CapitaineBeaver's Avatar
CapitaineBeaver CapitaineBeaver is offline
Car: BMW 230i xDrive
Talking B48 230i 1/4mile & 1/2mile times ... Impressed ! - 09-10-2018, 03:49 PM
Decided I needed to go to the track at least once this year and went out to one of the last 1/2mile of the season and could finally test out my Dragy in perfect conditions. I was pretty impressed (and others too) with the times my 230i with the B48 managed to get.
We went to the Sanair track and ambient temperature was around 18-22c during the day (64-72f).
It does not have the top-end power to smash the 1/2 mile (as well as the 135mph limiter) but I did manage to get faster time than a 335i xdrive and a M235i on the 1/4 mile.
Calculated with my dragy they did as follow :
N55 335i xDrive, Manual, Intake, JB4 Map 2, Did not launch the car : 14.02 @ 100.26mph (2.39 60ft). His highest trap speed for the day was 123.67mph on the 1/2 mile.
N55 M235i, Manual, Intake, JB4 Map 2, did a very mild launch : 13.36 @ 108.91mph (2.29 60ft). His highest trap speed for the day was 137.68mph on the 1/2 mile.
My only mods are JB4 (set to map 3 (+ 6psi) on the track) and the BMS billet intake (for the B48). Car was running roughly 98-100 octane and the tank was filled up prior to the day (Filled up with Petro-Canada 94 octane + Boostane octane booster).
My best times of the day were :
1/4 mile : 13.09 @ 103.68mph
1/2 mile : 20.85 @ 124.98mph
Consistant 60ft of 1.92 all day thanks to the xdrive.
Dragy screenshots attached
I’m hoping to smash into 12 seconds territory hopefully next season (12.99 would do) !
'18 230i xDrive // Black Met // Coral Red // M-Sport // 719M Black // BM3 // BMS Intake // BMS OCC // Dinan Axleback // Roof Rack // 365 days of fun
Default 09-10-2018, 04:30 PM
I'm also thinking. Is there any benefit of going with the EWG wires considering my setup ? And if I go with the EWG wires do I also need to get the Fuel Pressure sensor wire as well ? I'm not really planning on doing really more with the car (I only have 2 years left on it).
AndreySPB AndreySPB is offline
Car: Bmw 320i lci
Default 09-11-2018, 12:19 PM
Hi, good results, but mine is slightly better)
330ix (b48) auto trany, only mod is jb4. Map 6 22 psi and Ron 100 fuel
Default 09-11-2018, 02:41 PM
You had a bigger slope
Nice time ! Mean i'm hopeful that by removing the ''race day kit'' in the trunk which is about 30 pounds and dropping to 1/2 to 1/4 tank I should be able to do 12.9x in map 3. I'm a bit scared to touch map 6 since I'm not really confortable with the tuning process and which settings to verify (my knowledge in this field is limited).
I see the 0.09 difference seem to mostly be with your 60ft beeing exactly 0.09 quicker than mine which is the end result difference. You also trapped a slightly higher speed. I'm not sure how much boost total is with the Map 3 but I was under the impression it was around 19-21 psi. If you managed to be able to get 1 more psi i'm sure I could squeeze it too.
he difference seem to be between the 1/8mile and the 1000' mark where the extra psi or 2 should make a difference.
I assume you are Auto 8 speed as well ? Do you have the sport transmission (or reflash) ? How did you launch the car ?
Default 09-11-2018, 07:56 PM
Haha awesome performance for the 4 banger!
On EWG wires let's see the JB4 logs of say the 1/2 mile run and see how boost looks.
Car: Bmw 320i lci
Default 09-11-2018, 09:17 PM
Yeah slightly bigger slope but also the car is heavier. And yes it’s 8 speed auto. Sport transmission coded and launch control used. Start from about 3000-3200 rpm. I’m going to put ******* ** and an intake soon. Will try to break into 12s at lower temperatures. 13.0 was at +23.
Car: Bmw 320i lci
Default 01-14-2019, 12:47 AM
Iíve installed a c@tle**** and bms intake and here are my best results so far: map 6, 22 psi flat, ron100 fuel.
Default 01-14-2019, 05:09 PM
I will try to see next summer with my new car since unfortunately my 17 white 230i was totaled by a drunk driver. I got a newer 2018 230i but this time got the Dinan axleback installed. I swapped the JB4 and the BMS Intake on the new car but can't wait to get things rolling again. I will hit 6000km soon and will raise the boost soon to map 2 and keep cranking up every few thousands miles. For this time i'm trying to run 94 octane (the highest available at some places in canada) since I've got the car. What will be fun to see is this one now has the increased limiter (255kph instead of 210kph) and has a staggered stickier set of rubbers on it (versus the 4 seasons square setup on my old one). This one will be breaking the 12s barrier without ** for sure in the future.
