46 AM
thanks for the input, should i just use the latest version of the DME available? Can you confirm the latest version?
Thanks again!
Car: e92 335xi
Default 04-01-2016, 11:54 AM
Thanks again!
Sorry, got an N54. Another guy over on e90post had same issue as you, and fixed it with the DME update. I'd see if you can confirm whether you have an older version or not, and if you do update it to the most current. Wander around and see if you can find any DME update threads, cause if you go to a dealer they'll probably update everything and overwrite your Alpina flash.
nika1993's Avatar
nika1993 nika1993 is offline
Car: bmw 535i
Default 04-12-2016, 11:47 PM
Originally Posted by cn555ic
Does NOT work for the 5 series..
Is there any alternative for e60?
nitemare's Avatar
nitemare nitemare is offline
Car: 2010 535i 2002 530i
Default 04-14-2016, 06:34 AM
From reading all 6 pages I got this:
E60 w/out SAT: flash to SAT only
E60 w/ SAT: you are screwed
Unless, someone was able to crack the files and can flash an Alpina in the regular E60 along with the E60 that come factory with SAT?
Unfortunately, mine came as an M-Sport w/ SAT....so I am screwed. I'm thinking about finding a used 6HP26 and TCU to see if she will bolt up successfully. This would be the ultimate solution for 99% of the N54 communities power levels. NizPro has 6HP26s in Falcons running bottom 9s@150+ making over 1000whp.
I will have EVERY possible upgrade within the next month to my E60 (minus built motor, head work, higher stall torque converter, built tranny).
If our community can swap the 6HP26 along with a built higher stall TQ converter we could potentially knock off a half second in the 1/4.
WORLD'S FASTEST 535i - 60': 1.62 1/8: 7.2@98.3 1/4: 11.2@124.6 (@ 23psi only)
1/2: 151.2 (no boost in 4th or 5th bad TMAP)
Hexon RR700s/JB4/Trebila BEF/BMS Meth/MFactory LSD/Fuel-It Stage 2/ADE Port Injection/Full E85/ VRSF Inlets/VRSF ***/VTT Outlets/Custom 3.5" single exhaust/VRSF CP/Tial BOV/Rev9 FMIC/RB PCV fix kit/ RaceStar Dark Star 17" & 15" wheels/Custom 15" brake setup
Future: Lots more to come...stay tuned!
Rushan's Avatar
Car: 335i E92 2009
Default 05-03-2016, 11:04 AM
After you connect and choose Update ZUSB and choose ECU GK215 the program option doesn't show, the program option shows only when choosing Choose ZUSB and selecting ECU GK215 it take you by default to the 1st ZB number which I guess shouldn't be the case because it won't automatically write the latest update and it will write the 1st selected ZB instead,
Or I need to select Enter ZUSB and use my hardware number ?
I'm missing something?
nika1993's Avatar
Car: bmw 535i
Default E60 SAT - 06-24-2016, 09:16 AM
a firmware code e60 sat? how to write it on cars?
Impac's Avatar
Impac Impac is offline
Car: 2008 BMW 535i
Default 06-25-2016, 10:37 AM
SAT file for E60 is #7601458
JB4 G5, DCI, Er CP with HKS Bov, VRSF DP's, BB Race flash
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 08-05-2016, 05:41 AM
I know this thread is old. I just want to say If your having trouble call this guy. He remote flashed my car for a great price and setup everything for me. Hands down the best investment I've made. Thanks cn555ic
08 E92 335i AT 20k Miles | ***** E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
eurodiy eurodiy is offline
Car: 2011 BMW 335xi
Default 08-10-2016, 06:24 AM
I love write-ups thanks for that.
I've been following this subject closel and probably I have missed it, but can you actually use your Bavarian Technique cable to perform this? It's a INPA Ediabas K+DCAN USB Interface cable correct? Or am I missing something?
Banned
Car: 2009 Bmw 335i
Default 08-10-2016, 07:30 AM
bt cable won't work. you need k+d can cable for this.
Car: 2011 BMW 335xi
Default 08-10-2016, 07:57 AM
I'll bite the bullet and get the 100$ one then. There seems to be a lot of cheap chinese knock-offs out down but they are getting a bad rap.
Thanks for the info!
swissi's Avatar
swissi swissi is offline
Car: e91 335ix
Default great diy! - 08-15-2016, 11:53 AM
Thank you cn555ic for this great diy.
Today i made the alpina flash with winkfp and it works fine but the shift
Paddels don't work anymore. I have done the job with ncsexpert and the paddels work again.
I'am really happy! I never worked with winkfp or ncsexpert before.
BMW 2010 n55 e91 335ix, 6 AT xHP st.3, JB4 bef with connect kit rev.3 and FF wires, Pure st.2, pure hi flow inlet pipe, fuel it st.2 lpfp, bms wmi kit with 1 cn 5 nozzle in charge pipe, fuel it dpmi with 550cc injectors, aFe Magnum Force Pro 5r st.2 intake, Air Scoops, phx charge pipe, bms occ, wagner evo 1 comp fmic, c- less pipe, 98/100 oktane (vpower), 3.5 tmap.
Car: 2010 135i
Default 09-16-2016, 12:48 PM
So after I flash I'm getting an error 209.
I was getting a 211 but --> http://blog.uobdii.com/how-to-solve-...h-programming/
fixed that problem.
I'm not sure what to do now. The car can't move because the flash went 100% but the error is preventing something. I'm getting the gear MIL and can't shift from park.
2010 135i auto,
2020 mods: Speedtech S366, VTT DBBL, PR Coils, dual 450's, etc
Best stock turbo 1/8 mile: 7.469 @ 98.56, 1.769 60'
Best stock turbo 1/4 mile: 11.480 @ 121.79 1.802 60'
Car: 2010 135i
Default 09-16-2016, 11:34 PM
FINALLY got the flash to take.
All I had to do was buy a new laptop, reinstall everything twice and keep trying for another 3 hours.
Pretty easy really.
I just don't get it. I had coded things when I first got the car and did the trans flash. now 7 months later I can't do a thing W/O the car bricking or fighting me every step.
2010 135i auto,
kingjulian kingjulian is offline
Car: 2010 135i DCT Lemans Blue / Lemon
Default 09-27-2016, 03:01 AM
Does V53 datens have to be used for this, or is it possible to use a later datens (e.g V55 / V59) file and just track the latest ZB number update using the .HIS file in the GKE215 data folder?
KJ
2010 135i DCT (Le-Mans Blue/Lemon)
2003 E46 M3 SMG (Estoril Blue/Black)
2003 E46 330d Saloon (Silver Grey/Grey)
Banned
Car: 2009 Bmw 335i
Default alpina flash help - 09-27-2016, 03:08 AM
anyone that needs the alpina flash. i can help you get it done remotely as long as you have the k+d can cable
ImportAutoworks ImportAutoworks is offline
Car: 2008 E92 335i AT
Default Can Someone Help??? - 10-08-2016, 05:52 PM
Hello. Been sorting through all the posts on this thread, and I'm having issues importing the spdaten files to winkfp. I've tried to follow the instructions as listed, but I don't appear to be getting the logistics correct computer wise. I have all the needed programs loaded, just need help getting the them into winkfp so I can do this flash. Any help would be much appreciated!
Banned
Car: 2009 Bmw 335i
Default 10-08-2016, 06:09 PM
i can help you
Impac's Avatar
Car: 2008 BMW 535i
Default 10-08-2016, 06:23 PM
If you dont have BMW CODING TOOL get it, its very easy to update your daten files with it
Marcos_Nunes's Avatar
Marcos_Nunes Marcos_Nunes is offline
Car: E92 335i
Default 01-12-2017, 11:33 AM
Do i Have to uninstall MHD to do the flash?
