cn555ic cn555ic is offline
Car: 335
Default ALPINA B3 Flash DIY using WINkfp - 08-27-2013, 05:37 PM
I have posted this on other forums and finally had the chance to broadcast this on N54Tech.com
This guide is intended for personal use and anything that happens to your car is done soley by your choice.. This guide just provides the instructions on how to flash the software. I do not hold any responsibility if you damage your car.
Alpina B3 Flash DIY using WinKFP
DIY Guide to Flash Alpina B3 Flash:
WARNING...If you dont know what your doing, dont be brave and blindly go into this advanced flashing of software into the TCU module.. If your not too confident in doing this, either pay someone or just do without it.....WinKFP is a very dangerous tool but yet its awesome and in terms of coding its pretty advanced.. Proceed after reading this warning if you choose to do so...
This flash will make the transmission run smoother, gear change will be more precise and crisp, rev match downshift is unbelievable, rev limiter is increased and overall driveability is increased. You will have a new indicator for gear selection in D mode which display D1, D2, D3 ,D4, D5 and in DS mode you will see S1, S2, S3, S4, S5 and the same for the M mode. This single flash will make the car change gears more refined and crisp. You will no longer feel the lurching when the tranny shifts and it goes through the gears without even the slightest hesitation. It is indeed a must have flash if you own a E9x with a N54 engine...
This Alpina TCU flash works for model years 3/07 till present N54/N55 engine (some N55 engines which are rare, exhibit the rpms jumping down to zero on each shift but acts normal in every other way..This can be addressed if you update your DME version if you have this erratic rpm issue after flash). If your production date is before 3/07, your out of luck and cant flash your car! Before you attempt this you should have some knowledge in coding and setting software. You need to confirm INPA software is working and communicating with car. If you dont have INPA communicating, dont move beyond this point and go back and do some more research on getting it to work.. There are plenty of DIY guides for setting up INPA, Ediabas, NCSexpert and WinKFP,
You can purchase a proven cable that works...Please dont ask will this one work as it is cheaper if so.. Buy one that is proven and it will save you alot of headaches!
http://www.one-stop-electronics.com/...&product_id=16
Once you have configured your laptop properly with INPA, NCSexpert and WinKFP, you need to download Spdaten 49.3 which I have provided a link to download a condensed form for the strict purpose of this Alpina flash. The link for the SPdaten 53.0 is not the entire version and doesnt have the other data files needed to flash other modules if you need them, this is strictly for Alpina flash which makes the download much quicker...If you have any questions pm me, call or text me 1917-939-4980 or even email me Ccnoner@aol.com if you have any other questions or need assistance to remote flash it
https://www.dropbox.com/s/sb0bm1he0j7hto9/53.0.rar
Follow the guide how to import the SPdaten 53.0 data into Winkfp by downloading the PDF I have provided below..Once you have the data imported into Winkfp then you need to configure the Winkfp..follow this
Once Winkfp is configured correctly your ready to begin the flash of your new Alpina B3 software into your car!!
IMPORTANT..For those using Procede or JB4 make sure the tune is set to VALET map 0 before you start the flash..
Here we go:
-Make sure your battery is good if not get a battery charger
-Open drivers door and turn ignition ON (cluster guage on) Basically hit the start button twice without starting car..
-connect cable to obd connector of car
-Load Winkpf software
-Press (F1) comfort mode
-Press (F3) Update ZUSB
-Choose ECU GKE215
-Press (F2) Choose ZUSB
-Choose ECU GKE215 and next to it there will be ZB-Numbers..Find 7615835
-Click ok
-If you have done it correctly so far you will see at the top Assembly Identification number 7615835 (Alpina software ) and it will automatically reference 7591971
-Press (F4) Enter VIN ( make sure you double check you have entered the correct VIN numbers)
-click ok
-Press DONE (F8)
-Press (F3) Program
-Pop up window will say you can code the ECU 63 more times, click ok
-Flashing begins and you will have to wait till it reaches 100% twice..The first bar will finish rather quickly and then another bar progress of 100% will take about 3-4 minutes
the most and it will be completed...
-If everything is done correctly, then you will get a pop up screen saying programming done, click ok
-Shut off car by taking key out. Lock car with key, wait 5 minutes and start the car..If everything works correctly you will not
have any warning signs or check engine lights...Enjoy your newly transformed AT Alpina B3 software
NOTE::::::
For newer build cars after the flash the paddle shifters no longer works...If this is the case you would follow part II of this DIY..
Alpina B3 flash Part II: DIY for NOT-working paddles shifters after flash
Alpina B3 flash Part II: DIY for NOT working paddles after flash
The Alpina B3 flash has been a huge success so far for performance gains as well as fixing many issues that has plagued the N54 platform for years. It has undoubtedly given the performance gains in which everyone could enjoy. The only minor glitch during the flashing was on new model years in which once the car is flashed the paddle shifters now longer worked, unlike the earlier build model years which didn't exhibit this. This was quite bothersome to me so I had to find a fix as it seemed unthinkable it wouldn't work. Here is your solution!
You guys need to use NCSexpert and have the latest SPdaten 49.3 or even 48.1 loaded up to both NCSexpert and Ediabas. There are tons of literature on this so do a search on it. If you not comfortable doing this or the actual coding, you can find a local coder and pay to have this coded....
Warning: If you dont have the Spdaten 48.1 or 49.3 updated correctly into Ediabas and NCSexpert, after doing this coding the car will be Dead and show a gear warning on cluster but this can be fixed by correctly updating the NCSexpert...
Here is what you do:
0-Start ignition with cluster lights on
1-Load NCSexpert
2-File Use EXPERTMODE profile and click ok
3-(F1) Vin/ZCS/FA
4-(F3) SG ausw
5-Choose E89 chassis click ok
6-Choose CAS click ok
7-(F6) Back
8-Choose ECU and pick EGS
9-Press F3 (execute JOB)
10-After it says coding ended your done!
11-Close out NCSexpert
At this point 3 things can happen:
**A)There are no errors and the car starts fine and the paddle shifters are working and your happy!
**B)The car starts but then when you drive off, the shifting of gears are all screwy and changing incorrectly.
**C)The car starts but you get the dreaded GEAR error and it wont even go into drive at all..
If you have either B or C then you issue is the update of the Spdaten 48.1 or 49.3 was incorrectly done...Go back and check installation and start again
Reverting back to stock software...
Anyone that wants to go back to stock software for whatever reason, its really simple to do...Follow the same procedure and choose 7601492 as the ZB number instead of the 7615835 (alpina software zb number).
Have fun modding!
trebila's Avatar
trebila trebila is offline
Default 08-28-2013, 12:10 AM
Great.
Does it work for E8x 135i ?
Default 08-28-2013, 12:43 AM
Originally Posted by trebila
Great.
Yes, I've been running this flash for a few months.
trebila's Avatar
Default 08-28-2013, 07:03 AM
in fact I'm ready to flash the gearbox ecu with the alpina B3 flash with winkfp.
but before flashing with the ZB-Numbers 7615835 (alpina flash), I'd like to know what is my ZB number right now, just to be sure to re-install the right flash if I want to go back, because I had a gearbox ecu update few month ago made by BMW, which actually lead to the same effects of the alpina B3 flash, expect the " new indicator for gear selection in D mode which display D1, D2, D3 ,D4, D5 and in DS mode you will see S1, S2, S3, S4, S5 and the same for the M mode." features.
I don't tnink winfkp can indicate the actual version of the gearbox software, am I wrong ?
I have e89 sp daten v49 installed, but INPA can't communicate with my gearbox ecu because the GS19D.ipo file is missing in the v49 daten software (ok for the gs19a, gs19b and gs19c), whereas we can find it in the old V40 sp daten, but can't find a valid link to download it.
do you know where I can find the E89 sp daten V40, or just the GS19D.ipo file ?
or another way to know the actual version of my gearbox flash version ?
Car: 335
Default 08-28-2013, 09:51 AM
I sent you an email with the proper software to read the tranny module..
AndyW AndyW is offline
Car: 2008 335i
Default 04-18-2015, 10:18 PM
I would also like to know how to do this just to have a warm fuzzy before I do this. Would also be cool to get the full, current SPDATEN so I know I am missing nothing but that seems to be hard to find without signing up on websites I'd prefer not to...so if anyone has a legit link, pls pm me.
Also...since this is my first time working with all this software, who is a good expert to have on retainer in case I get the "gear"? I know computers and software...just not THIS software and like to have a backup plan in place before executing. TIA and thanks for this detailed DIY. I can see that this stuff will also come in handy when I get new injectors so this is a good intro...
135droptop's Avatar
135droptop 135droptop is offline
Default 04-19-2015, 06:35 AM
***** Performance is the guy you want to talk to. He helped me out, I work for the big blue place and I work on computers every day but, this I was not comfortable with. He setup a custom tune for me and did this Alpina flash for me. He remoted into my computer and I also had him on the phone. Flashed the Alpina tune and it's been great!
PM me if you want his email. Very nice guy.
Car: 2008 335i
Default 04-22-2015, 11:38 PM
Yeah, I converse a bit with cwarren(he also did my walnut blasting and I intend to have him install my DP's) and he says ***** is the man. I got the flash done successfully myself but had trepidation just like you....***** was definitely my backup plan if it went south! In fact, I just bought the MHD software and flashed with a stage 1 tune by *****. First drive with the "new" engine will be tomorrow!
trebila's Avatar
Default 08-28-2013, 10:29 AM
thanks cn555ic, I'll try it tonight. ;-)
mjmarovi mjmarovi is offline
Car: '09 335i coupe
Default 08-28-2013, 11:14 AM
Hey @cn555ic would I run into any issues running this on Windows 8? Thanks, Matt
2014 2500 Cummins- Pretty much everything.
09' Single Turbo 335i SOLD
Car: 335
Default 08-28-2013, 11:36 AM
Windows 8 is fine also. I have configured many laptop running windows 8.
Car: '09 335i coupe
Default 08-28-2013, 11:39 AM
Ok, great.
trebila's Avatar
Default 08-28-2013, 03:36 PM
I haven't done the flash yet.
I've succeded to read gearbox module informations with INPA despite the fact the version used is GS19D.ipo.
anyway, here is the result:
according to this, is my actual ZB number is 7568222 ??
trebila's Avatar
Default 08-28-2013, 04:05 PM
I've done the test with your inpa fxx, cn555ic, and it gave me this:
according to this, the ZB version of my gearbox module is 7603527 (EGS line), which in fact have been uploaded by the BMW dealer the 03/28/2013.
can you confirm me this is right ?
if so, what do the previous 7568222 refer to ?
Car: 335
Default 08-28-2013, 04:59 PM
You got it. That's your software on your EGS module. Don't worry about what was there prior to dealer update. Use this ZB number 7603527 as your backup when and if you decide you want to revert back to stock.
trebila's Avatar
Default 08-28-2013, 05:09 PM
Ok, thanks.
Alpina b3 flash done, everything is OK, thanks a lot.
Car: 335
Default 08-28-2013, 05:15 PM
Ok, thanks.
Niiicee!!! I see you have a convertible like me!
trebila's Avatar
Default 08-28-2013, 05:52 PM
Yes, with the smart top module, it's a real pleasure.
topspeed1991 topspeed1991 is offline
Car: 535i sport
Default 09-01-2013, 01:58 PM
I have a 08 535i without paddle shifters, will this work on pre-paddle shifter 535i's?
Car: 335
Default 09-01-2013, 08:05 PM
Does NOT work for the 5 series..
nika1993's Avatar
nika1993 nika1993 is offline
Car: bmw 535i
Default 04-12-2016, 11:47 PM
Is there any alternative for e60?
nitemare's Avatar
nitemare nitemare is offline
Car: 2010 535i 2002 530i
Default 04-14-2016, 06:34 AM
From reading all 6 pages I got this:
E60 w/out SAT: flash to SAT only
E60 w/ SAT: you are screwed
Unless, someone was able to crack the files and can flash an Alpina in the regular E60 along with the E60 that come factory with SAT?
Unfortunately, mine came as an M-Sport w/ SAT....so I am screwed. I'm thinking about finding a used 6HP26 and TCU to see if she will bolt up successfully. This would be the ultimate solution for 99% of the N54 communities power levels. NizPro has 6HP26s in Falcons running bottom 9s@150+ making over 1000whp.
I will have EVERY possible upgrade within the next month to my E60 (minus built motor, head work, higher stall torque converter, built tranny).
If our community can swap the 6HP26 along with a built higher stall TQ converter we could potentially knock off a half second in the 1/4.
WORLD'S FASTEST 535i - 60': 1.62 1/8: 7.2@98.3 1/4: 11.2@124.6 (@ 23psi only)
1/2: 151.2 (no boost in 4th or 5th bad TMAP)
Hexon RR700s/JB4/Trebila BEF/BMS Meth/MFactory LSD/Fuel-It Stage 2/ADE Port Injection/Full E85/ VRSF Inlets/VRSF ***/VTT Outlets/Custom 3.5" single exhaust/VRSF CP/Tial BOV/Rev9 FMIC/RB PCV fix kit/ RaceStar Dark Star 17" & 15" wheels/Custom 15" brake setup
Future: Lots more to come...stay tuned!
Wedge1967's Avatar
Wedge1967 Wedge1967 is offline
Car: '07 335i e92
Default 09-01-2013, 11:12 PM
I've flashed a few 535's with the e60 sport transmission flash. Noticeable improvement over the standard e60 transmission flash. If you need assistance, you can contact me or Steven (cn555ic).
sch4400 sch4400 is offline
Car: 08 535i
Default 10-14-2013, 02:22 AM
I have a 535i sport tranny.
I really want to this flash. What should I do?? Just follow #1 post??? Or is there different way to do this on e60 535i???
Wedge1967's Avatar
Car: '07 335i e92
Default 10-14-2013, 06:06 AM
It is not possible on the E60. I have tried every combination of options and something will not allow this flash to work on the E60. You can flash it all day long, but you will get a transmission error and it won't go into gear.
So, the only option for the E60 is the sport flash which if you have S1 in sport, then you already have it. Those with DS can surely benefit from the sport flash. Anyone looking to get this done should contact me or Steven (cn555ic). You can email me at *****Performance @ Gmail.
