naoaki's Avatar
naoaki naoaki is offline
Default MHD Overwrite - 02-12-2019, 08:28 AM
Hey guys
I currently use DME flash of 3D design, but is it possible to overwrite this with MHD? Or do you need to return to stock once? Please let me know if you know. Thanks in advance for all the answers in advance.
BMW 2007 E90 335i
Default 02-12-2019, 08:29 AM
Originally Posted by naoaki
Hey guys
Not familiar wirh 3D design- but you can overwrite whatever you want. Iím assuming you are looking to use our OTS BEF?
naoaki's Avatar
Default 02-12-2019, 09:58 AM
Thank you for answering. Since DME flash of 3D design is inferior in performance to MHD, I would like to switch to MHD. Also, 3D design is cumbersome to handle and you can not flash yourself so you have to go to the shop and flush and there is no extensibility. If MHD overwrites other flashes and there is no problem, we will use MHD. At first, I am planning to use MHD alone.
BMW 2007 E90 335i
Car: 2008 E93
Default 02-12-2019, 10:36 AM
When first installing MHD most cars are stock bin and it makes a copy and saves it for when you want to go back to stock.
In your case, (if you dont have stock bin) not sure but I believe you have to select stock map operations in MHD. If you do not have your stock bin, I believe MHD has a generic version. Install that, From there, you can now flash the bms BEF or any custom map.
codesx's Avatar
codesx codesx is offline
Default 02-12-2019, 04:15 PM
I think what's a little bit confusing is your signature states JB4 and MHD Race Flash, while you state the DME has "3D" flash.
Your JB4 is a great product, with a lot of good safety features.
The Race Flash you speak of is likely BMS Race Flash, uploaded using the MHD app for convenience.
You state you wish to use MHD alone.
Is it possible you're talking about a car that is not in your signature?
Otherwise, this is a little confusing.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
naoaki's Avatar
Default 02-12-2019, 07:52 PM
Since I do not have JB 4 yet, I am considering deleting DME flash of 3D design and using MHD alone. I would like to know if the MHD application has a function to delete another DME flash and return it to the stock map.
BMW 2007 E90 335i
naoaki's Avatar
Default 02-12-2019, 08:00 PM
By the way it is confusing but I want to do this work is my friend's car. I'm sorry to disorient the writing style. To be precise he is not yet JB 4.
BMW 2007 E90 335i
Default 02-12-2019, 11:50 PM
Short answer - Yes.
That being said - there are many benefits of running a flash WITH JB4.
