DSBM135i's Avatar
DSBM135i DSBM135i is offline
SICKwitIT
Car: DSBM 135i
Default 08-10-2015, 07:08 AM
So overall terry the N20 tunes and mods still need a bit more R&D to ensure motor life reliability?
2011 BMW 135i N55/ Convenience Package/ M Sport Package/ Premium Package/ Cold weather Package/ JB4 N55 Stage 2/ Cyba Air Scoops/ Berk Technology DP/ Shadowline Rear Diffuser/ Blonix by Iss Forged B-Spec/18x9 and 18x10.5/ Accelera Tires/ 205/40/18, 225/40/18/ Brembo Calipers/ H&R Street Performance Coilover/Full Catback exhaust by Riss Racing/ BMS Intake
Car: BMW 320i
Default 08-10-2015, 06:50 PM
The first N20 update coming is duty bias adjustments similar to what we've added to the N54 platform recently. So you can hand dial in your boost control.
Terry, has this feature already been implemented for N20s?
BostonBeemah's Avatar
Car: AW 135i
Default 08-10-2015, 09:55 PM
Do the 320i and 328i have the same n20 hardware wise?
RIP 2008 AW/BL 135i
Car: BMW 320i
Default 08-11-2015, 05:36 PM
Nope. AFAIK everything but the pistons is shared. Usually 320i's are high compression (11:1) but there're low compression ones too. And all 328i's are low compression (10:1).
There are some other minor variations too. For instance here in Brazil we have a flexfuel variation with different fuel lines, fuel pump, ethanol sensor, etc.
LycanX4M40i LycanX4M40i is offline
Registered Users
Car: 14' F25 X3 xDrive28 M-Sport AlpineWhite DHP
Default 09-06-2015, 12:10 PM
N20 is a dump but not as bad as its predecessor
harkes harkes is offline
Registered Users
Car: M135i
Default 09-06-2015, 08:44 PM
Sound like quite a few N20's has died with just Map2 and d0wnpipe... Running anything else than Map1 seems to be a bit of a gamble.
Default 09-06-2015, 08:55 PM
The motor just needs stronger rods. Seems that is what fails at higher torque levels.
timberwolf timberwolf is offline
Default 09-10-2015, 01:29 PM
So if I wanted to just do jB4 on our 528i Xdrive, do you think it's foolish for a daily driver? Naturally the power level is lower that a full meth/dp setup
Burgerized Cars:
19 Jeep Rubicon 2.0L
17 X5 50i
16 Golf R
13 M5
08 135i
Check out my videos
http://www.youtube.com/gvahan#p/u
wolfxx66 wolfxx66 is offline
Car: Bmw 228i
Default 11-06-2015, 08:02 AM
Originally Posted by e46m3lol
Can't wait to install the meth kit in the coming weeks on my FBO 228i. I'm already at 330whp so I'm curious to see if I can break the the 350whp mark.
Have you installed the meth kit yet? I have the same car with dp jb4 and intake. I'd love to know if you have had any problems in terms of reliability.
Registered Users
Default 11-06-2015, 08:34 AM
He is ECU Flash now, car threw some rods due to Turbo Upgrade JB4 on 91
Car: Bmw 228i
Default 11-06-2015, 08:54 AM
What are the options for changing the rods? Can anything be done about it?
rustyminded rustyminded is offline
Car: Bmw 328i F30
Default 11-08-2015, 11:45 AM
Call ABR Houston. they said they can do rods, turbo upgrade ect.
F30 328i - 8 auto.. JB4+FF+EWG, OCC, Injen Intake+scoop, AFE dp, AA axle-back - H&R springs, H&R rear SB - Front Strut - F&R BMS spacers..
Car: BMW 320i
Default 11-08-2015, 06:07 PM
Yeah, I think they're able to rebuild the bottom end with forged parts. As far as I know they use N54 parts. The N54 rod is 0.3 mm longer but the N20 wrist pin is 0.3 mm offset (from piston centerline). N54 rod bearings can also be used but the crankshaft has to be machined. Regarding the pistons, I don't know if N54 pistons can be used.
Unless he takes his car to Alex's shop, I don't think he's gonna be able to buy the parts from Alex. I already tried several times.
CP Carrillo can custom make pistons and rods but not bearings. I think they already have the molds so you won't need to send them the parts for molding.
I've been told JE and Pauter have already made forged pistons and rods but you'd need to contact them.
Get in touch with Anthony @ VAC Motorsports (anthony@vacmotorsports.com). He's sourcing the parts for me.
Registered Users
Default 11-10-2015, 04:00 PM
So who will be the first N20 with upgraded internals ?
Car: BMW 320i
Default 11-16-2015, 05:18 PM
My engine should be up and running in two weeks but I'm pretty sure I'm not the first one.
Registered Users
Default 11-17-2015, 10:03 AM
keep us posted
are you on bimmerfest or bimmerpost?
Car: BMW 320i
Default 11-17-2015, 10:06 AM
Originally Posted by RobX3
keep us posted
Yup, bimmerpost
Car: Bmw 228i
Default 11-18-2015, 08:40 AM
Can't wait to hear the result!
Registered Users
Default 11-24-2015, 04:26 PM
Yup, bimmerpost
Do you have a build thread progress?
Car: BMW 320i
Default 11-24-2015, 07:12 PM
Not yet but I intend to as soon as I get it up and running.
Car: Bmw 228i
Default 12-07-2015, 06:41 AM
How did it turn out?
Car: BMW 320i
Default 12-08-2015, 07:26 PM
Not finished yet. Lots of holdups.
Registered Users
Default 12-09-2015, 06:34 AM
Keep us posted, what are the upgrades you're having done?
Car: Bmw 228i
Default 01-04-2016, 12:18 PM
Any progress?
Seraphblade@SG Seraphblade@SG is offline
Car: BMW F30 328i
Default 01-12-2016, 06:13 AM
Is there some install notes that I can follow for the meth kit for N20?
From the burgertuning website, the installation notes applies for N54 and N55... Should I follow the N55?
