(#1251)
Jrod33084 Jrod33084 is offline
Car: 2013 328i M sport
Default 03-15-2016, 07:32 AM
Originally Posted by BIGBOYQ
There is no benefit in changing the Air Intakes - the limiting factor is your down pipes.
You have four options
1) Purchase an DP *******
2) Purchase an DP sport (most expensive) should pass emissions tets
3) Find an original DP, and bash the CATs out - (will look OEM - but expect it to fail emissions tests, I understand performance gains are better than stock - but an DP ******* will perform better due to less turbulence)
4) Keep it stock and only run MAP 1
I agree. Keep it in map 1 if you're stock. Even tho I know the tune has a safety temperature fail safe(won't work below 160 or above 240, I think?) I've noticed in map 2 the temperature gauge getting a lot hotter than in the stock performance map.
So a ******** with the *** would still pass emissions? No engine light?
BIGBOYQ's Avatar
BIGBOYQ BIGBOYQ is offline
Default 03-15-2016, 07:45 AM
I hate these ********
If you are replacing your DP to be C A T L E S S - expect it to fail -however I am aware some times they can pass. I think having your engine warm does help - but depends on your country's specification of emission testing.
The JB4 will remove the CEL warning as I believe
Default 03-15-2016, 09:16 AM
Yea I would rather play the safer side and not deal with failed emmisions. I wonder if running map 2 with a catte'd DP would still trip an engine light...
BIGBOYQ's Avatar
Default 03-15-2016, 09:20 AM
Check the manufacture of the DP website - as some differ - however the JB4 removes the warning
Registered Users
Default 03-15-2016, 09:48 AM
Map2 can be used with 93+ octane as well if you don't have DP you must have 93+ octane
joq3 joq3 is offline
Car: BMW 328i F30 -13
Default 03-16-2016, 01:26 AM
Are you sure? Will Shell V-Power 93 octane (+5% ethanol) work?
This is the most powerfull fuel in Sweden, where i live. In EU we call it 98 octane, which is the same as your 93.
milkdi milkdi is offline
Car: BMW F10 520i
Default 03-18-2016, 05:39 AM
I see that the PWG firmware is available for download now. Is it official now?
Seraphblade@SG Seraphblade@SG is offline
Car: BMW F30 328i
Default 03-20-2016, 01:16 AM
It would work. I have been running that for 3 years on map 2 without dp
disfunk disfunk is offline
Car: bmw
Default 03-20-2016, 04:38 AM
may I ask if the all weather enclosure is made to fit the jb4 stage 2 for n20 pwg?
noticed the all weather enclosure shown below seems longer than the high temp enclosure, so must a board get changed or something?
high temp enclosure
Default 03-20-2016, 07:59 PM
All enclosures fit all boards. For F series (including N20) we now include and suggest the water resistant. For E series the high temp is suggested as its already in a water proof DME box.
Car: bmw
Default 03-21-2016, 07:51 AM
to clear up the confusion, does it mean my existing jb4 stage 2 as pictured
will fit into the all weather enclosure which appears slim and longer?
have never opened the jb4 stage 2 to see the board so i assumed its fat as the enclosure and thought it wouldn't fit into the slim all weather enclosure
Default 03-21-2016, 08:05 AM
Yes, it will.
Car: bmw
Default 03-22-2016, 07:38 AM
thx! Btw is it possible for the jb4 to enable needle swipe on the f30 n20?
felipebmartins felipebmartins is offline
Car: bmw 320i
Default 04-06-2016, 03:52 PM
Yes, it will.
terry, please tell me by direct message , I have some doubts about JB4 , want your help
Default 04-06-2016, 06:08 PM
No it's not an F series feature currently. Maybe down the road.
Default 04-06-2016, 06:09 PM
I missed your question. What is it?
BIGBOYQ's Avatar
Default Waste Gate Rattle - 04-07-2016, 01:08 PM
I have an annoying sound, that is more noticeable in the cabin than in the engine bay. I believe from adding my new DP's its most likely waste gate rattle.
Since I have Z4 E89 with EWG
I understand there is no solution for waste-gate rattle for this Z4/X1 variant?
Reading other users, they have made tweeks within the "user adjustment settings"
What can I change to find a resolution?
Default 04-07-2016, 03:36 PM
There is no WG adjustment for integrated EWG firmware like the N20 uses.
bono_belem bono_belem is offline
Car: 320i ActiveFlex
Default 04-11-2016, 07:53 AM
Terry, can i install ewg firmware onto a pwg board jb4? my engine has ewg, but my jb4 has a pwg board.
tks
Default 04-13-2016, 01:15 PM
Support requests are deleted from the thread without being read. Use the support forum for personal assistance.
Roxxor Roxxor is offline
Car: 2013 328i M-Sport
Default 04-16-2016, 08:40 AM
Trying to figure out what settings to set as default on my JB4. 2013 328i with EWG, but I have an older JB4 made prior to the EWG differences. I don't have the EWG cable, my understanding is to still use the EWG firmware?
Also, I saw in the main post, it says "Set PID Gain to 10 and AutoShiftBoostReduction to 10. We also suggest lowering FF / Wastegate Adaption manually to 50 so it can learn itself up or down. All other settings are unchanged." Is this only if I am using the EWG cable?
Buenos24 Buenos24 is offline
Car: F35
Default 05-12-2016, 07:40 AM
my car is f30
my tuner is lastest bms jb4
i ues map5
but i dont know why when im driving, it will change to map4 autoly sometimes, and the power also cannot beyond 1bar
BIGBOYQ's Avatar
Default 05-19-2016, 04:50 AM
Anyone had issues with N20_OBDII_EWG_3.hex - as my JB4 is connected and visible - no errors or cels
But
NO RPM Recorded
NO BC controls work
E92 335i JB4 Stage 1 (Sold)
E89 28i JB4 Stage 2; Down P1pes; KW3's; 310bhp (Sold)
M2 N55 JB4; Down P1pes
jebs2k jebs2k is offline
Car: 2012 328i
Default 05-23-2016, 04:42 PM
do we have the flash blinkers when engine up to temp and the startup needle sweep yet?
anthonyrand's Avatar
anthonyrand anthonyrand is offline
Car: 428i JB4
Default 05-31-2016, 09:29 PM
I have ******* DP and run map 2 and havent seen a check engine light. I plugged it into the laptop to even see if i could see a warning in the JB$ an nothing there
