(#10926)
RadarContact's Avatar
Car: 2010 E60/535i AT FBO+WMI
Default 05-23-2017, 06:17 PM
Originally Posted by dave2221
When accessing the control menu on my JB4, i lost all sound to the speakers.
Restarted the car and they all came back on.
Accessed menu again, lost sound to all speakers
Restarted the car and only the drivers door speaker now works.
Any reason why my stereo now wont work except for the one speaker?
Early model JB4 (g4)
Car is a Aus delivered MY09 (DCT) N54 E93
Only other mods are pod filters, and a Smart Top roof controller.
*edit* I cant figure out which version of the firmware i have, although i know its not been updated and its a G4....
thus the NEW steering wheel controls might not work for me? how do i know which steering wheel control menu is accurate for a G4? as it might be an audio off setting that i am missing?
Was going to say check map 6/5, 6/6, 6/7 as they relate to radio in JB4 but considering the rest, I don't know.
2010 535i M-Sport w/Sport AT/6-spd xHP Stage3, Alpine White w/Natural Leather, APEX EC-7 race wheels w/ST Coilovers --- JB4 G5 ISO Trebila (Map-6/BEF) Custom Tune, Custom Meth Setup (link) 25/75%, VRSF 3" free-flow D/Ps, MMPe DCIs, Wagner 1060 Stepped FMIC, VRSF Chargepipe/Tial BOV w/BMS Vac adapter, BMS Oil Cooler Valve
dave2221 dave2221 is offline
Car: BMW335i N54
Default 05-23-2017, 07:27 PM
I've been trying to find the early model steering wheel codes but it's hard to know which options are available and which are only for newer models
harrychiu012 harrychiu012 is offline
Car: BMW E92 335i
Default 05-27-2017, 03:02 AM
Anyone else have issue with cruise control with JB4 installed?
Car: BMW335i N54
Default 05-27-2017, 04:44 AM
ANYONE.
Cynical Cynical is offline
Default 05-27-2017, 08:30 AM
ANYONE.
Funny enough you can find them on google. Not sure which youll need but google image search "jb4 steering wheel control" and take a look
Default 05-27-2017, 08:41 AM
To avoid confusion only controls for the latest firmware are loaded. If you have older firmware, update it.
Car: BMW335i N54
Default 05-27-2017, 02:55 PM
I thought I couldn't put the latest fries ware on a G4 older model JB4.....
Default 05-27-2017, 03:36 PM
If running a g4 set to map 0 until updating to a g5. It's beyond obsolete at this point.
Default 05-28-2017, 03:43 AM
(Prob not much help, but cruise won't work if DTC is turned off)
Default 05-31-2017, 09:57 AM
Updated the windows interface. Some minor changes including changing the "PWM" parameter to "WGDC" which with ISO firmware better describes what it represents. The wastegate dutycycle. PWM was a term left over from the original JB3 where it was adding dutycycle to the factory signal.
martymil's Avatar
martymil martymil is offline
The Backyard Mechanic
Car: BMW 1 Series M
Default 05-31-2017, 10:02 AM
So whats the scale of the wgdc 0 to 70 or 100 ?
Default 05-31-2017, 10:14 AM
0-100%, same as PWM was 0-100%.
HawkeyeGeoff HawkeyeGeoff is offline
Car: BMW 135i, MS6 BT
Default 06-02-2017, 06:40 AM
So I recently changed my wheels/tires out for my track set...I have the TPMS warning.
I noticed in the old JB4 software there was a TPMS warning defeat....is this still a thing on 4/6 @terry@bms;? I noticed it is just blank now.
Chrisneil Chrisneil is offline
Car: 2008 BMW 135i
Default 06-04-2017, 03:13 PM
@Terry I recently updated the firmware and my car is rattling like crazy , I had the 31_6 software and went to 32_5/32_6, where can I get the old firmware, my car sounds terrible since the update,
SINasTER's Avatar
SINasTER SINasTER is offline
Car: BMW 335xi E90
Exclamation 06-04-2017, 09:52 PM
My car has been rattleling like crazy also, thought it was my wastegates going to hell but now that I read this, maybe there's something in the last few updates because it started rattling avout when I went from 32.4 to 32.5/32.6/32.6b...
Also, I have a problem with the needle sweep, the odometer is only going to about 120kmh and back down but the tach goes all the way. Tried to reset the dash, going back to a previous release and update again. Nothing makes it go like it was suposed to before a few updates ago...
BMW 550 M-Sport xDrive 2011
HPE DME Stage 2 tune
JB4 backend flash
Custom valved exhaust with 3" quad tips
Custom 3" D.P.s
ESR RF2 19" wheels
Front: Firestone Firehawk Indy 500 235/40R19
Front: Firestone Firehawk Indy 500 285/35R19
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 06-05-2017, 05:06 AM
http://www.n54tech.com/forums/showthread.php?t=46407
Download the 32_8 should solve ur Speedo issue, as for rattle you need to check the FUD bits option for the rattle fix, or try to change your default wastage position.
Car: 2008 BMW 135i
Default 06-05-2017, 05:21 AM
@ Terry ...How in the hell do o change bit 7 for the alternative rattle fix
Rushan's Avatar
Car: 335i E92 2009
Default 06-05-2017, 08:27 AM
Are you using the latest interface?
Default 06-05-2017, 08:38 AM
It's on the FutureUseD BIT options.
Default 06-05-2017, 08:40 AM
You'll need 32.8 for the metric startup sweep. On the rattling maybe you did not reset a FUD value when it changes from byte values to bit settings?
Car: 2008 BMW 135i
Default 06-05-2017, 08:49 AM
@Terry yes I have the latest interface
Default 06-05-2017, 08:56 AM
Added the latest test firmware to the first post. Will merge this thread and this one: http://www.n54tech.com/forums/showthread.php?t=46407 soon.
chrissonfire chrissonfire is offline
Car: n54 bmw e82 135i
Default n54 jb4 problem - help request - - 06-05-2017, 08:10 PM
If anyone here has any clue regarding my issue please let me know in this thread .
everything started out when i decided to update my JB4-G5 to ISO_32_8_T11
after 3000 RPM , the car boosts inconsistently . huge gaps between power as if i was rapidly pressing and releasing . funny thing is my foot is completely still .
When i floor my gas , the car decides to blink me a 30 FF code and an engine malfunction Light .
_______
UPDATE:
Hi @Terry, here's my csv file and my logs. Can you please check it out and tell me what's wrong with my car.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 06-05-2017, 08:18 PM
Picture of my log is uploaded to GYAZO as i have no clue where to attach one .
https://gyazo.com/22f847dd549629daa3f0b1f4d95363aa
https://gyazo.com/67119cc77ea0108ada8303f18db6965e
thank you .
bouliannechristophe@gmail.com
@terry bms
Need a csv in the support section.
Car: 2008 BMW 135i
Default 06-06-2017, 03:42 PM
@Terry BMS,, How do I change the FUD bit 7, my rattle has gotten a lot worse since I uploaded the 32_5 firmware, I had 31_2 prior to this update , Please Help
