n54teek's Avatar
n54teek n54teek is offline
Car: bmw 335i n54
Default N54 coolant tank blew up - 10-01-2016, 10:36 AM
Hey guys and gyals
A little issue with the car.
The coolant tank blew up. I have since replaced the coolant tank with new one. Again the pressure seems to building inside the tank and steam and water is releasing from the cap.
oil temperature is fine. Water pump works properly during bleeding procedure.
Video to come soon
Any guesses before the vid?
could it be the head gasket?
2007 | BMW | E90 | 335i | M Sport | N54 | JB4 G5 ISO | 2 STEP NLS RELAY | MHD BACK END RACE FLASH | OEM BOSCH SPARK PLUGS | BMS DCI | VRSF DP | PE EXHAUST MOD | NORTH EAST ENGLAND | UK |
N54QC N54QC is offline
Car: 07 BMW 335i
Default 10-01-2016, 05:54 PM
You live in a cold weather climate?
bdhh's Avatar
bdhh bdhh is offline
Car: 2008 335i convertible
Default 10-01-2016, 06:05 PM
In clip the top small hose from the top of the tank and run it in a bucket.
Do this on cold start up and take a video. Or take the cap off shine a light in
Res and let's see what's going on?
2008 BMW 335i Convertible
ADE Bottom Mount 6062 Single
VRSF Charge Pipe & 7in intercooler Tial BOV,
Ign Project Plasma Coils & grounds
Robs High & low side Catch Cans with
head plugs.
Diff Brace, Fuel it stage 2 & Meth Port Injection
Aquamist HSF-4 Meth injection
Alpina Flash
BMW PE Mufflers
MDH Flash
Line lock & 16in Drag Radials
11.7 ET, 1.8 60ft, 122mph
n54teek's Avatar
Car: bmw 335i n54
Default 10-02-2016, 12:56 AM
https://youtu.be/uh8PY9VMaJE
https://youtu.be/dm3K9gJjHmE
Water doesn't look like it's bubbling without the cap on and waterpump needs the system perfectly without any strange noises.
Also I don't live in a cold climate, everything so far is leading me to head gasket but the car has only 100k miles on it.
jamesmurray jamesmurray is offline
Default 10-02-2016, 03:48 AM
You'll need to take it to a garage so they can perform a sniff test on the coolant. If there's traces of combustion gases in the coolant it will tell you straight away. Are you sure the water pump is working correctly?
James
2016 UK F22 M240i Alpine White
JB4 with EWG, BM3 Back end flash, BMS meth kit CM10, 4.5" dpipe, BMS filter and heatshield
n54teek's Avatar
Car: bmw 335i n54
Default 10-02-2016, 04:04 AM
100% waterpump is working correctly, engine is at around 90•c oil temp while this is happening
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 10-02-2016, 06:25 AM
Possible stuck thermostats?
RCB RCB is offline
Car: E61 535XIt
Default 10-02-2016, 07:59 AM
+1 for checking the thermostat.
2008 E61 535xit MHD, VRSF CP, Tial BOV, DCI, RB Inlets and Outlets, VRSF 7"FMIC, Custom ***, BMS OCC, RB External PCV, M5 seats, LED interior/DRL, 20" Style 128 wheels, KWv3, M5 steering wheel, M-Sport conversion, Bimmer-Tech HD/Apple TV, RB Twos
2008 Lexus ISF I/H/E, Figs suspension arms, BC/swift, BC wheels, PSS (305 rear)....
1993.5 Supra 857 WHP, GT42R, CCW/R888 (305 rear)...
1968 Plymouth GTX 440 (For Sale)
2017 Chevy 2500HD Z71 LTZ
IG: CBBOOST
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 10-02-2016, 01:43 PM
I'm no expert but in that top picture are some of the tubes possibly blocked with some kind of a radiator repair fluid? The white stuff?
UK FBO 335i, ̶V̶T̶T̶ ̶G̶C̶s̶ China 19T, JB4, PI meth, BMS CP, OCC, Braided brake lines. Diff Lockdown. TMAP sensor, custom bucketless stage2
n54teek's Avatar
Car: bmw 335i n54
Default 10-03-2016, 01:45 AM
i think the white stuff is either residue from either the water or caused by heat, no rad fix has ever been sent down there i dont think.
Ill guess its safe to say its most likely the head gasket, so i need a new engine now :/
I dont think anything else could pressurize the system like that, however i will do a test by connecting the jb4 up and keeping an eye on water temps to see if the pressure is caused by heat or if it is from co2 gasses entering.
AWSAWS's Avatar
Default 10-03-2016, 04:00 AM
I wonder if a previous owner might have used some rad fix stuff though.
You should do the bleed process where you hold the throttle to get the pump staying on for 10 mins or so to check water circulates easily. I think it's also possible to over tighten some of the bleed screws so that water wont be able to flow. I'm sure you know the bleed screw is next to the filler cap. I think the other screw located down near the radiator is only for draining but not 100% certain.
http://wiki.bavariantechnic.com/inde...leed_Procedure
1FastT2 1FastT2 is offline
Default 10-03-2016, 08:53 AM
Did you replaced the coolant reservoir cap when you replaced the reservoir itself?
2008 e92 335i 6MT - On3 Performance Single Kit w/Precision 6266 Gen 2 | VRSF 7" FMIC | VRSF Chargepipe w/HKS BOV | JB4 w/Bluetooth & 2 step and MHD BEF | BMS Meth Kit 2x CM10's | Fuel It Buckless Stage 2 Pump | ADV Sensors | Trebila Tuned
DreadFox DreadFox is offline
Car: 2008 Bmw 535i
Default 10-03-2016, 09:02 AM
Drain the oil, inspect it for coolant, pull the spark plugs look for coolant deposits. Is there lots of moisture coming from the tailpipes? A compression test will tell you right away if it's a head gasket or not.
I'm probably reading a SAE Paper...or in the garage.
BostonBeemah's Avatar
Car: AW 135i
Default 10-04-2016, 01:23 PM
Hope its not a head gasket causing excessive pressure in the cooling system and you dont need an new engine to fix it either. Good luck!
RIP 2008 AW/BL 135i
n54teek's Avatar
Car: bmw 335i n54
Default 10-05-2016, 10:45 AM
I have a spare n54 engine in the garage so I wont bother messing with this and just install the other engine in.
anything i should do while the engine is already out?
mr.335i mr.335i is offline
Car: E92 335i
Default 10-05-2016, 12:13 PM
Replace engine mounts while you can.
HTX. 6MT FBO E85
stuie1982 stuie1982 is offline
Car: 335i 2007
Default 10-05-2016, 12:16 PM
Hi n54teek,
I see your in the UK running the MHD Race BEF. Can i ask what map (boost) your running on the JB4 and what fuel you are using?
I seen another post saying you can run the MHD race flash ok on vpower nirtro+ so was thinking of doing same once i fit my new inlets and outlets.
Cheers
DaZuc DaZuc is offline
Car: 335i xDrive
Default 10-05-2016, 12:48 PM
Possibly overfilled system.
n54teek's Avatar
Car: bmw 335i n54
Default 10-05-2016, 12:54 PM
stuie1982 hey, use the race flash on map 2 if u are FBO on nitro plusthen log and post the log on here.
Dazuc, its not overfilled.
Car: 335i 2007
Default 10-06-2016, 02:31 PM
Alright nice one, will give it a go. Im FBO. What do you make of Tesco 99? Better or worse than Nitro+ ?
n54teek's Avatar
Car: bmw 335i n54
Default 10-06-2016, 08:05 PM
id say tesco99 is better due to higher octane = less chance of knock and more ethanol content
Darren2008 Darren2008 is offline
Car: 328i E46
Default 10-07-2016, 03:07 AM
vacuum lines.....good time to replace them
AWSAWS's Avatar
Default 10-07-2016, 05:56 AM
The VPower Nitro+ apparently claims 99ron these days but momentum is cheaper.
Car: 335i 2007
Default 10-08-2016, 04:37 AM
I had a 21psi tune from ***** running about 3 up to 7 degree tuning and it never seemed to have any timing drops. Never tried tesco on that tune but I did on 18-19psi tune with about 7 to 9 degree timing and was just showing signs of being too aggressive so I know the limit of Tesco and would not want to run that tune for long. Tesco is easier for me to get. Shell vpower is supposed to be 99 but shell won't say so could be more or less or maybe they don't want to say as it changes. Been tempted to buy and octain tester and actually see what we are running!
Do you guys have any logs for both Tesco and vpower?
AWSAWS's Avatar
Default 10-09-2016, 02:54 PM
Fuel blends vary throughout the year to adjust for the temp changes so what was once bad may be better and what was once great may not be as good.
To get over this you can add some ethanol yourself to increase the octane and efficiency of the engine. 7 to 9 degrees is not that much but I wouldn't go any higher unless using ethanol or water/meth injection. Personally I wouldn't run boost over 15 psi on just pump fuel. I feel the effective compression is just too stressful on the engine in those conditions.
