paulexec paulexec is offline
Car: 2016 M3
Default Map 6 with Meth? - 11-26-2016, 02:24 PM
Can I use map 6 with the meth kit? Map 6 is my favorite
2016 M3 ZCP
Paul
Default 11-27-2016, 10:09 AM
Yes, you can use meth on all maps if set up properly. Here is the guide for the trigger and safety settings but in your case the meth map is 8.
Meth Safety Mode:
0 - Raise boost as a function of meth flow & historic timing (default)
1 - Raise boost as a function of meth flow only
2 - Start at high boost target and reduce IF flow drops below flow level for 1 second under boost.
3 - Start at high boost target and disable all safety systems. Meth flow is completely ignored.
Meth Trigger Mode:
0 - Meth flows on maps 3, 6, and 7 (default operation)
1 - Meth flows on all maps
2 - Meth flows on map 3 only
3 - Meth is disabled on all maps
Car: 2016 M3
Default 11-27-2016, 01:17 PM
Awesome, thanks! Do the meth safety precautions still work on Map 6?
Meth Safety Mode:
Meth Trigger Mode:
steeve13m steeve13m is offline
Car: 13 M5 DCT
Default 11-27-2016, 07:33 PM
I was told no meth safety in map 6 and it is only on map 8.... I use map 8 and adjust boost psi using the "boost additive" number like 60-75
2019 Marina Bay Blue M5 Competition, HRE FF04 21",BMC filters, 5% Window tints,Clear protection film,Escort Passport MAX,zw5,Sprint Booster.
2004 Lamborghini Gallardo -Manual- Giallo Midas Pearl Yellow- Modified Intake, Exhaust, Tuning, Carbon parts, HRE wheels, Sound system, +
Car: 2016 M3
Default 11-27-2016, 08:56 PM
I'm keeping my fingers crossed that the meth boost additive works on map 6, such that I can control the boost by rpm base curve then adjust how much boost is added when meth is flowing. We shall see. I wish the documentation on all of this was a little more thorough.
Peter @ Pure's Avatar
Car: F20 M135i
Default 11-27-2016, 10:38 PM
I had this working on n55 jb4. But it depends what Terry put on the S55 fw. Maybe he can chime in.
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 12-13-2016, 08:12 PM
I believe Map 6 is no longer a meth additive map.
harkes harkes is offline
Registered Users
Car: M135i
Default 12-14-2016, 12:52 AM
Would be GREAT if map6 was additive. I'd like to target 23-25psi up top but not midrange as it will produce too much torque for the ZF8. And then you would have the safety of map3
