(#1676)
MurlinatoR's Avatar
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 02-13-2019, 10:04 PM
Originally Posted by Eronenris
Comfort, sorry.
What map do you have your JB4 on? You have summer or all season tires?
-MurlinatoR
Connoisseur of all things Kia
Eronenris Eronenris is offline
Car: Kia Stinger GT2
Default 02-13-2019, 10:47 PM
Map2, awd, factory tires.
Scorped Scorped is offline
Car: Stinger GT2
Default 02-14-2019, 12:10 AM
Terry and/or other experts, I finally got around to logging a few runs; how am I looking so far?
Thanks in advance.....
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 02-14-2019, 05:43 AM
Pretty dang good!
Car: Stinger GT2
Default 02-14-2019, 11:40 AM
Originally Posted by brancky3
Pretty dang good!
Really? Whew, thanks, that's good to see.
It runs really strong but my (dragy) times are pathetic because of wheelspin and lack of traction. Just wanted to make sure I'm not leaving any power on the table.
Default 02-14-2019, 12:12 PM
Looks good to me also.
Default 02-14-2019, 12:15 PM
How much E85 do you actually have in your tank? Your logs are showing 50%!
Car: Stinger GT2
Default 02-14-2019, 12:25 PM
Awesome, thanks!
One other question though; would I see better results if I swapped plugs? I'm still using the stock plugs at stock gap (I know, I know, I'm too lazy to change them until one actually blows..lol)
Car: Stinger GT2
Default 02-14-2019, 12:28 PM
50%?? Lol. I added 4.5 gallons of E85 on top of 10 gallons of 93 from QT. Honestly I only planned to add 3 gallons but I got distracted talking to some guy asking questions about the car at the pump.
Edit: 50% sounded like a lot but I just remembered our tanks are pretty small and I was almost empty when I refueled, so, that would indeed be about 50%.
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 02-14-2019, 02:23 PM
Awesome, thanks!
Is it 100% that we have to even touch them? Meaning...just leave stock plugs with stock gap. Will they eventually blow...or is it just a "would be better" type situation.
I would love to avoid regapping...or even replacing with the regapped Denso's. But if it is a requirement...well...I will do it.
Default 02-14-2019, 03:54 PM
I'd swap plugs at some point for sure, it's only a matter of time before one cracks IMHO.
G80SPORT G80SPORT is offline
Car: 2019 g80 sport
Default G80 Sport - Yesterday, 09:55 AM
Can you confirm if the g80 sport can use the fuel wires?? I have asked support and got an inconclusive answer.
My buddy ordered the lap3 solution and I would like to use the JB4 for a side by side comparision?
Do you have plots or graphs for the G80, any pointers would be helpful.
I have read 67 pages and are still on the fence.
Default Yesterday, 11:21 AM
Yes fuel wires work on all applications including G80, and even the 2L now!
Everything worth reading is in the first post. The rest is just discussion.
Sorry to hear your buddy wasted so much money on the Lap3-Pro for what is a similar product only with less developed interface and tuning. Performance on each until will depend on the settings/maps used. They all have the same capability. Only, the JB4 has much more development and features done. You'll see when you compare our app to Lap3-Pro app.
Car: 2019 g80 sport
Default Yesterday, 11:57 AM
Thanks for the reply - just made my order! , I have a e54 pump near me and hope 5-6 gallons of that will allow map 3 to run well.
I will post my logs here for review.
Thanks again.
MekstingerGT MekstingerGT is offline
Default Yesterday, 12:04 PM
Filled her up yesterday 30% e85 and notice that the fuel cap is turning yellow, normal? I've been running 30% e85 for 2 months now.
CeramicGT2 CeramicGT2 is offline
Car: 2018 Stinger GT2
Default Yesterday, 10:10 PM
Just installed JB4 with fuel wires and Bluetooth today that I received yesterday. What firmware version are they now shipping with? IE, do I need to update?
Default Yesterday, 11:54 PM
Well, I tried to update the firmware and now get: Failed checksum testing file: 21210 Read: 5051114.
Because I canít get any firmware to properly reload, I canít use the JB4 until I get some help with this. Bummer.
Default Today, 09:00 AM
Hold the phone closer to the blue tooth device, that sometimes helps if the phone has a weaker signal.
Default Today, 09:01 AM
You don't need to update but the firmware posted here is newer than the production firmware.
Default Today, 09:15 AM
Ok, let me give that a try and I will keep you posted.
Default Today, 09:42 AM
Thank you Terry, this worked!
I loaded Version 8 of the firmware, but had a quick question. The files is titled "test", so is it ok to run? Also, since I have fuel wires, I am assume with this new firmware I don't need to change any settings, it's good to go the way it is?
Car: 2019 g80 sport
Default Today, 10:03 AM
In the newer firmware's nothing is needed to run the fuel wires.
Default Today, 10:20 AM
Thank you!
Default Today, 12:25 PM
Yes it's fine.
