135droptop's Avatar
135droptop 135droptop is offline
Default One of the best looking DP's I have seen. - 08-25-2016, 10:44 PM
Price is not bad to boot. http://www.ebay.com/itm/1320-Perform...3D282149670697
08 335i Droptop 18lbs boost, VRSF Charge pipe, HKS BOV, BMS dual cone intake, ARM intercooler, MHD Stage 2
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 08-25-2016, 11:03 PM
Whats with the reduced size right before it bolts up to the stock catback?
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 08-26-2016, 06:37 AM
Reduced size in this way doesn't seems smart idea,
Go for proven product,
I had this from Mike @ N54tuning
http://sww.n54tuning.com/n54tuning-l...*********.html
I'm happy with the quality and price
BostonBeemah's Avatar
Car: AW 135i
Default 08-26-2016, 07:40 AM
#Every ******** have that taper to the stock catback since they are going from 3in to 2.25 I believe.
RIP 2008 AW/BL 135i
phil1320 phil1320 is offline
Car: 2011 335is
Default 08-26-2016, 10:44 AM
Yea 99% of down pipes have that taper because it is mating up to the stock 2.5" exhaust. AR are the only DP that doesn't have the taper as far as I know
Car: 09 E92 335i
Default 08-26-2016, 11:14 AM
Clearance is gonna be extremely tight without the gradual tapers in most other pipes. These better fit like a glove or else you gonna have them rubbing against each other of the frame.
Car: AW 135i
Default 08-26-2016, 11:21 AM
I had that happen on my first set of ********* and they made the car vibrate and I could hear turbos spooling louder haha These were 3in *** with a hard taper.
RIP 2008 AW/BL 135i
rhm135's Avatar
rhm135 rhm135 is offline
Tech
Car: 335is
Default 08-26-2016, 11:23 AM
Looks clean. But does anybody run them?
335is DCT MOTIV - xHP - Fuel-it! - SSP - DocRace
Torgus Torgus is offline
Default 08-26-2016, 12:28 PM
go be a ginnie pig.
Got Boost?
08_335i 08_335i is offline
Car: 2008 335i
Default 08-26-2016, 12:35 PM
1320!? Must be some serious go fast DP's like their videos! But on a serious note, if they fit well they actually look like a nice set of DP's. I like the design.
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 08-26-2016, 12:50 PM
Looks great.
Price is right.
Looks like I may have a bad O2 sensor = if I'm going to spend the time to replace it, might as well do DP's at the same time.
That said, I'm not going to be the first, as I don't want to mess with a PITA install just to save a few bucks over the VRSF unit.
ichris323 ichris323 is offline
Car: 2007 E90 335i
Default 08-26-2016, 01:11 PM
Weird, I actually bought these last week and picked them up at their store in Elk Grove, CA. They seem nice. I will be getting them installed on Tuesday.
135droptop's Avatar
Default 08-26-2016, 01:14 PM
Let us know how it goes..
Car: 2010 135i
Default 08-26-2016, 01:29 PM
I like the sales pitch. I don't recall any other ebay listing having install pictures.
And US made product.
If I didn't have track events coming up I'd get these now.
2010 135i auto,
Car: 2007 E90 335i
Default 08-26-2016, 01:33 PM
I will definitely let you guys know how the install goes.
snelson3003's Avatar
snelson3003 snelson3003 is offline
Car: 135I
Default 08-26-2016, 01:50 PM
http://1320performancestore.com/bmw%...est?search=n54
cheaper on their site... FYI
498WHP / 516TQ : 10/29/16
VTT Stage 1 + Billet Wheel | VTT Inlets | VTT PCV Valve | JB4 G5 ISO | BMS E85 Flash | Fuel It Stage 2 | ECS TwinTake| Stett Vacuum Canisters | Hartge Stepped FMIC | VRSF DP | 91Oct w/E50 | BMS Cowl Filters | Located in Denver, Colorado - High Altitude!
Maintenance: EKPM3-DE @ 74K | Water pump & T-stat @ 70K | Valve Cover @ 50K | VTT Turbo @ 70K | HPFP @ 65K | Walnut Blasting @ 65K | 6 Injectors @ 55K | Vacuum lines @ 55K | Spark Plugs @ 75K | Boost Solenoid @ 65K
Car: 2007 E90 335i
Default 08-26-2016, 01:54 PM
Originally Posted by snelson3003
Yea, they let me get away with $295 cash at their store.
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 08-27-2016, 07:43 PM
Many "3 inch" N54 *** reduce for the ~2.5" flanges to the ***-back.
There isn't much to go wrong with *** construction wise so they can be "proven" after a single dyno.
Evan
N54 Powered M5 Wagon:
04gto 04gto is offline
Car: 2008 335i
Default 1320 - 09-02-2016, 10:16 AM
If I did not already have DP's, I would grab these right now. They look like they would have super low resteiction, minimal welds. Made in the US a nice bonus. The price is great. Nice find 135droptop.
dadzy dadzy is offline
Default 09-10-2016, 09:27 AM
Did you manage to get these installed? Thinking of pulling the trigger on these.
Car: 2007 E90 335i
Default 09-11-2016, 10:15 PM
I finally got around to having them installed by a local N54 specialized performance shop. At first they had trouble getting them to line up properly, they are just too tight against each other to get the one for the front turbo into place. They asked me if they could make a little bit of a flat spot on each ******** where they were touching each other so that they would clear, I agreed and they worked their magic to make them fit. They are some of the nicest ********* they've seen, just a bummer they had to be a little modified to work.
Also, the supplied DP gaskets will leak, use OEM only.
They worked out in the end, .
Default 09-11-2016, 10:32 PM
Thanks for the update. Too bad about the fitment as they do look really nice.
klipseracer klipseracer is offline
Default 09-11-2016, 11:02 PM
I don't know anyone besides myself that had true 3" dp's. I had them custom made including 3" mid pipes.
Car: 09 E92 335i
Default 09-12-2016, 07:51 AM
yep, just as expected. there is very little room for pipes larger than stock ones down there.
fluxil fluxil is offline
Car: 2007 335i 6AT
Default 09-12-2016, 08:47 AM
These ********* are only 299 on 1320performancestore.com
Just type in 335i in the search bar and this is the only product that pops up.
